2024-09-30 at 10:08 am #10482
How does wire cutting go halfway back to the origin? In the process of wire cutting, if it is necessary to stop the processing and return the cutting head to the origin, it can be achieved through a series of operations. Here are some concrete steps to get back to square one.
First, the cutting process needs to be stopped. In general, the operator needs to press the stop button or click the stop icon in the software control interface. This immediately stops the machining process and the cutting head stays in its current position.
Second, you need to move the cutting head back to the origin position. The operator can input instructions on the machine control panel or click the "back to origin" button in the software interface, and the machine will move the cutting head to the preset back to origin position.
In this process, care needs to be taken to adjust back to the origin position and ensure that the cutting head can move smoothly to this position. The return to the origin position of different machine tools may be different, and the operator needs to check the relevant instructions of the equipment or consult professionals to ensure that the correct setting of the return to the origin.
When the cutting head reaches the origin position, the operator needs to set the processing starting point again, and adjust the processing depth and parameters. After confirmation, you can restart the cutting process, move the cutting head to the specified position, and start the cutting process.
Before returning to the origin, you need to save the current location information to prevent improper operations caused by information loss. In addition, it is necessary to carry out regular maintenance and maintenance of the machine tool to ensure the normal operation and accuracy of the equipment.
In short, the return to the origin operation in wire cutting processing is a relatively basic but critical process, which requires the operator to correctly grasp the relevant knowledge and skills to ensure the accuracy and efficiency of cutting processing. Only after professional training and practice, operators can be more skilled and accurate back to the origin of the operation, to provide better processing services.
http://www.talentcnc.com
Suzhou Talent Import and Export Co., Ltd. -
