How PU Spray Machines Work and Operation Guide
  • #13236
      Polyurethane (PU) has become a cornerstone material across various industries—offering versatility, insulation, and structural benefits in everything from construction to automotive components. Behind its seamless application lies a critical piece of equipment: the PU spray machine.
      This article explores how PU spray machines work, provides a step-by-step operation guide, and highlights Haifeng, a leading manufacturer of PU production and processing systems, known for delivering reliable, innovative equipment to global markets.
      What Is a PU Spray Machine?
      A PU spray machine (polyurethane spray machine) is a specialized device designed to mix and apply two reactive liquid components—isocyanate (A) and polyol resin (B)—to form polyurethane foam or elastomer on surfaces. These machines are widely used for:
      Thermal insulation
      Waterproofing
      Protective coatings
      Seamless sealing and lining
      PU spray systems are essential in construction, refrigeration, pipeline coating, shipbuilding, and more.
      PU Sprary Machine
      How PU Spray Machines Work: The Basics
      PU spray machines operate on a high-pressure, two-component system, combining chemical precision with mechanical force to ensure proper mixing and spraying. Here's how they function:
      1. Raw Material Storage
      Each component (A and B) is stored in separate heated and agitated tanks to maintain optimal temperature and consistency.
      2. Metering and Pumping
      Two independent metering pumps deliver precise volumes of each component to the mixing chamber. Consistency in the mix ratio (commonly 1:1) is vital to the chemical reaction that forms PU.
      3. Heating System
      PU spray machines include inline heaters to preheat the materials, ensuring proper viscosity for atomization and reaction. Heating is especially critical in colder environments.
      4. Mixing and Spraying
      The two components meet in a mixing head, usually using impingement (high-pressure collision), and are instantly sprayed out as a reactive blend. The mixture starts foaming or curing within seconds after application.
      5. Spray Gun Control
      The operator uses a spray gun to direct the material onto surfaces. Spray pattern, flow rate, and fan width are adjustable for different applications—like wall insulation, tank coating, or floor sealing.
      Operation Guide: Step-by-Step Process
      Operating a PU spray machine requires precision and adherence to safety procedures. Here’s a simplified guide:
      1. Pre-Operation Check
      Inspect the machine and hoses for damage or blockages.
      Ensure chemical drums are full and sealed.
      Power on and check electrical and pneumatic connections.
      2. Temperature and Pressure Settings
      Set the required temperatures for A and B tanks (typically 45–70°C).
      Adjust the pressure for both components (usually 1000–2500 psi, depending on material spec).
      Monitor gauge readings for consistency.
      3. Machine Start-Up
      Activate pre-heating systems.
      Purge air from hoses to prevent uneven spraying.
      Circulate components for a few minutes to stabilize temperature and viscosity.
      4. Test Spray
      Conduct a test spray on a designated surface or collection board.
      Check for mix balance, spray pattern, and reaction quality (foam structure or coating uniformity).
      5. Full Operation
      Begin applying the mixture to the work surface.
      Maintain consistent spray distance (usually 40–70 cm) and movement speed.
      Avoid pauses or back-sprays to prevent uneven layering or dripping.
      6. Post-Operation Maintenance
      Flush the mixing chamber and hoses with a recommended cleaning agent.
      Relieve pressure from the system.
      Store the spray gun properly and cover tanks to avoid contamination.
      PU Sprary Machine
      Haifeng: Your Trusted PU Equipment Partner
      Among the many manufacturers in this space, Haifeng stands out as one of the most professional and experienced developers of polyurethane production equipment and system solutions.
      With a strong commitment to R&D and customer-focused engineering, Haifeng offers:
      High-pressure PU spray machines
      Low-pressure casting systems
      PU elastomer processing units
      Custom foam production lines
      Key Advantages of Haifeng PU Spray Machines
      Precision metering for consistent mix ratios
      Stable heating systems for reliable spraying in all environments
      User-friendly interface with digital control panels
      Durable components for long service life and low maintenance
      Custom configuration available for specific industry needs
      Haifeng’s equipment is widely used in building insulation, cold storage, pipeline anticorrosion, and automotive interiors—delivering efficiency, reliability, and top-tier safety.
      PU Sprary Machine
      Common Applications of PU Spray Machines
      Haifeng PU spray systems are applicable across industries:
      Construction: Roof and wall insulation, waterproof layers
      Vehicle Manufacturing: Interior panel filling, soundproofing
      Industrial Equipment: Protective coatings, pipeline insulation
      Refrigeration: Cold room panels, freezer insulation
      Marine: Deck coating, flotation systems
      Q: Can PU spray machines be used for both foam and coating?
      Yes, depending on the model and material, Haifeng machines can handle both expanding foam and rigid coating systems.
      Q: What maintenance is required?
      Regular cleaning of the mixing head, flushing of hoses, and calibration of pressure systems are essential. Haifeng machines are designed for easy maintenance with clear alerts and diagnostics.
      Q: How long does it take for sprayed PU to cure?
      Initial reaction occurs in seconds, but full curing may take several hours depending on ambient conditions and material type.
      PU Sprary Machine
      A well-designed PU spray machine is the backbone of efficient, high-quality polyurethane applications. Whether you’re insulating buildings or coating industrial tanks, choosing the right equipment makes all the difference.
      Haifeng, with its for many years of experience in PU machinery, offers precision-engineered solutions tailored for the most demanding industries. From reliable performance to expert support, Haifeng’s systems ensure you get the job done right—every time.
      What Is a PU Spray Machine? Purpose, Function, and Key Benefits
      http://www.haifeng-automation.cn
      Haifeng
