2026-11-11 at 9:21 am #18360
Choosing a mixer for a 1,000-liter production batch involves more than checking whether the tank can hold the required volume. The characteristics of the material, especially its viscosity, powder content, and circulation behavior, have a direct impact on mixing performance.
This is a common consideration for manufacturers working with paints, inks, resins, putty, pigments, gels, and other chemical formulations. Some materials flow relatively easily, while others become thick and difficult to move once the ingredients are combined. In these situations, conventional single-shaft equipment may not provide sufficient circulation or dispersion.
Powder particles can form lumps during feeding, some ingredients may take longer to dissolve, and material close to the tank wall may not participate effectively in the mixing process. These issues can affect batch consistency and extend production time.
One equipment option worth considering is a Chemical Double Shaft Mixer, which integrates high-speed dispersion with low-speed agitation. This combination is designed to address different mixing requirements within the same vessel.
How Two Agitators Improve the Mixing Process
The working principle of a double-shaft mixer is based on two agitators performing complementary functions rather than simply increasing the number of mixing components.
In Rumi's Double Shaft Mixer, the high-speed disperser is installed concentrically within a low-speed anchor or frame agitator. Each component has its own drive system and contributes differently to the processing cycle.
The dispersing disc generates intensive shear in its surrounding area. This is particularly useful when introducing powders into liquid formulations, as the localized shear helps wet particles and break down agglomerates. It can improve the distribution of pigments, fillers, and other solid ingredients throughout the liquid phase.
The anchor agitator focuses on moving the overall batch. It continuously circulates the material and helps transport ingredients from different areas of the tank toward the dispersing zone. This reduces the likelihood of having regions that remain poorly mixed.
These two functions complement each other. A high-speed disperser working alone may provide sufficient shear around the disc but struggle to move highly viscous material throughout a large vessel. An anchor agitator, on the other hand, can provide bulk circulation but may not deliver the concentrated shear needed for effective powder dispersion.
The combined configuration helps address both limitations.
Another useful feature is the PTFE scraper installed on the anchor frame. During operation, the scraper removes material accumulating on the inner tank wall and returns it to the moving batch. Besides reducing material residue, this action helps maintain contact between the product and the jacketed vessel surface, supporting more effective heat transfer.
For manufacturers handling medium or large production batches, maintaining this circulation pattern is an important part of achieving consistent processing conditions.
Why Speed, Temperature, and Processing Conditions Matter
Not every chemical formulation should be processed using the same mixing speed or operating temperature.
For example, resin formulations can become considerably more viscous when temperatures decrease. Paint and ink production may require intensive pigment dispersion while controlling air incorporation. Putty and gel formulations often need continuous bulk movement to prevent poorly circulated areas.
Rumi's Double Shaft Mixer uses frequency converter control to adjust the operating speeds of both agitators independently. Operators can therefore modify the mixing conditions according to the material and the current production stage.
During the initial powder-feeding stage, a higher disperser speed may be appropriate to improve particle wetting and dispersion. After the solid ingredients have been incorporated, the process can move toward homogenization, with the anchor agitator maintaining circulation throughout the vessel.
Temperature management is another factor that should not be overlooked. The mixer is equipped with a jacketed tank that can be connected to an external heating or cooling system.
Heating may help lower the viscosity of certain resin or gel formulations, making them easier to circulate. Cooling can be used when the material needs to be brought back to a controlled temperature after processing or when excessive heat could affect the formulation.
Atmosphere control is also available for processes that require it. The airtight vessel design supports vacuum operation and inert gas protection. Vacuum can be used to remove entrained air from the product, while inert gas protection provides a controlled atmosphere for formulations that require reduced exposure to air.
In addition, the hydraulic lifting mechanism allows the mixing assembly to move vertically. This makes it easier to access the vessel during material loading, equipment cleaning, inspection, and routine maintenance.
For manufacturers processing different formulations on the same production line, these features can make equipment operation and changeover more manageable.
What Influences the Price of a Chemical Double Shaft Mixer?
When requesting a Chemical double shaft mixer price, buyers should avoid evaluating equipment based solely on tank capacity. Mixers with identical working volumes can have very different configurations depending on the actual production requirements.
Material viscosity is one of the primary considerations. High-viscosity products generally require more drive torque and appropriate motor capacity to maintain stable movement. The required dispersion intensity and operating speed also influence the selection of the high-speed drive system.
The mechanical configuration is another cost factor. A double-shaft arrangement requires two independently driven agitators, together with the associated transmission and control components. Additional features such as hydraulic lifting, frequency converters, digital speed displays, and optional PLC touch-screen systems will also affect the overall equipment cost.
Wetted-part materials should be selected according to the chemical properties of the formulation. Rumi supplies Stainless Steel 304 as the standard material for wetted parts, with SS316L available as an option when higher corrosion resistance is needed.
Other configuration details may include:
Jacket design and heating or cooling requirements.
Vacuum capability and sealing configuration.
Inert gas protection.
Hydraulic lifting arrangements.
Control system and automation level.
Required production capacity and mixing performance.
These factors explain why comparing quotations based only on nominal capacity or motor power may not provide a reliable basis for purchasing decisions.
A more useful approach is to compare the complete technical configuration against the actual production process.
What Should Buyers Look for in Chemical Double Shaft Mixer Manufacturers?
Selecting suitable Chemical double shaft mixer manufacturers requires more than checking product specifications and comparing quotations. The manufacturer's engineering experience and ability to understand the application are equally important.
Before finalizing a mixer design, several process details should be discussed, including the formulation's viscosity, batch volume, powder-to-liquid ratio, required dispersion intensity, operating temperature, and expected production cycle.
Heating, cooling, vacuum, and inert gas requirements should also be considered where applicable. These details help determine the appropriate motor capacity, agitator structure, tank configuration, and control system.
Rumi is a professional supplier of chemical equipment and processing solutions, serving customers in different markets worldwide.
Since developing its first high-precision dosing system and high-efficiency mixing equipment in 2018, RUMI Technology has concentrated on fine chemical equipment and customized process solutions. Its application experience includes paint and ink dosing, resin and new-material processing, as well as equipment for the new energy and composite industries.
Through hundreds of R&D iterations, RUMI has developed proprietary technologies and obtained invention patents related to dosing and mixing equipment.
Manufacturing and after-sales support are also relevant when selecting production machinery. Rumi's quality assurance arrangements include 72-hour factory testing, a 24-hour after-sales response commitment, and ISO9001 and CE certifications.
For buyers planning to use a mixer regularly in batch production, these considerations are worth reviewing alongside the technical specifications.
Final Thoughts: Select the Mixer Based on Your Formulation
There is no single double-shaft mixer configuration that is ideal for every chemical product. The appropriate design depends on how the material behaves during processing and what the production line needs to achieve.
For paint and pigment applications involving substantial powder addition, dispersion performance and shear conditions deserve particular attention. For thick resin, putty, and gel formulations, anchor circulation, scraper design, drive torque, and temperature management become especially important.
If the production process requires air removal or protection from atmospheric exposure, vacuum operation or inert gas protection should also be considered during the equipment selection stage.
Ultimately, the purpose of a Chemical Double Shaft Mixer is not simply to rotate two agitators inside a tank. It is to maintain effective material movement, achieve the required dispersion, manage temperature, and support consistent processing across the entire batch.
Therefore, when comparing Chemical double shaft mixer price or evaluating different Chemical double shaft mixer manufacturers, buyers should look at the complete processing solution rather than focusing on one specification. Matching the equipment configuration to the actual formulation is a more practical way to achieve reliable production performance.
https://www.rumiasia.com/
RUMI Technology -
