2026-10-23 at 7:20 pm #18084
Choosing a dried chili color sorter is not a matter of selecting the largest model or the most aggressive color setting. A Mexican plant needs a solution that matches its chili variety, product form, target defects, required output grades and available line conditions. This guide shows what to check before requesting a quotation.
The decision rule: choose the sorter only after a representative sample test confirms that the machine can separate your difficult material while keeping good chili in the saleable stream. Then match the tested result to capacity, feed structure, air requirements, layout and service support.1. Describe the product form before comparing suppliers
Start with the material entering the machine: whole pods, broken pods, mixed forms, cleaned chili or material with stems and fibers. Whole pods need a different presentation from small fragments. If the plant processes both, ask whether recipes and feeding conditions can be changed without rebuilding the line.
2. Turn the buyer’s quality standard into target outputs
Write down the streams you need: primary whole-pod grade, second color grade, grinding material, recovery and final reject. A supplier should explain how the outlets will be used and how good-product carry-over will be checked. If the only output is “reject,” the plant may lose material that still has commercial value.
3. Compare the machine by decision coverage
A dried chili sorter should be judged by the features it can evaluate on your samples: color range, visible surface condition, shape, size and distinguishable plant material. Ask the supplier to show difficult samples—not just clean red pods—and to explain which targets are surface-visible and which require another process.
WESORT’s spice sorting application uses product-specific testing and optical classification. The WESORT products center helps buyers compare sorting equipment by application, while the final machine recommendation follows the sample, throughput and line layout.
4. Check feeding, overlap and product handling
Dried chili is irregular. Pods can overlap, turn, split or carry dust. A sorter with a technically strong camera still needs a stable feed. During the trial, ask how the system handles:
- Dense flow and overlapping pods.
- Large differences in pod length and diameter.
- Broken chili and small fragments mixed with whole pods.
- Dust or plant fibers on the feed surface.
- Transfers where saleable chili could be damaged or lost.
5. Request a complete test report, not a sales sentence
A useful report should include:
- The sample description and target defect categories.
- Accepted-stream appearance and reject-stream purity.
- Good-product carry-over into reject.
- Feed rate used during the test and whether a second pass was required.
- Photos or video of the actual machine output.
- Required power, compressed air, footprint and operator tasks.
- Recommended recipe changeover and cleaning procedure.
WESORT’s Mexico customer materials show why this matters. The site review compared several visible sample groups instead of presenting one idealized lot. That allows the buyer to discuss the exact boundary between main product, recovery material and reject.
6. Evaluate the supplier behind the machine
A chili season does not stay visually identical. New suppliers, harvest dates, drying conditions and storage can shift color and surface appearance. Ask who will help adjust the recipe, what information the operator should send during a problem and how remote technical support is handled after installation.
WESORT provides a route from sample evaluation to equipment configuration and technical communication. Buyers can use the WESORT customer stories to understand how real applications are documented, then request a test based on their own Mexican chili.
7. Choose the configuration only after the application is clear
Buyer condition What to discuss with WESORT Whole-pod packing Visible color window, pod integrity, stem removal and low carry-over of accepted pods. Grinding raw material Broken-piece tolerance, foreign material and recovery value. Mixed whole and broken product Feeding changeover, recipe management and separate output streams. High defect variation Sample range, borderline training examples and recheck frequency. Existing cleaning line Where the sorter will be installed and which upstream or downstream controls remain necessary. 8. What should the Mexican plant send with an inquiry?
Send the chili variety, product form, normal and peak throughput, target defects, accepted and reject references, current cleaning steps, available compressed-air conditions, available floor space and preferred output grades. Photos and a short video help explain the feed, but physical samples are the most useful basis for a final recommendation.
WESORT’s customer-site material from Mexico includes three sample groups and visible plant debris. It is a good example of the information that turns a general request—“we need a chili sorter”—into a specific discussion about color boundaries, broken chili, stems, fibers and usable recovery.
How WESORT helps after the purchase decision
WESORT can support the project through material testing, sorting-program setup, equipment selection, commissioning guidance and later parameter communication. The aim is not only to deliver a cabinet, but to help the customer keep a repeatable visible grade as the incoming material changes.
Ask WESORT for a Mexico dried chili equipment proposal
Share your samples and production requirements. We will discuss which visible defects can be evaluated, how the product should be presented, what outputs make commercial sense and which machine configuration should be tested before you commit to the purchase.
https://www.wesortcolorsorter.com/
Shenzhen Wesort Optoelectronics Co., Ltd. -
