2025-05-08 at 10:46 am #12564
After purchasing an electric vehicle, the maintenance and precautions of the
electric sightseeing vehicle in the later stage are as follows:The electric sightseeing vehicle should be placed in a cool and dry place,
avoiding direct sunlight and rain to prevent damage to the vehicle.Regularly check the condition of the electric sightseeing vehicle, including
whether the front and rear brakes are sensitive, whether the tire pressure is
sufficient, whether the screws are loose, whether there is any abnormal sound in
the vehicle, whether the battery is fully charged, etc. If any abnormality is
found, it should be adjusted or repaired in time.Regularly check whether the battery connection wire is broken, whether the
pole is loose or moldy, etc. If there is a problem, it should be handled in time
to prevent the whole vehicle circuit from failing.If the electric sightseeing vehicle is stored for a long time, its battery
should be charged regularly to prevent the battery from running out of
power.When cleaning the electric sightseeing vehicle, avoid directly washing the
electrical components of the vehicle with water to prevent short circuit or
electric shock. When cleaning, you can cover the contact power supply part with
a plastic bag or other waterproof cover, and then clean it with soapy water or
detergent. If it is a rubber part, it cannot be washed with water, but only
wiped with a cloth.When operating an electric sightseeing car, you should follow the safe
operating procedures, such as disconnecting the power supply, pulling out the
key, pulling the brake, etc.During driving, proper ventilation should be maintained to avoid sparks or
open flames.The above are the maintenance and precautions of electric sightseeing cars, I
hope it will be helpful to you.The following are common electric sightseeing car styles for reference, there
are 8 seats, 11 seats, 14 seats, 23 seats, closed and open.http://www.kaopuvehicle.com
ShenZhen KaoPu Electric Vehicle Co., Ltd -
