2026-11-07 at 10:00 am #18327
Custom hydraulic components are often designed around the specific requirements of a machine or hydraulic circuit. Port positions, mounting dimensions, internal passages and material specifications may differ significantly from one project to another. For manufacturers, turning these requirements into a finished component depends heavily on the accuracy and completeness of the engineering documentation.
When sourcing a Non-standard valve block, buyers should pay particular attention to the technical drawing package. Clear dimensions, machining details, material grades and inspection requirements give the manufacturer a reliable basis for production planning. Incomplete information can lead to repeated clarification, longer approval cycles or differences between the intended design and the finished component.
A well-prepared drawing does more than describe the component's shape. It communicates how the part needs to fit, connect and function within the larger hydraulic system.
1. Provide Complete Views and Overall Dimensions
The first step is to define the component's overall geometry. The drawing should clearly indicate its length, width and height, along with any stepped surfaces, recesses, mounting faces and other structural features.
For complicated valve blocks, one or two views may not be sufficient. Front, side and top views, together with sectional details where necessary, help explain the relationship between external surfaces and internal machining features.
A useful drawing should also include:
Consistent measurement units throughout the document
Overall dimensions and important intermediate dimensions
Positions of mounting faces and structural features
Sectional views for internal passages
Reference dimensions for complex profiles
The intended installation orientation, where relevant
Reference surfaces should be clear, particularly when the component contains several mounting levels or machined faces. This makes it easier to interpret the design and establish suitable machining and measurement references.
MAYTAG handles custom hydraulic manifold blocks in different sizes and weights. Manufacturing examples include components measuring 600 × 390 × 200 mm and 560 × 350 × 290 mm, with a listed product weight range of approximately 1–200 kg. These figures illustrate the range of component sizes handled; the feasibility and requirements of each new project are evaluated according to its own drawings.
2. Identify Critical Dimensions and Tolerances
Not all dimensions have the same functional importance. Some determine the overall shape, while others directly affect mounting accuracy, connection alignment or assembly performance.
For a custom valve block, buyers should clearly identify the dimensions that require particular attention. These may include:
Overall length, width and height
Mounting hole diameters and positions
Hole depths and threaded features
Distances between machined surfaces
Port center positions and spacing
Flatness, parallelism and perpendicularity requirements
Other geometric tolerances specified by the design
A consistent datum system is also important. When dimensions are measured from different reference points without clear relationships, the drawing may be interpreted differently by manufacturing and inspection personnel.
Customers should define suitable datum references and indicate which surfaces or features are used to locate the component during assembly or measurement.
It is equally important to avoid applying unnecessarily tight tolerances to every dimension. Excessively strict requirements can increase machining and inspection difficulty without improving the component's practical performance. Tolerances should reflect the actual design, connection and assembly requirements.
3. Specify Port Positions, Threads and Internal Passages
Port configuration is one of the most important technical details in hydraulic manifold block production. The manufacturer needs to know not only where each port is located but also its dimensions, thread type and relevant machining requirements.
The technical drawing or supporting documentation should specify:
Port positions and center-to-center distances
Port sizes and thread standards
Thread depth and other relevant dimensions
Counterbores and spot faces
Sealing-related machining features
Internal and external passage arrangements
Mounting and connection interfaces
For complex internal structures, sectional views and enlarged details can help clarify the design. If intersecting passages or hidden features cannot be understood from standard projections, additional technical information may be necessary.
A port can appear correctly positioned in an overall view while still lacking important information about thread depth or machining details. These omissions should be resolved before production rather than left to interpretation.
Drawing revision control is particularly important when the hydraulic circuit changes during equipment development. Customers should ensure that the manufacturer receives the latest approved version, especially when port positions or connection specifications have been modified.
4. Confirm the Material Grade Before Production
Material selection influences machining requirements and the suitability of the finished component for its intended application. A general description such as steel, iron or aluminum is often insufficient for custom manufacturing.
MAYTAG works with several material groups for hydraulic manifold blocks and related precision-machined components, including ductile iron, carbon and alloy steel, aluminum alloys and copper.
Available material grades include:
Material group Listed material grades Ductile iron QT500-7, QT450-12, QT450-10, QT400-18, QT400-15 Carbon and alloy steel 45#, 45# forgings, Q345B, Q355D, Q235B, 35#, 42CrMo, 9SMn28 Aluminum alloys AL6061-T6, AL6082-T6, AL7075-T6, AL5083-H112, AL6110-T6, LY12 Copper C18000 The exact grade should be stated in the drawing or material specification. If a particular standard or material documentation is required, the relevant reference should also be provided.
Material requirements should be confirmed during the quotation and technical review stages. This allows the manufacturer to assess material availability, machining feasibility and any applicable inspection arrangements before production begins.
The Non-standard valve block is manufactured according to the material and technical requirements agreed for each project. Final material selection should therefore be based on the customer's approved engineering documentation and application requirements.
5. Describe Surface Treatment and Finishing Requirements
Surface treatment can affect the final condition of a hydraulic component and should be defined before production. Buyers should specify the required treatment process and identify any surfaces that need special handling.
For example, some areas may require protection during finishing, while particular machined faces, threads or connection features may need to remain untreated. These requirements should be clearly marked on the drawing or included in the accompanying technical specification.
It is also useful to distinguish between appearance requirements and functional requirements. A surface appearance specification does not automatically define dimensional acceptance criteria. If both matter to the project, they should be stated separately.
MAYTAG's production workflow includes surface treatment, ultrasonic cleaning and ultrasonic washing. Providing clear finishing instructions helps coordinate these operations with machining and final inspection.
6. Define Dimensional Inspection and Acceptance Criteria
A completed valve block needs to be checked against the agreed technical requirements. Machining to programmed dimensions is only one part of the process; inspection helps determine whether the finished component meets the drawing specifications.
Customers should identify which features require measurement records or particular inspection attention. Depending on the design, these may include:
Overall dimensions and critical machining surfaces
Mounting hole positions and diameters
Port locations and threaded features
Geometric tolerances
Material verification requirements
Surface treatment acceptance criteria
Visual inspection requirements
Special documentation or reporting requirements
Coordinate measuring machine (CMM) inspection can support dimensional verification of selected features against the engineering drawing. The inspection plan should be based on the customer's specified tolerances and agreed measurement criteria.
MAYTAG incorporates CMM inspection into its manufacturing workflow. This is supported by raw material inspection, CNC machining, manual deburring, visual inspection, thermal deburring, further visual inspection, ultrasonic cleaning, surface treatment, ultrasonic washing and final inspection.
Clearly identifying critical features before production helps establish which dimensions and conditions need to be checked at different stages.
7. Control Drawing Revisions and Technical Documents
Custom hydraulic components may undergo several design changes before the final configuration is approved. A modification to a port location, material grade or mounting dimension can affect the machining route and inspection requirements.
For this reason, every drawing should carry a drawing number, revision identifier and issue date. When a new version is released, the customer should clearly state which earlier version it replaces.
A complete project document package may include:
Approved 2D engineering drawings
3D models, where available
Material specifications
Hydraulic circuit diagrams
Surface treatment instructions
Inspection requirements
Relevant assembly drawings
Technical notes covering special features
If the 2D drawing and 3D model contain conflicting information, the customer should clarify which document takes priority. Before production begins, both parties should confirm that they are working from the same approved technical data.
This is especially important for repeat orders, where outdated drawings could otherwise be used unintentionally.
8. Use a Pre-Production Checklist
Before requesting a quotation or releasing a custom valve block for production, buyers can review the following points:
Overall dimensions and component geometry are fully defined.
Critical dimensions and tolerances are clearly marked.
Mounting holes, ports and threaded features are specified.
Internal passages are explained through suitable views or supporting documents.
Material grades and relevant standards are confirmed.
Surface treatment and finishing requirements are included.
Inspection criteria and special quality requirements are identified.
Drawing numbers, revision levels and issue dates are consistent.
Related 3D models and assembly information are provided where necessary.
If certain details are still under development, they should be identified as pending rather than left ambiguous. This gives the manufacturer an opportunity to review the available information and request clarification before production planning is finalized.
How MAYTAG Organizes Custom Valve Block Manufacturing
A clear drawing package provides the foundation for manufacturing, but production capability and process management also matter when choosing a machining partner.
MAYTAG WUXI PRECISION MACHINERY CO., LTD. was founded in China in 2011 as a family-owned company specializing in the precision machining of hydraulic manifold blocks. Its manufacturing facility is located in Meicun Industrial Park, Wuxi New District, covering approximately 2,700 m² and supported by a team of more than 50 employees.
The company's development includes several manufacturing and management milestones:
2011: MAYTAG WUXI PRECISION MACHINERY CO., LTD. was established.
2015: ISO 9001 certification was obtained.
2017: Lean Manufacturing was introduced, alongside a company relocation.
2018: Digital factory implementation began.
2021: Intelligent Manufacturing Standardization was advanced.
These developments reflect an ongoing focus on production management and manufacturing improvement.
Its manufacturing process covers raw material inspection, CNC machining, CMM inspection, manual and thermal deburring, visual inspection, ultrasonic cleaning, surface treatment, ultrasonic washing, final inspection, packaging and delivery. After-sales support is also included as part of its customer service process.
The company serves customers in wind power, solar energy and other industrial sectors worldwide. Its drawing-based manufacturing approach allows project requirements to be evaluated according to individual component dimensions, material specifications, port arrangements and inspection criteria.
Preparing a Custom Valve Block Project for Production
The success of a custom machining project depends on communication between the equipment designer, purchasing team and manufacturer. Complete drawings help establish a common understanding of the component, while clearly defined tolerances and inspection requirements provide a basis for evaluating the finished part.
For hydraulic system developers, a Non-standard valve block should be treated as an application-specific component rather than a standard catalog item. Its port configuration, internal passages, mounting dimensions and material requirements need to match the approved system design.
With its focus on hydraulic manifold block machining, approximately 2,700 m² manufacturing facility and multi-stage production and inspection workflow, MAYTAG WUXI PRECISION MACHINERY CO., LTD. supports customers requiring components made to technical drawings.
Before submitting a project, buyers should prepare the latest approved drawings, material specifications, surface treatment instructions and critical inspection requirements. This provides a clearer starting point for manufacturing evaluation and helps align machining, quality checks and final delivery with the intended application.
http://www.wuximaytag.com
WUXI MAYTAG PRECISION MACHINERY CO.,LTD -
