2026-11-24 at 4:02 pm #18587
As electric vehicles continue to develop, their electrical systems are being designed to support more than basic driving functions. External power supply is becoming a useful feature in various EV applications, allowing vehicles to provide electricity to compatible equipment and accessories. This creates demand for reliable vehicle outlet sockets that can be integrated into the vehicle's electrical system.
For EV manufacturers and component buyers, a vehicle outlet socket is not simply a connection point. It needs to match the vehicle's electrical output, installation structure, and operating environment. Choosing a suitable component early in the development process can help simplify integration and support consistent performance.
Zhangjiagang UCHEN New Energy Technology Co., Ltd., also known as Youcheng Technology (stock code: 873087), focuses on the development and market promotion of high-performance charging products for new energy vehicles. Under its DUOSIDA brand, the company offers vehicle outlet sockets and a wider range of EV charging and electrical connection products.
Vehicle Outlet Sockets: A Practical Interface for EV Power Supply
A vehicle outlet socket provides an external electrical connection for compatible devices. In an EV power supply system, it works together with the vehicle's power source, conversion equipment, wiring, and circuit protection components.
Depending on the vehicle configuration, external power output can be useful in several applications:
Passenger electric vehicles: Providing a connection point for compatible external electrical devices.
Commercial EVs: Supporting auxiliary power requirements in selected vehicle configurations.
Utility vehicles: Connecting suitable tools and electrical equipment during field operations.
Special-purpose vehicles: Offering an additional power interface where external electricity is required.
The actual output capability depends on the vehicle's electrical design and power conversion system. Therefore, manufacturers should check the socket rating against the intended power supply rather than selecting a product based only on its physical appearance.
DUOSIDA YGB-105A: A 10A Vehicle Outlet Socket for EV Applications
The DUOSIDA YGB-105A Vehicle Outlet Socket is one of the product options available for vehicle outlet applications.
Its published specifications include a rated current of 10A and a rated voltage of 220V AC. The product references GB 1002 and GB 2099.1 standards and has an IPXXD protection classification.
Several specifications are worth considering during component evaluation:
Rated current: 10A
Rated voltage: 220V AC
Insulation resistance: At least 100MΩ under DC 500V testing
Voltage endurance: 1500V AC for 60 seconds
Leakage current: No greater than 3mA during the specified voltage endurance test
Mechanical lifespan: More than 10,000 cycles
Operating temperature: -30°C to +50°C
Housing: Black PC with a textured surface
Contact material: Copper alloy with pickling treatment
Rubber shell flammability rating: UL94 V-0
These details give engineering teams a clear starting point when comparing the socket with their vehicle requirements. The 10A and 220V AC ratings can be checked against the planned external output, while the operating temperature range provides a reference for evaluating the intended installation environment.
The mechanical lifespan of more than 10,000 cycles is also relevant for an outlet that may be connected and disconnected regularly. Actual service performance will depend on the installation, operating conditions, and use patterns.
YGB-107: Another Option for Vehicle Outlet Integration
The DUOSIDA YGB-107 Vehicle Outlet Socket is another model in the company's vehicle outlet socket range.
Its published specifications include:
Rated current of 10A
Rated voltage of 220V AC
Operating temperature from -30°C to +50°C
Mechanical lifespan exceeding 10,000 cycles
Insulation resistance of at least 100MΩ under DC 500V testing
Voltage endurance of 1500V AC for 60 seconds, with leakage current no greater than 3mA
Black PC housing with a textured surface
Copper alloy contact sleeve with pickling treatment
Both YGB-105A and YGB-107 have comparable published electrical and mechanical ratings. However, buyers should not assume that they are interchangeable in every application. Dimensions, mounting requirements, terminal arrangements, and other installation details should be confirmed with the supplier before final selection.
For vehicle manufacturers working on different platform configurations, having multiple product models to evaluate can make it easier to identify a suitable interface for a particular design.
What Should Buyers Check Before Choosing a Vehicle Outlet Socket?
When sourcing vehicle outlet sockets, procurement teams and engineering departments should evaluate the complete application rather than focusing on one specification.
1. Electrical compatibility
Confirm the required output voltage and current. The socket rating must be compatible with the vehicle's power conversion equipment and the intended external loads. A socket should never be selected without considering the complete electrical circuit.
2. Installation dimensions
Check the product drawings, mounting dimensions, terminal positions, and available installation space. These details are especially important when the outlet needs to fit into an existing vehicle body design.
3. Environmental requirements
Vehicle components may be exposed to temperature changes, vibration, dust, and moisture. The YGB-105A and YGB-107 list an operating temperature range of -30°C to +50°C. Their IPXXD classification should also be evaluated carefully. It does not represent a general waterproof or dustproof rating, so additional protection may be necessary depending on the installation location.
4. Contact and housing materials
Contact materials and housing characteristics are important considerations for electrical connection components. The YGB models use copper alloy contacts and a PC housing. Buyers can review these material specifications alongside their own requirements for mechanical durability and electrical performance.
5. Technical documentation and validation
Before placing an order for a vehicle development project, request the latest product drawings and technical documentation. Sample evaluation and system-level testing can help verify that the selected socket works with the vehicle's wiring, protection devices, and installation structure.
Youcheng Technology: EV Charging and Connection Product Supplier
For buyers sourcing vehicle outlet sockets, working with a supplier that focuses on new energy vehicle connection products can provide a broader product reference for related development projects.
Zhangjiagang UCHEN New Energy Technology Co., Ltd. (Youcheng Technology, stock code: 873087) is positioned as a charging solution service provider in China. The company focuses on developing and promoting high-performance charging products for new energy vehicles.
Its DUOSIDA product portfolio covers multiple EV charging and connection categories, including:
Vehicle outlet sockets
AC and DC charging connectors
NACS charging products
High-power charging (HPC) products
Charging adapters
High-voltage connectors
Electric locks
Charging stations and related accessories
This product range serves different connection requirements across EV charging equipment and vehicle electrical applications. Buyers can explore the DUOSIDA official website to review the available product categories and identify components relevant to their projects.
For vehicle outlet socket inquiries, the YGB-105A and YGB-107 product pages provide model-specific information for initial technical evaluation.
Building a More Practical EV Power Connection
Vehicle outlet sockets play a supporting but important role in modern EV electrical systems. They provide an accessible external connection point and need to work reliably with the vehicle's power supply design.
The DUOSIDA YGB-105A and YGB-107 offer 10A, 220V AC product options with published mechanical and electrical specifications for vehicle outlet applications. Their operating temperature range, contact material, housing material, and mechanical lifespan provide useful reference points for engineers and buyers.
For EV manufacturers, charging equipment developers, and component distributors, the right selection process should combine electrical compatibility, installation requirements, environmental evaluation, and supplier technical support.
Youcheng Technology continues to focus on EV charging and connection products through its DUOSIDA brand. For more information about vehicle outlet sockets and other EV connection components, visit DUOSIDA.
http://www.duosidaev.com
Zhangjiagang UCHEN New Energy Technology Co., Ltd. -
