Hydraulic Plane Hot Stamping Machine KH-500HPFR for Foil Stamping
  • #17181
      The Hydraulic plane hot stamping machine-1 KH-500HPFR is designed for manufacturers that need stable foil stamping with adjustable pressure, temperature, and dwell time. These factors directly affect foil adhesion, pattern clarity, and surface quality, especially when different substrates or larger stamping areas are involved.
      Instead of relying on fixed operating conditions, the KH-500HPFR combines hydraulic pressure, adjustable heating, PLC control, touchscreen operation, flexible worktable positioning, and automatic feeding. This makes it suitable for production environments where stamping requirements may change between orders.
      How Pressure, Temperature and Time Affect Stamping
      Hot stamping depends on the interaction of three main parameters. Pressure brings the foil and substrate into close contact, temperature activates the transfer layer, and stamping time determines how long heat and pressure are maintained.
      Insufficient pressure or temperature can result in incomplete transfer. Excessive pressure may leave unwanted impressions, while too much heat or dwell time can affect the substrate. Therefore, operators normally need to test and adjust these parameters according to the specific foil and material.
      The KH-500HPFR allows pressure, temperature, and time to be configured separately, helping users establish more suitable production conditions.
      Hydraulic Stamping with Up to 5T Pressure
      The machine uses a hydraulic stamping mechanism with a maximum pressure of 5T. This provides a practical option for applications where a relatively large stamping area requires consistent pressing force.
      For a new job, operators can begin with moderate pressure and increase it gradually after checking test samples. The goal is to achieve complete foil transfer without applying unnecessary force.
      The KH-500HPFR provides a 300 × 450 mm stamping area, a 350 × 500 mm worktable, a 100 mm stamp head stroke, and supports workpieces up to 200 mm high.
      These specifications allow the machine to accommodate different workpiece configurations and stamping requirements.
      Temperature Adjustment up to 280°C
      Different foils and substrates require different heating conditions. The KH-500HPFR offers a temperature range from ambient temperature to 280°C, allowing operators to adjust the heating process according to material characteristics.
      If the temperature is too low, the foil may not transfer properly. Excessive heat can affect the substrate or reduce the quality of the finished pattern.
      A practical approach is to use the foil supplier's recommended temperature as the starting point, then make controlled adjustments through sample testing.
      Finding the Right Stamping Time
      Dwell time determines how long the heated head remains in contact with the material. The appropriate time depends on the foil, substrate, temperature, stamping area, and production speed.
      A longer cycle does not necessarily provide better results. Operators should look for the shortest practical time that delivers consistent foil transfer.
      Several samples can be compared for adhesion, edge definition, surface appearance, and consistency. Once the suitable setting has been identified, it can be recorded for future production.
      Adjustable Worktable for Accurate Positioning
      Correct positioning is essential for precise foil stamping. The KH-500HPFR worktable can be adjusted in front-rear and left-right directions and can also be adjusted by angle.
      The worktable provides a 240 mm adjustable stroke, while the stamping head can be positioned for different workpiece heights.
      Before production begins, operators should confirm the workpiece position, table alignment, and head height. Correct mechanical positioning provides a better starting point for adjusting pressure, temperature, and time.
      PLC and Touchscreen Operation
      The KH-500HPFR uses PLC control and a touchscreen interface to organize machine operation and process settings.
      Different products may require different combinations of pressure, temperature, and dwell time. Programmable control makes these settings easier to manage and can reduce repeated manual adjustments.
      For recurring orders, manufacturers can record successful settings as production references. Customized PLC programs can also be developed according to customer requirements.
      Automatic Feeding and Safety Functions
      The machine includes automatic paper feeding and delivery, with feeding and delivery lengths adjustable according to production needs. This can help maintain consistent material movement during repeated stamping operations.
      A foot switch is also provided for convenient cycle control. An emergency stop device supports rapid response when abnormal conditions occur. Operators should always follow appropriate training and safety procedures when using hot stamping equipment.
      Main Specifications of KH-500HPFR
      Item Specification
      Stamping Area 300 × 450 mm
      Worktable 350 × 500 mm
      Table Stroke 240 mm
      Stamp Head Stroke 100 mm
      Max. Workpiece Height 200 mm
      Temperature Ambient–280°C
      Max. Pressure 5T
      Max. Speed Up to 900 pcs/hr
      Voltage 380V, 50Hz
      Air Pressure 6 bar
      Weight Approx. 380 kg
      Dimensions 950 × 1650 × 1900 mm
      Actual performance should be evaluated according to the foil, substrate, stamping pattern, production speed, and installation conditions.
      Practical Setup Process
      When introducing a new product, first install the selected foil and position the substrate correctly. Adjust the worktable and stamping head so the target area aligns with the heated head.
      Next, select an initial temperature and moderate pressure, then set a suitable stamping time. Produce several test samples and check foil coverage, adhesion, pattern definition, and substrate condition.
      If the transfer is incomplete, review temperature and pressure before making major changes to dwell time. If the material shows excessive heat exposure, reduce temperature or stamping time.
      After obtaining a stable result, record the settings for later production. This approach can reduce trial-and-error when the same product is manufactured again.
      What to Check Before Purchasing
      When comparing hydraulic hot stamping equipment, buyers should consider more than maximum pressure. Important factors include stamping dimensions, substrate type, foil specifications, temperature requirements, dwell time, workpiece height, worktable adjustment, production speed, feeding method, electrical conditions, compressed-air supply, and PLC customization.
      Testing actual production materials before purchase is recommended to confirm machine compatibility.
      About Shenzhen Kar Lee Keung Electronic Equipment Ltd.
      Shenzhen Kar Lee Keung Electronic Equipment Ltd. has more than 20 years of experience in equipment development, design, and manufacturing. Its product portfolio includes hot stamping machines, pad printing machines, screen printing machines, UV curing ovens, flame treatment equipment, and other specialized printing machinery.
      The company operates a production site of approximately 9,000 m², with more than 50 employees and over 500 partners according to the supplied information. Its manufacturing approach focuses on quality, safety, efficiency, customer service, and equipment development.
      Hydraulic hot stamping provides manufacturers with adjustable pressing force for different foil stamping requirements. Combined with controllable temperature and dwell time, it allows production parameters to be adapted to different substrates and applications.
      The Hydraulic plane hot stamping machine-1 KH-500HPFR combines 5T hydraulic pressure, a 300 × 450 mm stamping area, heating up to 280°C, PLC touchscreen control, adjustable worktable positioning, and automatic feeding.
      For manufacturers seeking a flexible flat foil stamping solution, the Hydraulic plane hot stamping machine-1 offers a practical platform for developing repeatable stamping processes across different products and production conditions.
      http://www.szklkelec.com
