IEC 62752:2024 Plug Temperature Control: What Changed for Mode 2 Chargers
  • #18141
      Published: October 2026  |  By Youdianbang Engineering Team  |  6 min read
      IEC 62752:2024, published in March 2024, added a construction requirement that no Mode 2 charger built to the previous edition can satisfy: the IC-CPD must monitor the temperature of the current-carrying parts inside the household plug and interrupt charging within 10 seconds once they reach 70 °C. Clause 8.3.1 states it, test 9.36 proves it, and neither existed in IEC 62752:2016+A1:2018.
      That is the whole IEC 62752 2024 plug temperature control requirement explained in one sentence. What it means commercially is less tidy. A large share of Mode 2 cables still sitting in distributor warehouses were certified between 2018 and 2023, when plug temperature was simply not part of the test schedule.
      Those units are not illegal and their CB certificates remain valid, but they were designed before the rule existed, and a missing sensor inside a moulded plug is invisible from outside. Youdianbang moulds temperature-sensing plugs and builds IC-CPD assemblies in-house, so our technical conversations with distributors usually start with one question: what do we ask the supplier for? This article is the answer.
      1. What Does the IEC 62752:2024 Plug Temperature Control Requirement Actually Say?
      The requirement is narrow, physical and measurable: sense the temperature of the plug's current-carrying parts, and open the circuit within 10 seconds of reaching 70 °C. Everything else in clause 8.3.1 exists to make that behaviour repeatable in production, not only in a laboratory sample.
      Three details separate compliant designs from datasheet-compliant ones:
      • Sensing location. The sensor must be thermally coupled to the L and N pins or their busbars, inside the plug body. An NTC on the IC-CPD circuit board, 1.5 m away behind a moulded strain relief, reads cable temperature — a damped proxy that can lag the pin by minutes.
      • Response window. Ten seconds is short enough to rule out heavy averaging. Firmware that smooths temperature over 60 or 120 seconds to avoid nuisance trips will not pass, which is why compliant designs run a fast absolute threshold alongside a slower trend filter.
      • Failure behaviour. An open or shorted NTC must not leave the charger running at full current with no protection. The device has to fail safe — stop charging, or drop to a restricted current — which means the sensor needs continuity diagnostics, not just an ADC reading.
      The edition also re-aligns residual current with IEC 61543:2022 and EMC with IEC 61851-21-2, so a genuine 2024 certificate covers more than the plug.
      Why the plug? Because that is where Mode 2 fails. Worn plating, oxide film, spring fatigue or a loose socket raise contact resistance at the pin; dissipated power climbs with the square of that resistance, the body softens, the insulation carbonises and tracking begins. An RCD never sees it, because there is no earth leakage until the failure is already thermal. The IEC 62752 clause 9.36 plug heating test procedure exists to reproduce exactly that condition and measure whether the electronics notice in time.
      NTC thermistor position inside a Mode 2 EV charger plug for IEC 62752:2024 plug temperature control
      It is worth being precise about what 9.36 is not. It is not a current-overload test, and a bimetal thermostat glued to the relay does not satisfy it. The test drives the plug's current-carrying parts to a specified temperature and measures how long the IC-CPD takes to open. A device that trips at 95 °C, or needs 40 seconds, fails. Which is why the IEC 62752 2024 plug temperature control requirement explained without the test behind it is so often misread.
      ✅ Bottom line: IEC 62752:2024 makes plug-level temperature sensing mandatory, with a 10-second window that rules out slow, indirect sensing.
      2. What Temperature Should an EV Charger Plug Cut Off At — and How Do You Verify It?
      The number is 70 °C measured at the plug's current-carrying parts, with the circuit opened inside 10 seconds. So the useful question is not what temperature should an EV charger plug cut off at, but whether the sensor can actually see that temperature at the pin. In practice that distinction decides which suppliers survive your incoming inspection.
      Two details matter before you discuss price. First, tiering: mature OEM designs warn or derate near 55–60 °C and trip at 70 °C. A single hard trip turns every marginal socket, extension lead or corroded campsite outlet into a nuisance failure, and nuisance failures generate returns. Second, rate of rise: a degrading contact climbs roughly 1 K per minute long before it reaches the threshold, so firmware watching dT/dt catches a loosening pin minutes earlier.
      On the purchasing side, the certificate is the weakest evidence available. A CB certificate to IEC 62752:2016+A1:2018 says nothing about clause 8.3.1, and a great many certificates still circulating are exactly that. Ask for five items instead, in writing — this is the list Youdianbang returns with every quotation:
      • The IEC 62752 clause 9.36 plug heating test procedure report for the exact plug variant and cable length you are ordering — not for a sister model.
      • An X-ray or cross-section photo showing where the NTC sits relative to the L and N pins.
      • Sensor specification and mounting: part number, beta value, and whether it is potted against the busbar, clamped or taped. Tape and thermal pads drift over thermal cycles; potting does not.
      • Declared behaviour on sensor open circuit and short circuit.
      • Contact plating thickness and plug body material — glass-filled PA66 rated V-0 behaves very differently from unfilled PP at 90 °C.
      You can screen incoming stock without a lab. Run a sample at 1.1× rated current for one hour in a 40 °C chamber, using a socket with deliberately degraded contacts, and watch the plug with a thermal camera. A compliant unit opens before the body passes roughly 90 °C; a pre-2024 unit keeps charging while the housing softens. Screening only — it detects the absence of protection, it does not replace 9.36.
      This is where the cost argument turns. At wholesale levels a sensing plug costs a few dollars more per unit; the gap in field returns is not a few dollars. Distributors who have paid for one batch of melted plugs stop negotiating on the plug and start asking for the test report. Ningbo Youdianbang New Energy Technology Co., Ltd. moulds its own sensing plugs and cords, so plug, cable and IC-CPD leave one factory — which is why we can show the sensor position instead of describing it.
      Custom work carries the same trap. A re-branded plug body with different wall thickness, or a new moulding gate, moves the thermal gradient — so the sensing path has to be re-qualified and the 9.36 evidence regenerated for the new tooling.
      ✅ Bottom line: Request the 9.36 report for the exact plug variant; a 2016-edition certificate proves nothing about plug temperature control.
      Frequently Asked Questions
      Q: What temperature should an EV charger plug cut off at?
      A: 70 °C on the current-carrying parts of the plug, with charging interrupted within 10 seconds under IEC 62752:2024. Field-proven designs usually start derating earlier, around 55–60 °C, so that an aged socket produces a reduced charge rate rather than a hard stop.
      Q: My supplier's IC-CPD already has a thermal cut-out inside the enclosure. Is that enough?
      A: No. The thermal path from a plug pin to the enclosure runs through the cable and takes minutes to respond, so a thermostat on the relay protects the electronics, not the plug. Clause 8.3.1 targets the plug's current-carrying parts, and that is where the sensor belongs.
      Q: Can I get the IEC 62752 2024 plug temperature control requirement explained for my own plug standard?
      A: Yes, and it matters, because national adoptions such as EN 62752 and BS EN 62752 can carry deviations, and the plug differs by market — Schuko, BS 1363, GB/T, or Argentina IRAM 2073. Send your target market and plug type and Youdianbang will map clause 8.3.1 to the plug you actually sell and share the matching 9.36 report. We also run OEM and ODM programmes for distributors who need their own branding.
      Next Step
      Auditing a Mode 2 range? Start with the plug. Send your plug standard, rated current and target market, and Youdianbang will return three things free of charge: the 9.36 report for the matching plug variant, a cross-section image of the NTC position, and a quotation with tooling and MOQ broken out separately.
      We supply wholesale and custom volumes direct from our Ningbo factory, including OEM and ODM builds. Start with the Mode 2 portable EV charger range or the temperature-sensing plug and power cord line, then send us the specification you are working to.
      http://www.ydbcharger.com
