2026-07-28 at 6:07 pm #16934
https://www.zxbypump.com/ihf-d-fluoroplastic-alloy-centrifugal-pump-short-stand.html
In industrial processes involving highly corrosive liquids, reliable fluid transfer equipment is essential for maintaining stable production operations.
The IHF-D fluoroplastic alloy centrifugal pump is developed based on the performance requirements of the IHF centrifugal pump series. It combines advanced non-metallic pump design technology with fluoroplastic lining materials to provide strong corrosion resistance, reliable operation, and long service life.
Designed for demanding chemical and industrial environments, the IHF-D centrifugal pump is suitable for transferring various corrosive media where conventional metal pumps may face performance limitations.
Structural Design of IHF-D Fluoroplastic Alloy Centrifugal Pump
The IHF-D fluoroplastic alloy centrifugal pump adopts a metal shell structure lined with polytetrafluoroethylene propylene (F46/PFA).
The pump body uses a fluoroplastic lining structure, while key components such as the pump cover, impeller, and shaft sleeve are manufactured with metal inserts wrapped and sintered with fluoroplastic materials.
This composite structure combines the mechanical strength of metal materials with the corrosion resistance advantages of fluoroplastics, providing reliable performance in harsh chemical environments.
Key Performance Advantages
Excellent Corrosion Resistance
The fluoroplastic lining provides strong resistance to various corrosive media, allowing the pump to handle demanding chemical transfer applications.
It is suitable for conveying strong corrosive liquids, including acids, alkalis, oxidizing agents, organic solvents, and reducing agents.
Good Wear Resistance and Mechanical Strength
The combination of fluoroplastic materials and metal reinforcement improves structural strength while maintaining wear resistance during continuous operation.
Stable Operation and Long Service Life
The pump features a reliable structure and stable operating performance, helping reduce maintenance requirements and extend service life.
Reliable Sealing Performance
The shaft seal can be equipped with external single-end mechanical seals or container-type double-end mechanical seals according to different operating requirements.
The sealing surface materials can be selected from options including:
Silicon carbide
Pressureless sintered silicon carbide
Ceramic
PTFE
Hard alloy
These choices help meet different requirements for corrosion resistance and operating conditions.
Suitable for Highly Corrosive Media Applications
The IHF-D fluoroplastic alloy centrifugal pump is designed for transporting strong corrosive liquids under demanding conditions.
It can be used for media such as:
Sulfuric acid
Hydrochloric acid
Acetic acid
Hydrofluoric acid
Nitric acid
Aqua regia
Strong alkali
Strong oxidizing agents
Organic solvents
Reducing agents
The operating temperature range is suitable for applications from -20℃ to 150℃.
Applications of IHF-D Fluoroplastic Alloy Centrifugal Pump
Due to its corrosion-resistant structure and reliable performance, the pump is widely used in industries requiring safe and stable chemical liquid transfer.
Typical applications include:
Petroleum industry
Chemical processing
Acid production
Alkali production
Metal smelting
Rare earth processing
Pesticide manufacturing
Dye production
Pharmaceutical production
Electroplating processes
Electrolysis systems
Pickling processes
Chemical foil production
Scientific research institutions
Defense-related industries
Reliable Pump Solution for Chemical and Industrial Processes
The IHF-D fluoroplastic alloy centrifugal pump combines fluoroplastic corrosion resistance with reinforced structural design to provide reliable performance in harsh industrial environments.
With advantages including strong corrosion resistance, stable operation, convenient maintenance, and long service life, the pump provides an effective solution for industries requiring dependable corrosive liquid transfer.
http://www.zxbypump.com
Jiangsu Zhenxing Pump Industry Co., Ltd. -
