Industrial Horizontal Type Washing Machine: How to Improve Laundry Efficiency and Choose the Right Model
  • #16952
      An industrial horizontal type washing machine is designed to handle large batches of textiles in commercial and industrial laundry facilities. Its horizontal drum uses controlled rotation to move fabrics through water and detergent, creating the mechanical action needed for effective washing.
      However, machine performance is not determined by capacity alone. Drum construction, textile movement, control accuracy, structural strength, and proper equipment selection all influence the final washing result. The right machine should also match the type of textiles being processed and the operating conditions of the laundry facility.
      How Does an Industrial Horizontal Type Washing Machine Work?
      The washing process is based on the repeated movement of textiles inside a rotating horizontal drum. As the drum turns, internal lifters raise the laundry and allow it to fall back into the wash solution. This continuous lifting and dropping action helps expose more of the fabric to water and detergent.
      Drum speed and loading level are important to this process. If the rotation speed is too low, textiles may simply slide along the bottom instead of tumbling effectively. Excessive speed can cause centrifugal force to press the load against the drum wall. Similarly, overloading reduces the free space needed for proper textile movement.
      The drum's dimensions, lifter design, and perforations also affect washing efficiency. A suitable industrial horizontal type washing machine should provide enough internal volume for the intended textile type, as towels, sheets, and heavy workwear can occupy very different amounts of space at the same dry weight. Smooth internal surfaces and properly finished perforations can also help minimize fabric snagging and unnecessary abrasion.
      What Determines the Quality of an Industrial Horizontal Type Washing Machine?
      Industrial laundry equipment must operate repeatedly under demanding conditions. Its long-term performance depends on the quality of the mechanical structure, washing controls, and components exposed to continuous use.
      Drum and Mechanical Construction
      The inner drum is commonly made from stainless steel because it is regularly exposed to water, detergent, and textile loads. Its internal surface should be smooth, with cleanly finished perforations and no sharp edges that could damage fabrics.
      The frame, shaft, bearings, and drive system must also support the weight of wet laundry during rotation. A rigid structure helps maintain stable drum alignment and can reduce excessive vibration, noise, and mechanical wear during operation.
      Washing Control and Maintenance
      Water level, temperature, washing time, and drum movement all affect cleaning performance. Hotel linen, towels, uniforms, and industrial workwear may require different process conditions, so adjustable controls allow operators to adapt the washing cycle to the load.
      Durability and maintenance are equally important. Bearings, seals, motors, transmission components, and door mechanisms are subject to repeated use. A reliable industrial horizontal type washing machine should provide dependable components while allowing commonly serviced parts to be inspected and maintained without unnecessary downtime.
      How to Select the Right Industrial Horizontal Type Washing Machine?
      The correct machine should be selected according to actual laundry requirements rather than simply choosing the model with the largest rated capacity. Batch size, textile characteristics, daily workload, and installation conditions should all be considered.
      Capacity and Textile Type
      Machine capacity is normally measured by the dry weight of textiles that can be processed per batch. However, dry weight does not always indicate the volume occupied inside the drum. Towels may require more space than sheets, while heavy workwear has different loading characteristics.
      An industrial horizontal type washing machine should therefore provide sufficient room for the actual textile mix. Overloading can restrict fabric movement and reduce washing effectiveness, while a machine that is too large for normal batches may frequently operate below its efficient load level.
      The main types of laundry being processed should also influence the selection. Facilities handling multiple textile categories may benefit from adjustable washing time, temperature, water level, and drum operation.
      Installation and Utility Requirements
      Before purchasing equipment, buyers should confirm that the installation area has enough space for the machine, loading and unloading operations, and routine maintenance. The site should also provide suitable access for equipment delivery and installation.
      Water supply and drainage capacity must match the machine's requirements. Insufficient water flow can extend filling times, while inadequate drainage may slow down the overall washing cycle. Electrical specifications, including voltage, frequency, and power, should also be checked in advance. If the machine includes a heating function, the available heating source must be compatible with its requirements.
      An industrial horizontal type washing machine uses horizontal drum rotation to provide the mechanical action required for processing large textile loads. Its washing performance depends on the interaction of drum design, textile movement, process control, and machine construction.
      When choosing equipment, buyers should look beyond nominal capacity and consider the actual batch size, textile types, daily production volume, and installation conditions. A properly matched machine can provide stable washing performance while supporting efficient operation and easier maintenance in demanding commercial and industrial laundry environments.
      https://www.tzbjlwash.com/industrial-horizontal-type-washing-machine-performance-quality-and-selection-guide.html
      https://www.tzbjlwash.com/Industrial-Horiontal-Type-Washing-Machine
      http://www.tzbjlwash.com
      Taizhou Baijieli Washing Technology Co.,Ltd.
