Ingersoll Rand Oil-Flooded Air Compressors RM185-315 for Industrial Applications
  • #17271
      Industrial facilities often depend on compressed air for automated production equipment, pneumatic tools, material handling systems, process machinery, and factory utilities. When air demand remains high for long operating periods, selecting the right compressor requires more than looking at motor power. Airflow, working pressure, electrical supply, cooling method, control technology, installation conditions, and maintenance requirements all need to be considered together.
      The Ingersoll Rand Oil-Flooded Air Compressors RM185-315 series is designed for high-demand industrial compressed air applications. The range covers 185 kW to 315 kW power ratings, with pressure options from 7.5 to 10 bar and airflow reaching up to 64 m³/min. Depending on the model and application, users can select fixed-speed or variable-demand configurations as well as air-cooled or water-cooled packages.
      RM185-315 Capacity Range
      A major consideration when selecting an industrial screw compressor is whether the equipment can provide sufficient airflow at the required operating pressure. The RM185-315 range provides several capacity levels, allowing engineers to select a model according to actual plant demand.
      For example, the RM185i delivers approximately 37 m³/min at 7.5 bar, 35.7 m³/min at 8.5 bar, and 32.4 m³/min at 10 bar. Moving to the RM220i, airflow increases to around 45.6 m³/min at 7.5 bar, 43.2 m³/min at 8.5 bar, and 38.8 m³/min at 10 bar.
      For higher-demand installations, the RM275i can provide approximately 56.5 m³/min at 7.5 bar, 53 m³/min at 8.5 bar, and 48 m³/min at 10 bar. The RM315i reaches approximately 64 m³/min at 7.5 bar, 60.8 m³/min at 8.5 bar, and 55 m³/min at 10 bar.
      These figures demonstrate why compressor selection should be based on the relationship between pressure and airflow rather than motor rating alone. As discharge pressure increases, available airflow generally decreases. A proper system calculation should therefore start with the plant's actual air consumption and pressure requirements.
      Variable-Demand and Fixed-Speed Options
      Industrial air consumption rarely remains constant throughout an entire production day. A factory may operate several production lines during one shift and only a portion of its equipment during another. Variable-demand compressor configurations can help address these changing requirements.
      The RM185n provides an approximate flow range of 12.1-37 m³/min at 7-10 bar, while the RM275n covers approximately 17.6-56.5 m³/min. The RM315n extends the range to approximately 2.0-63 m³/min at 7-10 bar.
      For facilities with fluctuating compressed air consumption, variable-speed drive technology can allow compressor output to respond more closely to demand. According to the supplied product information, advanced VSD control and system tuning can potentially reduce electricity consumption by around 15%-20%, depending on operating conditions and system design.
      This type of configuration may be considered for factories with multiple pneumatic loads, intermittent production cycles, automated equipment, or significant changes in air demand throughout the day.
      Screw Air-End and Drive System
      The air end is a key component in an oil-flooded screw compressor because its design has a direct influence on airflow and energy consumption.
      The RM series uses an updated screw rotor profile intended to improve compression efficiency. The supplied specifications indicate that the revised air-end design can achieve up to 16% higher efficiency, while the optimized rotor profile can increase air volume by approximately 14% compared with previous models.
      Another important feature is the integrated gear-drive arrangement. Helical gears are positioned on the air-end and motor shafts to help establish an appropriate operating speed. The direct-drive configuration avoids the transmission slip associated with conventional belt-driven systems and is designed to maintain consistent air-end speed.
      For industrial facilities where compressors operate for thousands of hours annually, even relatively small improvements in specific power consumption can have a meaningful effect on overall operating costs.
      Motor and Electrical Configuration
      Industrial plants have different electrical infrastructures, so compressor motor selection should be considered during the equipment planning stage.
      The RM185-315 range can be configured for 400V electrical systems using a three-phase, 50Hz, IP55, IE3 high-efficiency motor. Medium-voltage configurations are also available for 6kV and 10kV, three-phase, 50Hz applications, with IP23 and IE2 motor specifications according to the supplied information.
      This range of electrical options allows engineers to consider the compressor together with the site's existing power distribution system. Voltage, available electrical capacity, motor specifications, starting requirements, and installation conditions should all be reviewed before ordering.
      Physical dimensions and equipment weight should also be included in the plant layout. For example, RM275i and RM315i packages are approximately 3,850 mm long, 2,150 mm wide, and 2,240 mm high, although final dimensions and weight can vary according to voltage and cooling configuration.
      Air-Cooled and Water-Cooled Configurations
      Cooling is another important factor when installing a large industrial air compressor. The RM185-315 series provides both air-cooled and water-cooled configurations, allowing users to select a package according to plant conditions.
      Air-cooled compressors can be suitable where the compressor room has sufficient ventilation and heat dissipation. Water-cooled versions may be more appropriate for facilities that already have a suitable cooling-water system or where water-based heat removal fits the plant's infrastructure.
      Noise levels can also influence compressor-room planning. The supplied specifications indicate approximately 78 dB(A) for water-cooled models and around 79-80 dB(A) for air-cooled configurations.
      The compressor package is designed for installation on a sufficiently flat and spacious surface without requiring a dedicated special foundation. Nevertheless, the installation plan should provide adequate space for ventilation, maintenance, piping, electrical connections, lifting, and equipment access.
      Intelligent Control and Monitoring
      Large compressed air systems benefit from monitoring functions that allow operators to observe equipment status and operating conditions.
      For RM275-315i/n and RM185-220n configurations, the Luminance Series Controller provides an operating interface with a 10.1-inch high-resolution touchscreen. The controller also incorporates IoT functionality and supports communication through Modbus RTU and an RS485 serial connection.
      Its isolated design is intended to improve resistance to electrical interference, which can be useful in industrial environments containing motors, drives, switching equipment, and other electrical devices.
      Access to operating information, alarms, and system status can help maintenance personnel identify abnormal operating conditions and coordinate compressor performance with the wider compressed air network.
      Maintenance and Operating Conditions
      For large industrial compressors, maintenance accessibility can have an important impact on service efficiency. The RM185-315 package uses removable panels to provide access to internal components and facilitate routine service operations.
      Based on the supplied specifications, the air filter element and oil filter element have a stated replacement interval of 2,000 operating hours, while the oil separator element has a replacement interval of 4,000 operating hours under applicable conditions.
      The compressor package is also designed for ambient temperatures of up to 46°C. This can be relevant for manufacturing plants located in warm regions or compressor rooms where temperatures increase during continuous operation.
      A standard air-water separator is included to assist with condensate management. Cooling configuration, ventilation, filtration, and enclosure design work together to support stable operation in industrial environments.
      Choosing the Right RM185-315 Configuration
      Selecting a compressor should begin with the requirements of the compressed air system rather than a single equipment specification.
      Before purchasing, industrial users should evaluate:
      • Required airflow in m³/min
      • Working pressure in bar
      • Daily and annual operating hours
      • Variable or stable air demand
      • Available electrical voltage
      • Air-cooled or water-cooled requirements
      • Compressor-room ambient temperature
      • Installation space
      • Maintenance access
      • Control and communication requirements
      • Future production expansion
      For example, a plant with large fluctuations in air demand may need a different configuration from a facility with a stable 24-hour production load. Likewise, a site with medium-voltage electrical infrastructure may require a different motor configuration from a factory using standard low-voltage distribution.
      Working with Biaofang Compressor Shanghai Co., Ltd.
      Biaofang Compressor Shanghai Co., Ltd. is an independent third-party trading and technical service company specializing in air compressor sales and compressed air solutions. The company has approximately 20 years of sales and technical service experience and provides equipment selection, compressed air system design, consultation, and technical support.
      Its service team includes sales personnel and technical service engineers with experience in compressor applications. The company serves customers in various international markets, including Europe, North America, South America, Central Asia, Southeast Asia, the Middle East, and Africa.
      In addition to Ingersoll Rand equipment, Biaofang works with compressor brands and product lines including CompAir, Atlas Copco, Gardner Denver, GHH RAND, and ARO. This allows the company to support different compressed air requirements and provide technical assistance according to project conditions.
      What to Confirm Before Ordering
      For overseas industrial buyers, providing detailed project information can make compressor selection more efficient. A typical inquiry should include the required pressure, estimated air consumption, electrical voltage and frequency, cooling conditions, ambient temperature, installation location, operating schedule, and any communication or control requirements.
      Buyers should also confirm the exact model, rated airflow at the required pressure, motor configuration, cooling method, package dimensions, weight, applicable documentation, maintenance requirements, and delivery conditions.
      For projects with strict production requirements, it is also useful to evaluate the compressor together with dryers, filters, receivers, piping, condensate management, and other components of the compressed air system rather than treating the compressor as an isolated machine.
      The Ingersoll Rand Oil-Flooded Air Compressors RM185-315 series provides a broad capacity range for large manufacturing plants and other industrial facilities requiring substantial compressed air output. With 185-315 kW power ratings, 7.5-10 bar pressure options, airflow of up to approximately 64 m³/min, and multiple cooling, motor, and control configurations, the series can be configured around different plant requirements.
      The combination of an optimized screw air end, integrated drive system, VSD options, high-efficiency motor configurations, intelligent monitoring, and service-oriented design makes the range suitable for demanding continuous-duty compressed air applications.
      For companies planning a new compressed air installation or upgrading an existing system, the Ingersoll Rand Oil-Flooded Air Compressors RM185-315 should be specified according to actual airflow demand, pressure requirements, electrical infrastructure, cooling conditions, operating schedule, and available installation space. Biaofang Compressor Shanghai Co., Ltd. can provide equipment sourcing and technical support for buyers developing industrial compressed air solutions.
      http://www.air-aircompressors.com
