2025-05-06 at 4:27 pm #12552
Solar energy is a clean and sustainable energy source that has received increasing attention worldwide in recent years. As a leading solar technology manufacturer, Jinko Tiger solar panels launched by Jinko Solar have been widely recognized in the market for their high efficiency, durability and environmental protection. Proper installation and maintenance can not only ensure the best performance of solar panels, but also extend their service life. This guide will provide you with a detailed introduction to the installation and maintenance steps of Jinko Tiger solar panels to help you make better use of this clean energy.
1. Overview of Jinko Tiger Solar Panels
Jinko Tiger solar panels use the latest technology, mainly including high-efficiency monocrystalline silicon technology and advanced PERC (passivated emitter and contact technology) technology. Its core advantages lie in high conversion efficiency, long-term durability and strong resistance to bad weather. One of the biggest features of Jinko Tiger panels is its excellent low-light performance, which can effectively generate electricity on cloudy or cloudy days. In addition, Jinko Tiger solar panels also have a low temperature coefficient, which can maintain high power generation efficiency even in high temperature environments.
2. Preparation before installation
Before installing Jinko Tiger solar panels, some preparations must be made, including evaluating the installation site, selecting a suitable installation method, and ensuring the necessary tools and equipment.
2.1 Evaluate the installation site
Choosing a suitable installation site is key to ensuring the performance of solar panels. The following are the selection criteria for installation sites:
Sufficient sunlight: Solar panels need to receive sufficient sunlight to ensure power generation efficiency. Avoid installation in the shade or shaded areas.
Avoid obstacles: Make sure there are no buildings, trees or other structures around the panels that will block sunlight.
Suitable angle: The best installation angle of solar panels is usually matched with latitude. Generally speaking, the angle between the panel and the ground should be the angle of the local latitude plus 10 to 15 degrees, which can maximize the capture of sunlight.
Avoid excessive temperature: Although Jinko Tiger solar panels perform well in high temperatures, excessive temperatures will affect their efficiency, so try to avoid installing panels in extremely hot places.
2.2 Installation method selection
Depending on the installation environment, Jinko Tiger solar panels can choose different installation methods:
Roof installation: The most common installation method, suitable for the roofs of residential and commercial buildings.
Ground installation: If there is not enough space on the roof, you can choose ground installation. Ground installation requires additional brackets and is usually suitable for rural areas or areas with large open spaces.
Stand-alone bracket installation: suitable for buildings without roofs or places where solar panels need to be moved regularly.
3. Tools and equipment preparation
During the installation process, you will need some basic tools and equipment:
Bracket installation: According to the selected installation method, make sure that the material and size of the bracket meet the requirements of Jinko Tiger panels.
Electrical connection tools: cables, junction boxes, wire holders, etc.
Electrician tools: tools such as screwdrivers and electric drills are used to fix brackets and connect electrical equipment.
Safety equipment: Safety belts, helmets and other safety equipment are required when working at heights.
4. Jinko Tiger solar panel installation steps
The installation of Jinko Tiger solar panels involves multiple steps, including bracket installation, panel fixing, electrical wiring, etc. These steps will be described in detail below.
4.1 Bracket installation
First, you need to choose a suitable bracket according to the size of the panel and the installation environment. The bracket installation requires stability and can withstand the weight of the panel and external wind force. The specific steps are as follows:
Measurement and positioning: Determine the location of the mounting bracket and mark it according to the preset angle.
Mounting bracket: Use an electric drill to drill holes on the roof or ground and fix the bracket in place. If it is a rooftop installation, the bracket should be connected to the wooden or steel beams of the roof to ensure stability.
4.2 Installing solar panels
After the bracket is installed, the next step is to install the panel:
Fix the panel: Place the Jinko Tiger solar panel on the bracket and ensure that the panel is properly positioned and stable.
Connect the electrical interface: Use a special electrical tool to connect the panel's electrical interface to the battery pack or inverter. Make sure the connection is tight and prevent the wiring from loosening.
Wiring check: Check whether all wire connections are safe to avoid any short circuits or poor contact.
4.3 Electrical system connection
Solar panels need to convert DC power to AC power through an inverter, so when installing the electrical system, all equipment must be compatible.
Install the inverter: Select an inverter suitable for the Jinko Tiger solar panel and install it in a suitable location. The inverter is usually installed close to the battery pack.
Connect the battery pack: According to the design of the solar system, connect the output power of the panel to the battery pack through the inverter to ensure that the battery can charge and store energy.
Electrical inspection: After the installation is completed, conduct a comprehensive inspection of the electrical system to ensure that there are no loose cables or connectors.
4.4 System commissioning and startup
After the installation is completed, commission the system to ensure that the solar panel can work properly. Turn on the power and observe the output of the system. If the system does not work properly, check whether the electrical connections and the position of the panel are correct.
5. Maintenance of Jinko Tiger solar panels
In order to ensure the long-term stable operation of Jinko Tiger solar panels, regular maintenance is essential. Maintenance work can extend the service life of the panel and ensure its continued efficient power generation. The following are common maintenance measures for Jinko Tiger solar panels.
5.1 Regular cleaning
The surface of the panel is prone to accumulate dust, bird droppings or leaves, which affects the absorption of light and reduces the power generation efficiency. Regular cleaning of the panel is the key to maintaining efficient power generation. The cleaning steps are as follows:
Cleaning with soft cloth and water: Avoid wiping the surface of the panel with hard objects to avoid scratching the surface coating. Use soft cloth and clean water to clean the panel.
Cleaning frequency: In dusty areas, it can be cleaned once a month; in rainy areas, the cleaning frequency can be appropriately reduced.
5.2 Check electrical connections
Regularly check whether the electrical connections are tight to prevent loose or oxidized wiring. This is the key to ensuring the safe operation of the solar panel system.
Check connectors: Regularly check whether the cables and connectors are loose, corroded or damaged.
Test voltage: Use a voltmeter to detect the voltage of the panel and battery pack to ensure stable output.
5.3 Monitor system performance
Jinko Tiger solar panel inverters are usually equipped with a monitoring system that can help users monitor power generation in real time. Through the monitoring system, users can quickly detect system abnormalities and make repairs in time.
5.4 Check the stability of the bracket and panel
Regularly check the firmness of the bracket to ensure that there are no loose screws or corroded parts. In addition, check whether the panel has cracks or other physical damage. If damaged, it needs to be replaced in time.
Proper installation and regular maintenance are the key to ensuring the long-term and efficient operation of Jinko Tiger solar panels. By choosing a suitable installation site, following the installation steps, and performing regular inspections and maintenance, you can maximize the performance of your solar panels, save energy costs, and contribute to environmental protection. I hope this guide will provide you with a useful reference to help you smoothly install and maintain your Jinko Tiger solar panels.
http://www.janewenergy.com
JA TECH Co.,ltd. -
