2026-08-27 at 6:23 pm #17352
KC chain couplings are flexible shaft couplings designed to connect two rotating shafts and transmit mechanical power. Using a roller chain and sprockets, this type of chain coupling provides a practical solution for shaft-to-shaft power transmission in industrial machinery.
KC chain couplings are commonly considered for applications where torque transmission, flexible shaft connection, and straightforward mechanical construction are required. Different KC coupling configurations can be selected according to shaft dimensions, torque, operating speed, material, and equipment requirements.
Sambur Transmission Machinery TaiCang Co., Ltd. manufactures transmission components including KC chain couplings, roller chains, sprockets, gears, racks, synchronous pulleys, couplings, and torque limiters.
KC Roller Chain Coupling for Torque Transmission
A roller chain coupling uses two sprockets connected by a roller chain to transmit rotation from one shaft to another. The chain engages with the sprocket teeth on both sides, creating the mechanical connection between the driving shaft and driven shaft.
This design makes the roller chain coupling suitable for various mechanical power transmission applications where a flexible shaft connection is required.
For applications requiring higher torque transmission, coupling selection should be based on the actual torque generated by the machinery. Operating speed, shaft diameter, bore size, and working conditions should also be considered.
The specified Sambur KC chain coupling configuration is available with a 500 N·m rated torque and a maximum speed of 2000 RPM.
KC 6022, 6018, and 8020 Chain Coupling Configurations
When selecting among KC coupling configurations, customers should confirm the required shaft dimensions, coupling dimensions, torque requirements, and operating speed of their equipment.
Rather than selecting a coupling based only on the model number, it is important to match the coupling configuration with the actual mechanical transmission requirements.
For application-specific requirements, Sambur can provide product information and support OEM, ODM, and OBM requirements.
Chain Coupling Shaft Connection
A chain coupling provides a mechanical connection between two shafts through sprockets and a roller chain.
One sprocket is mounted on the driving shaft and another on the driven shaft. The roller chain engages with the teeth of both sprockets and transfers rotational movement between the two shafts.
The shaft diameter and bore size are therefore important factors when selecting a suitable chain coupling.
A 20 mm bore diameter is available for the specified Sambur KC chain coupling configuration. Shaft dimensions should be confirmed before ordering to ensure compatibility with the equipment.
Key Features of KC Chain Couplings
Roller Chain and Sprocket Design
KC chain couplings use a roller chain and sprocket structure to transmit rotational power between connected shafts.
The sprocket teeth engage with the roller chain, allowing the coupling to transfer mechanical rotation from one shaft to another.
Flexible Shaft Coupling
A KC chain coupling is a flexible coupling designed for shaft-to-shaft power transmission. It provides an alternative to rigid coupling arrangements where a flexible coupling design is required.
500 N·m Rated Torque
Torque capacity is an important consideration when selecting a chain coupling for industrial machinery.
The specified Sambur KC chain coupling configuration provides 500 N·m rated torque, making this parameter important when evaluating the coupling for a particular transmission application.
Maximum Speed of 2000 RPM
The specified configuration supports a maximum speed of 2000 RPM.
The actual operating speed of the connected machinery should be checked when selecting the appropriate coupling.
Steel and Stainless Steel Options
KC chain couplings are available in steel and stainless steel options.
The appropriate material can be selected according to mechanical requirements and operating conditions.
OEM, ODM, and OBM
Sambur supports OEM, ODM, and OBM requirements for KC chain couplings.
This provides flexibility for machinery manufacturers, distributors, and industrial buyers who require specific coupling configurations or customized transmission component solutions.
KC Chain Coupling Applications
KC chain couplings can be used for shaft connection and mechanical power transmission in different industrial environments.
Application areas include:
Building material machinery
Machinery repair equipment
Manufacturing plants
Printing machinery
Industrial transmission equipment
Mechanical power transmission systems
The appropriate KC chain coupling should be selected according to the torque, operating speed, shaft diameter, bore size, and working conditions of the equipment.
How to Select a KC Chain Coupling?
Several factors should be evaluated before selecting a KC chain coupling.
Torque
Check the required transmission torque of the machinery and select a coupling with appropriate torque capacity.
A 500 N·m rated torque configuration is available from Sambur.
Speed
Confirm the normal operating speed of the equipment and compare it with the coupling's maximum allowable speed.
The specified KC coupling configuration has a 2000 RPM maximum speed.
Shaft Diameter and Bore
The shaft diameter must match the coupling bore requirements.
A 20 mm bore diameter configuration is available.
Material
Steel and stainless steel options are available. Material selection should take into account the mechanical requirements and operating environment.
For KC coupling references such as 6022, 6018, and 8020, customers should confirm the required configuration and dimensions before ordering.
Why Choose Sambur for KC Chain Couplings?
Sambur Transmission Machinery TaiCang Co., Ltd. specializes in transmission components and has more than 10 years of experience in this industry.
The company manufactures a broad range of mechanical transmission products, including roller chains, sprockets, gears, racks, synchronous pulleys, couplings, and torque limiters.
Sambur has production equipment, manufacturing technology, and a testing system for transmission components. The company has also passed ISO 9001 certification.
Its products are sold in more than ten provinces and cities in China and exported to the United States, Japan, and Southeast Asia.
For customers sourcing KC chain couplings, roller chain couplings, shaft couplings, or other transmission components, Sambur provides manufacturing experience together with OEM, ODM, and OBM support.
KC Chain Coupling Manufacturer and Supplier
Sambur provides transmission components for machinery manufacturers, distributors, and industrial users in domestic and overseas markets.
For a KC chain coupling application, customers can provide information such as:
Shaft diameter
Required bore size
Operating speed
Required torque
Material requirements
Equipment application
These details help determine whether a specific KC chain coupling configuration is suitable for the intended transmission system.
https://www.tcsambur.com/
Sambur Transmission Machinery TaiCang Co.,Ltd. -
