Keeping Bus Air Tanks Secure: Mounting Components, Inspection Points and Replacement Considerations
  • #18627
      A bus compressed-air system depends on more than the air tanks themselves. The supporting brackets, fixing straps, positioning blocks, and fasteners all contribute to keeping the tanks securely installed while the vehicle is moving. Continuous vibration, road shocks, braking cycles, and changing operating temperatures can gradually affect these mounting components.
      A loose strap or deformed bracket may not immediately cause an obvious system failure, but it can lead to unwanted movement, mounting stress, or repeated maintenance issues. For technicians working on bus air systems, inspecting the complete installation is therefore just as important as checking the tank body.
      The ZK6127 25L Air Tank and 20L Air Tank configuration provides a useful example of how different tank capacities and mounting accessories work together. Understanding the component specifications can help maintenance teams identify suitable replacements and avoid ordering parts based only on appearance.
      1. Understanding the ZK6127 Air Tank Arrangement
      The first step in replacement work is confirming the number, capacity, and part numbers of the tanks installed on the vehicle.
      The listed ZK6127 configuration includes:
      Component Part Number Specification Quantity Per Bus
      25L air tank 3513-00019 φ246, Q195, without bracket 4
      20L air tank 3513-00012 φ246, Q195, without bracket 1
      This means the vehicle uses four 25L tanks and one 20L tank. Both versions have the same listed diameter of φ246, but their capacities and part numbers differ.
      That distinction matters when sourcing replacements. Two tanks may look similar from the outside while still having different specifications. Buyers should verify the original part number and capacity rather than relying on visual comparison alone.
      Another detail is that the tanks are supplied without brackets. The associated mounting hardware must therefore be identified separately when planning a replacement.
      Before removing an existing tank, technicians should compare its position and installation arrangement with the vehicle's parts documentation. The relevant air circuit must also be safely depressurized according to the vehicle manufacturer's maintenance procedures before work begins.
      2. Different Bracket Designs Serve Different Installation Positions
      Air tank brackets provide structural support and help maintain the intended mounting position. Because the available space and mounting geometry can vary across the vehicle, the ZK6127 parts list includes several bracket designs.
      The listed components include:
      • 3513-00232: L-shaped air tank bracket, 100 mm long.
      • 3513-00372: Straight angle steel bracket, 812.5 mm long, supplied as a two-unit set.
      • 3513-00263: U-shaped air tank bracket, 180 mm long.
      • 3513-00373: Straight angle steel bracket, 360 mm long, process 20, supplied as a two-unit set.
      • 3513-00099: Irregular-shaped air tank bracket, 111 mm long, for a φ246 air tank.
      These parts should not be treated as interchangeable simply because they are all described as air tank brackets.
      During maintenance, inspect each bracket for bending, cracks, corrosion, damaged welds, and signs of contact with nearby vehicle structures. Mounting holes and welded joints deserve particular attention because they may experience repeated mechanical stress.
      A deformed bracket should be assessed against the original dimensions and the vehicle manufacturer's repair requirements. Straightening a damaged part without checking its structural condition may not restore the intended mounting performance.
      When ordering replacements, confirm the bracket's shape, length, and installation position. For example, the 812.5 mm straight angle steel bracket is a different component from the 360 mm version, even though both have a similar general form.
      3. Fixing Straps and Positioning Blocks: Small Parts with an Important Job
      Brackets support the tank, while fixing straps and positioning components help keep it in the correct position.
      The ZK6127 configuration identifies air tank fixing strap 3513-00543, designed for a φ246 air tank suspension arrangement. According to the supplied parts information, it replaces the earlier part number 3513-00034.
      A fixing strap should be checked for corrosion, cracks, deformation, loose connections, and signs that the tank has been moving against its mounting structure. If it can no longer maintain the required installation condition, the correct replacement should be selected.
      Other related mounting components include:
      Part Number Component
      3513-00015 Fixing block
      3513-00016 Positioning block
      3513-00014 Hex socket head cap screw
      These components work as part of the same mounting arrangement. A worn positioning block may allow the tank to shift, while a damaged fixing block or loose screw can affect the reliability of the installation.
      During replacement, check for missing hardware, damaged threads, and signs of fastener loosening. Use the specified components and tightening requirements rather than improvised substitutes.
      4. Why the φ246 Diameter Matters When Selecting Mounting Parts
      The φ246 specification is an important reference when matching the tanks with their mounting accessories.
      Both the 25L tank and the 20L tank in this ZK6127 parts list have a listed diameter of φ246. The fixing strap 3513-00543 is also specified for a φ246 tank suspension application.
      A mounting strap that does not match the tank's external profile may sit incorrectly or create uneven contact. This can affect how securely the tank is held in position.
      Before purchasing replacement components, confirm the following details:
      • Tank part number and nominal capacity.
      • Specified external diameter.
      • Fixing strap part number and application.
      • Bracket shape, length, and mounting position.
      • Fixing and positioning block arrangement.
      • Fastener specifications.
      Even when two tanks share the same diameter, the complete installation should still be checked against the original vehicle parts documentation. Keeping these details in maintenance records can also make future purchasing more efficient.
      5. Do Not Overlook Drain Valves and Sealing Parts
      Air tank maintenance involves more than checking the external mounting structure. Drainage and sealing components also deserve regular inspection.
      Moisture can accumulate inside compressed-air equipment during normal operation. Following the vehicle manufacturer's drainage schedule helps manage accumulated moisture and maintain the condition of the air system.
      The supplied ZK6127 parts list includes manual drain valve 3513-00013M, which replaces the earlier part number 3513-00013.
      When inspecting the valve, look for air leakage, damaged threads, corrosion, blockage, or abnormal opening and closing behavior. If the valve is defective, confirm the updated part number before ordering a replacement.
      The parts list also identifies two M22 sealing components:
      • 3506-00159: M22 sealing ring.
      • 3506-00156: M22 O-ring seal.
      Although both are associated with M22 connections, they should not automatically be treated as identical. Their profiles, sealing positions, and applications may differ. Confirm the correct part number and dimensions before installation.
      If leakage appears around a drain valve or connection, inspect the sealing surface and related components to identify the cause. Simply tightening a connection without checking for damaged seals or threads may not resolve the problem.
      All work on compressed-air equipment should follow the vehicle manufacturer's safety procedures.
      6. A Practical Air Tank Inspection Checklist
      A consistent inspection routine helps maintenance teams cover both the tank body and its supporting components.
      Inspection Area Items to Examine Recommended Action
      Air tank body Corrosion, deformation, visible damage Assess against replacement criteria
      Mounting brackets Bending, cracks, damaged welds, corrosion Replace damaged brackets
      Fixing straps Wear, deformation, loose connections Confirm φ246 compatibility
      Fixing blocks Cracks, deformation, incorrect position Check part number and condition
      Positioning blocks Wear, displacement, missing parts Restore the specified arrangement
      Fasteners Missing screws, damaged threads, looseness Replace or tighten to specification
      Drain valve Leakage, blockage, abnormal operation Inspect or replace as required
      Sealing components Wear, damage, leakage Verify M22 specification and application
      For fleet maintenance departments, recording the vehicle identification, inspected part numbers, replacement quantities, and abnormal findings can be helpful. These records provide a reference for future repairs and allow purchasing staff to prepare the correct components in advance.
      7. Common Purchasing Mistakes to Avoid
      One common problem in bus parts procurement is using broad descriptions such as “air tank bracket” or “tank fixing strap” without checking the exact application.
      The ZK6127 arrangement contains several bracket shapes, different lengths, and multiple supporting components. A general product description may not be enough to identify the correct replacement.
      There are also two part number updates in the supplied information:
      Previous Part Number Updated Part Number Component
      3513-00034 3513-00543 Air tank fixing strap
      3513-00013 3513-00013M Manual drain valve
      Purchasing teams should use the updated numbers when preparing new orders while keeping the older numbers for cross-checking historical maintenance records.
      For parts that are difficult to identify, providing the vehicle model, original part number, required quantity, and photographs of the installed component can help the supplier verify the application.
      It is also worth checking the supporting hardware whenever a tank is replaced. A tank-only order may leave damaged straps, brackets, or positioning components unaddressed, potentially creating the need for another maintenance job.
      The ZK6127 25L Air Tank and 20L Air Tank should therefore be considered alongside their associated brackets, fixing straps, blocks, fasteners, drain valves, and seals when planning replacement work.
      8. Sourcing Chinese Bus Air System Parts More Efficiently
      For bus operators, repair workshops, and overseas parts distributors, accurate identification is only one part of the purchasing process. Coordinating multiple part numbers, checking applications, and arranging international transportation can also take considerable time.
      Founded in 2000 and based in Guangzhou, Guangzhou Hangji Trading Company Limited specializes in spare parts for Chinese buses. Its one-stop purchasing service covers a broad range of bus accessories and replacement components.
      The company has more than 25 years of industry experience, a warehouse and shop area exceeding 5,000 square meters, and a team of over 30 professionals. Its product sourcing network includes more than 30,000 SKUs, helping customers consolidate different purchasing requirements through one supplier.
      Hangji's core suppliers hold IATF 16949:2016 and ISO 9001:2015 certifications. The company also acts as an authorized agent for various international brands.
      For overseas buyers, logistics support includes express delivery, air freight, sea freight, and combined shipments. Its professional mechanics can also assist with technical questions and product identification, which is useful when customers need to verify less familiar components.
      With customers in more than 40 overseas countries, Hangji supports bus parts distributors, workshops, and fleet maintenance businesses looking for a more coordinated approach to sourcing Chinese bus spare parts.
      Air tank reliability depends not only on the tank itself but also on the condition and compatibility of its mounting and supporting components. Brackets, fixing straps, positioning blocks, fasteners, drain valves, and sealing parts all deserve attention during routine inspection and replacement work.
      For the ZK6127 configuration, the key details include four 25L tanks, one 20L tank, a shared listed diameter of φ246, several different bracket dimensions, and updated part numbers for the fixing strap and manual drain valve.
      Checking these specifications before ordering can help reduce incorrect purchases and unnecessary installation delays. For buyers sourcing the ZK6127 25L Air Tank and 20L Air Tank and other Chinese bus replacement components, Guangzhou Hangji Trading Company Limited provides product sourcing, technical purchasing assistance, and international shipping coordination.
      http://www.hjbuspart.com
