2026-02-11 at 2:18 pm #15322
The introduction of mold water channel cleaning machines has significantly reduced the labor intensity involved in cleaning mold cooling channels. By replacing manual cleaning with mechanized operation, these machines help manufacturers lower labor costs, improve efficiency, and reduce overall maintenance expenses.
Although mold water channel cleaning machines are generally easy to operate, improper use or ignoring standard procedures may lead to unsatisfactory cleaning results or even equipment damage. To ensure safe operation and optimal performance, several important precautions should be followed during normal use.
Perform Leak Testing and Pressure Testing Before Cleaning
Before starting any cleaning operation, it is essential to carry out leak testing and pressure testing. This step ensures that all connections between the machine and the mold water channels are properly sealed.
Only after confirming that there is no leakage or abnormal pressure loss should the cleaning process begin. Proper testing not only guarantees cleaning effectiveness but also helps prevent safety risks during operation.
Enter the Correct Mold Identification Number
Before each cleaning cycle, operators should input the corresponding mold identification number into the system. This practice facilitates accurate record-keeping and allows for systematic tracking of cleaning history for each mold.
Over time, these records can support better maintenance planning, help analyze blockage frequency, and improve overall mold management efficiency.
Ensure Correct Power Connection
When connecting the mold water channel cleaning machine to a power source, it is critical to match the machine’s rated voltage and connect the power supply correctly. Special attention should be paid to avoiding reverse connections or wiring errors.
Incorrect power connections can lead to unstable operation, electrical faults, or serious damage to the equipment. Verifying electrical parameters before startup is a necessary safety measure.
Pay Attention to Procurement, Installation, and Pre-Use Preparation
Proper performance of a mold water channel cleaning machine begins with correct procurement and installation. The selected equipment should match actual production requirements, and installation should follow the manufacturer’s technical guidelines.
Before using the machine, operators are advised to carefully read the user manual and fully understand the operating procedures and safety instructions. This helps minimize operational errors and extends the service life of both the equipment and the molds.
Seek Professional After-Sales Support When Needed
If any questions arise during use, maintenance, or troubleshooting, users should promptly contact professional after-sales service rather than attempting unauthorized adjustments or disassembly.
Guangzhou Yizai Intelligent Technology Co., Ltd. provides dedicated after-sales support to assist customers in resolving technical issues and ensuring efficient, safe operation of mold water channel cleaning machines.
Mold water channel cleaning machines play an important role in improving mold maintenance efficiency and reducing operational costs. However, only through standardized operation, careful attention to detail, and proper equipment management can their full benefits be realized. By following the recommended procedures and usage precautions, manufacturers can achieve more reliable cleaning results and long-term operational stability.
http://www.moldcleanmachine.com
Guangzhou Yizai Intelligent Technology Co., Ltd -
