KF3N8-500 Female Quick Coupling: 3/8-18NPT Connection for Precision Fluid Systems
  • #17267
      In fluid handling equipment, quick couplings play an important role in making tubing connections easier to assemble, service, and configure. Although compact in size, a coupling must match the mechanical interface, material requirements, sealing method, and fluid conditions of the complete system. For OEMs and equipment designers, selecting the right configuration at the beginning can help simplify assembly and reduce compatibility issues.
      KF3N8-500 is a B0 Series female quick coupling featuring a 3/8-18NPT threaded connection. Manufactured from POM and supplied in white, it is designed for applications requiring a lightweight engineering-plastic connection without an integrated shut-off valve. Its defined thread, material, and coupling configuration make it suitable for equipment manufacturers looking for a practical component for precision fluid connection systems.
      Understanding the KF3N8-500 Quick Coupling
      The specifications of KF3N8-500 provide several important selection points. This model belongs to the quick coupling range and adopts a female B0 Series configuration. It uses POM as the primary material, has a 3/8-18NPT threaded end, and is designed without a shut-off valve.
      The female interface is intended to connect with a compatible male coupling. Meanwhile, the threaded end provides a defined connection standard for integration with corresponding fluid-control components. POM construction offers a lightweight alternative to metal components in applications where engineering plastics meet the required operating conditions.
      The non-shut-off configuration is equally significant. Unlike quick couplings with an internal valve, KF3N8-500 does not automatically isolate the fluid path when disconnected. Therefore, it is best suited to systems where flow control or isolation is provided elsewhere.
      Why 3/8-18NPT Thread Compatibility Matters
      Thread specification is one of the first details that should be confirmed when purchasing a quick coupling. Even when two components appear similar in size, different thread standards can prevent direct assembly.
      The 3/8-18NPT specification defines the nominal size and NPT thread configuration of KF3N8-500. For equipment designed around compatible NPT connections, this provides a straightforward reference for component selection.
      For OEM projects, confirming the thread type before production can reduce the need for additional adapters and help maintain a consistent bill of materials. Engineers should also verify the specifications of the mating connector and any connected tubing, fittings, or valves before finalizing the fluid path.
      POM Material for Lightweight Fluid Connections
      Material selection can have a significant influence on connector performance. KF3N8-500 uses polyoxymethylene, commonly known as POM, an engineering thermoplastic widely used for precision components.
      POM is valued in many technical applications for its dimensional stability, mechanical characteristics, and suitability for precision manufacturing. In a quick coupling, these properties can support a consistent connection while keeping component weight relatively low.
      However, material selection should always be considered in relation to the actual application. Fluid type, operating temperature, pressure, chemical exposure, and surrounding environmental conditions should be evaluated before the coupling is qualified for a specific system.
      The standard white appearance of KF3N8-500 can also provide a clean and consistent look when incorporated into laboratory, medical, analytical, or other precision equipment.
      Female Design Without an Internal Shut-Off Valve
      The configuration of a quick coupling determines how it functions within a larger fluid circuit. KF3N8-500 is designed as a female connector without a built-in shut-off mechanism.
      This configuration can be advantageous in systems where fluid isolation is managed by a separate valve. By separating the connection function from the flow-control function, equipment designers can select each component according to the requirements of the overall system.
      For applications that require automatic fluid interruption when the coupling is disconnected, a shut-off coupling should instead be considered. The choice should therefore be based on how the complete fluid circuit is designed rather than on the coupling itself.
      Configuration Options for Different Equipment Designs
      Fluid-control equipment rarely has identical connection requirements across every model. Tubing direction, material compatibility, sealing requirements, available installation space, and connection standards can vary significantly between machines.
      The wider coupling selection system offers different configurations, including male and female types, shut-off and non-shut-off designs, straight and 90-degree elbow structures, multiple thread options, different construction materials, colors, and sealing materials.
      Depending on the selected configuration, material options can include POM, SUS316, PEEK, and PP. Color choices may include natural, black, white, orange, red, green, blue, gray, and yellow. O-ring materials can also vary, including EPDM, FFKM, FKM, and NBR.
      This type of configuration flexibility can be useful for OEM manufacturers developing different equipment platforms. Rather than redesigning the entire fluid connection system for every application, engineers can evaluate connector specifications based on the requirements of each product.
      Potential Applications in Precision Fluid Equipment
      Quick couplings are commonly used in equipment where fluid lines need to be assembled, disconnected, replaced, or arranged in modular configurations. Their suitability depends on the selected material, connection type, sealing system, pressure and temperature conditions, and fluid compatibility.
      Precision equipment can benefit from well-defined quick-connect solutions because simplified tubing connections can support more efficient assembly and maintenance. Typical application fields include medical equipment, laboratory instruments, diagnostic systems, analytical devices, life-science equipment, and environmental monitoring systems.
      KF3N8-500 can be evaluated for applications requiring a female 3/8-18NPT connection combined with POM construction and a non-shut-off design.
      For any specific application, however, engineers should assess the entire connection assembly rather than selecting a coupling based solely on nominal thread size. The mating connector, tubing, seal material, working fluid, temperature, pressure, and installation environment all need to be considered.
      How Engineers Can Specify the Right Quick Coupling
      Before placing a purchase order, equipment manufacturers can review several key parameters:
      1. Connection standard: Confirm the required thread specification. KF3N8-500 uses a 3/8-18NPT threaded connection.
      2. Coupling gender: Determine whether the equipment requires a female or male interface and verify the compatibility of the mating component.
      3. Shut-off requirement: Establish whether fluid isolation must occur automatically when disconnected. KF3N8-500 is a non-shut-off model.
      4. Construction material: Confirm that POM is suitable for the fluid, temperature, pressure, and environmental conditions of the application.
      5. Sealing material: Select an appropriate O-ring material according to chemical compatibility and operating conditions.
      6. Installation geometry: Consider whether a straight or angled configuration is more suitable for the available equipment space and tubing route.
      7. System compatibility: Evaluate the complete fluid path, including hoses, tubes, valves, fittings, and other connectors.
      Following these steps can help prevent connection mismatches and make the coupling easier to integrate into new equipment designs.
      AIIBOOM's Manufacturing and Engineering Capabilities
      The performance of a quick coupling depends not only on its published specifications but also on manufacturing consistency and engineering support. These factors become particularly important when connectors are used as part of commercial medical, laboratory, or industrial equipment.
      Aiiboom technology specializes in precision fluid-control components and customized connection solutions for medical devices, life sciences, diagnostics, analytical instrumentation, and environmental applications. With more than 20 years of industry experience and over 1,000 partners, the company supports both standard product selection and application-specific requirements.
      The company operates research and development centers in Shenzhen, China, and Sendai, Japan. Its manufacturing operations cover approximately 20,000 square meters across facilities in Dongguan, Guangdong, and Tongling, Anhui. Production is supported by quality and environmental management systems certified to ISO 9001 and ISO 14001.
      For OEM customers, this combination of product development, manufacturing, and technical support can be useful when evaluating standard quick couplings alongside customized fluid-control requirements.
      Final Selection Considerations
      A quick coupling should be selected according to the requirements of the entire fluid system rather than simply its nominal size. Thread standard, connector gender, valve configuration, material, sealing method, tubing compatibility, and installation space all influence the final selection.
      KF3N8-500 offers a clearly defined B0 Series configuration with a female interface, POM construction, white finish, 3/8-18NPT thread, and no internal shut-off valve. For equipment designs that require these specifications, it can provide a practical option for compact and modular fluid connections.
      With configurable coupling solutions and the manufacturing and engineering capabilities of Aiiboom technology, OEMs and equipment developers can assess suitable connection components according to their specific system requirements. For applications requiring a female NPT connection without an integrated shut-off function, KF3N8-500 is a focused option worth evaluating.
      http://www.aiiboom.com
      Aiiboom technology
