2026-09-14 at 6:45 pm #17572
When products become too large for a conventional environmental test chamber, a walk-in environmental test chamber provides the additional space and environmental control required for large components, assemblies, battery systems, vehicles, and industrial equipment.
These chambers are widely used in automotive, electric vehicle, battery, aerospace, electronics, semiconductor, pharmaceutical, energy storage, and industrial manufacturing applications. Depending on the project, a walk-in chamber may be used to simulate controlled temperature and humidity conditions, perform thermal cycling, or reproduce other demanding environmental conditions.
For companies looking for a large walk-in environmental test chamber supplier, several established manufacturers are worth evaluating. KOMEG, ESPEC, Weiss Technik, Thermotron, Associated Environmental Systems (AES), and CSZ all offer environmental testing solutions, but their product portfolios, engineering approaches, customization capabilities, and target applications differ.
The best supplier is therefore not necessarily the company with the largest chamber or the lowest advertised temperature. The better approach is to compare each manufacturer against the actual requirements of your product and testing program.
Leading Large Walk-In Environmental Test Chamber Suppliers
The following six manufacturers are commonly considered when purchasing large or customized environmental test chambers.
Manufacturer Key Strengths Typical Applications KOMEG Flexible customization and large-scale environmental chambers Automotive, EV batteries, electronics, aerospace, solar, industrial ESPEC Precision environmental simulation and reliability testing Automotive, electronics, semiconductor, R&D Weiss Technik Climate simulation and industrial environmental testing Automotive, aerospace, electronics, industrial Thermotron Custom panel and solid walk-in chambers Automotive, aerospace, defense, industrial Associated Environmental Systems (AES) High-load and custom environmental rooms Batteries, automotive, aerospace, industrial CSZ Broad environmental testing portfolio Automotive, aerospace, defense, electronics, energy This is not intended to be a ranking from first to sixth. Each supplier has different strengths, and the appropriate choice depends on factors such as chamber size, temperature and humidity requirements, product heat load, safety requirements, installation conditions, and customization.
1. KOMEG
Custom Large Walk-In Environmental Test Chambers
KOMEG is a China-based manufacturer specializing in environmental test chambers and customized environmental simulation systems. The company has been manufacturing environmental testing equipment since 1990 and supplies products to customers in international markets.
Its walk-in environmental chamber portfolio includes standard configurations as well as customized systems. Published standard models range from approximately 4 m³ to 55 m³, while larger systems can be engineered according to the dimensions and requirements of the product being tested.
Depending on the configuration, KOMEG walk-in chambers can provide temperature and humidity control for demanding environmental testing applications. The company lists temperature ranges extending to approximately -60°C on the low side and up to +120°C on selected configurations, with humidity control available for temperature-and-humidity testing.
KOMEG’s walk-in chambers are used for a variety of applications, including automotive components, EV batteries, electronics, semiconductor equipment, solar panels, aerospace products, pharmaceutical testing, and industrial equipment.
One of KOMEG’s main advantages is its ability to customize the chamber around the customer’s actual testing requirements. Chamber dimensions, doors, cable ports, loading systems, internal fixtures, refrigeration capacity, airflow configuration, and safety features can be considered as part of the overall engineering design.
This is particularly useful when the product cannot be accommodated by a standard chamber or when the test involves significant heat generation, heavy loads, special loading equipment, or specific safety requirements.
Best suited for: companies looking for a flexible supplier capable of developing customized large walk-in environmental test chambers for industrial applications.
2. ESPEC
Precision Environmental Simulation
ESPEC is a Japanese manufacturer with a long history in environmental testing technology. Its portfolio includes temperature and humidity chambers, walk-in chambers, thermal shock systems, and other environmental testing equipment.
The company’s walk-in chambers are designed for applications where conventional laboratory chambers cannot accommodate the size of the test specimen. ESPEC also offers systems designed for high-power and demanding automotive reliability testing.
ESPEC can be a strong option for companies that place particular importance on environmental simulation accuracy, reliability testing, and established Japanese testing technology.
Its products are widely relevant to automotive, electronics, semiconductor, and research applications.
Best suited for: organizations that prioritize precision environmental simulation and established environmental testing technology.
3. Weiss Technik
Climate Simulation for Industrial Testing
Weiss Technik is a major international supplier of environmental simulation equipment. Its portfolio covers temperature and climatic test chambers, walk-in systems, customized environmental testing solutions, and other testing technologies.
The company serves industries including automotive, aerospace, electronics, alternative energy, and industrial manufacturing.
For large environmental test projects, Weiss Technik is particularly relevant when climate simulation performance, engineering support, and integration with broader testing requirements are important considerations.
As with other suppliers, buyers should evaluate actual chamber performance under the expected product load rather than relying solely on the temperature range stated on a product datasheet.
Best suited for: industrial and engineering organizations looking for established climate simulation technology and customized environmental testing solutions.
4. Thermotron
Panel and Solid Walk-In Environmental Chambers
Thermotron is a U.S.-based manufacturer of environmental and vibration testing equipment. Its walk-in chamber portfolio includes both panel walk-in chambers and solid walk-in chambers.
Panel systems can provide a practical solution for many large-product testing applications, while solid walk-in chambers can be customized for larger or more specialized requirements.
Thermotron’s walk-in chambers are used for automotive, aerospace, defense, and industrial applications. Depending on the configuration, customers can specify features such as reinforced floors, access ports, shelving, and customized chamber dimensions.
For projects involving large components or specialized environmental testing conditions, the distinction between standard panel construction and custom solid construction can be an important purchasing consideration.
Best suited for: buyers looking for U.S.-manufactured environmental test equipment and customized walk-in chamber solutions.
5. Associated Environmental Systems (AES)
High-Load and Custom Environmental Rooms
Associated Environmental Systems, commonly known as AES, provides environmental test chambers ranging from standard systems to customized walk-in environmental rooms.
Its walk-in solutions include panel-built, structural, and field-built systems designed for applications involving large products, high loads, and demanding environmental conditions.
AES serves industries such as automotive, aerospace, batteries, energy storage, electronics, and industrial manufacturing.
For battery and high-power applications, product heat generation can have a major effect on chamber design. The refrigeration system must be capable of removing the heat generated by the device under test while maintaining the required environmental conditions.
This makes AES relevant for projects where high live loads, significant heat loads, or customized environmental rooms are important requirements.
Best suited for: high-load applications and projects requiring modular or custom-built environmental rooms.
6. CSZ
Walk-In, Drive-In, and Environmental Testing Systems
CSZ is an established environmental testing equipment manufacturer offering a broad range of testing systems.
Its portfolio includes temperature and humidity chambers, stability chambers, thermal shock chambers, altitude chambers, vibration systems, and walk-in and drive-in environmental chambers.
The company’s walk-in and drive-in systems can be used for applications ranging from large components to complete vehicles and other large industrial products.
CSZ can therefore be an attractive option for companies that require environmental testing equipment beyond a single walk-in chamber and may need several types of test systems as part of a broader laboratory or manufacturing facility.
Best suited for: organizations looking for a broad environmental testing portfolio, including walk-in and drive-in systems.
How Do These Suppliers Compare?
There is no single manufacturer that is the best choice for every application. A more useful comparison is to consider which supplier aligns most closely with your engineering requirements.
Supplier Customization Large Chamber Capability Battery Applications Automotive Global Market KOMEG High High Strong Strong Yes ESPEC High High Strong Strong Yes Weiss Technik High High Strong Strong Yes Thermotron High High Strong Strong Yes AES High High Strong Strong Yes CSZ High High Strong Strong Yes The table should be viewed as a purchasing framework rather than an independent performance ranking. Actual chamber capability depends on the specific model, configuration, test conditions, and engineering requirements.
What Should You Consider When Choosing a Walk-In Environmental Test Chamber?
Choosing a large environmental chamber requires more than comparing the minimum and maximum temperatures.
The first consideration is working volume. The chamber must accommodate not only the product itself but also fixtures, racks, cables, operators, and sufficient airflow clearance. Door dimensions are equally important because a chamber that can technically accommodate the product may still be difficult to load.
Temperature performance is another critical factor. Buyers should compare temperature range together with temperature uniformity, stability, heating and cooling rates, recovery time, and performance under actual product load.
Humidity performance should also be evaluated when the test requires temperature and humidity control. Important parameters include humidity range, humidity stability, uniformity, dew-point performance, and low-temperature humidity capability.
For batteries, electronics, servers, motors, inverters, and other heat-generating products, product heat load can be one of the most important specifications. A chamber that achieves its rated temperature in an empty condition may not provide the same performance when the DUT generates several kilowatts of heat.
Airflow is closely related to this issue. As chamber size increases, maintaining temperature uniformity becomes more challenging. The supplier should consider fan capacity, air distribution, product placement, heat generation, and fixture design when engineering the chamber.
Finally, safety and installation requirements should be addressed before the chamber is ordered. Battery testing, for example, may require gas detection, smoke detection, fire protection, pressure relief, exhaust systems, and emergency shutdown functions depending on the test scenario and risk assessment.
Standard or Custom Walk-In Environmental Chamber?
A standard walk-in chamber can be the most economical option when the product dimensions, environmental conditions, loading method, and facility requirements fit an existing configuration.
A customized chamber becomes more appropriate when the project involves unusually large or heavy products, high heat loads, special door dimensions, rapid temperature cycling, unusual loading requirements, battery safety systems, production-line integration, or restricted installation space.
For these applications, the chamber should be designed around the test rather than simply selected according to nominal chamber volume.
What Information Should You Provide When Requesting a Quote?
A detailed technical specification can significantly improve the accuracy of supplier quotations.
Instead of telling a manufacturer only that you need a “20 m³ walk-in chamber,” provide information about the product dimensions and weight, number of test samples, required temperature and humidity ranges, heating and cooling rates, product heat generation, chamber dimensions, door size, loading method, applicable safety requirements, available electrical power, installation space, and relevant testing standards.
A useful RFQ should answer four basic questions:
Category Key Information Product Dimensions, weight, quantity, heat generation Test Temperature, humidity, ramp rate, uniformity Chamber Internal dimensions, door, floor load, loading method Facility Power, room size, utilities, installation conditions The more complete the RFQ, the easier it is for different suppliers to provide comparable technical proposals.
Which Walk-In Environmental Chamber Supplier Is Right for You?
If your project requires a highly customized large environmental chamber, KOMEG may be a strong candidate to include in the RFQ process.
ESPEC is worth considering when precision environmental simulation and established Japanese technology are priorities. Weiss Technik is relevant for industrial climate simulation and international engineering support. Thermotron is an option for U.S.-manufactured panel and solid walk-in systems, while AES is particularly relevant to high-load and custom environmental room applications. CSZ may be attractive when walk-in or drive-in chambers need to be combined with other environmental testing technologies.
The best supplier ultimately depends on the specific product, test standard, environmental conditions, heat load, safety requirements, facility, and service expectations.
Frequently Asked Questions
What is a large walk-in environmental test chamber?
A large walk-in environmental test chamber is a controlled test enclosure designed to accommodate large products, assemblies, or multiple test samples. It can reproduce environmental conditions such as temperature and humidity for reliability and performance testing.
How large can a walk-in environmental test chamber be?
There is no universal maximum size. Standard walk-in chambers are typically available in several cubic meters to several tens of cubic meters, while much larger systems can be engineered as customized environmental rooms.
How much does a large walk-in environmental chamber cost?
The cost depends on chamber volume, temperature range, humidity requirements, temperature change rate, product heat load, construction, refrigeration capacity, safety systems, controls, and installation requirements. For this reason, large walk-in chambers are normally quoted according to detailed technical specifications.
Can walk-in environmental chambers be used for EV battery testing?
Yes. Walk-in chambers are increasingly used for battery and EV component testing. However, battery applications may require additional safety and thermal-management systems depending on the battery type, energy level, test procedure, and facility risk assessment.
What is the difference between a walk-in and a drive-in environmental chamber?
A walk-in chamber is designed for operators to enter the test space and for large products or assemblies to be loaded inside. A drive-in chamber is generally designed to accommodate vehicles or very large equipment directly.
What is the most important specification when buying a walk-in chamber?
There is no single most important specification. Chamber size, temperature and humidity performance, ramp rate, DUT heat load, airflow, safety, loading requirements, installation conditions, and service support should all be evaluated together.
Final Takeaway
For companies searching for large walk-in environmental test chamber suppliers, KOMEG, ESPEC, Weiss Technik, Thermotron, Associated Environmental Systems, and CSZ are six manufacturers worth considering.
However, the right supplier should be selected based on the actual testing application rather than brand recognition alone.
For a serious procurement project, compare suppliers according to working volume, temperature and humidity performance, ramp rate, product heat load, airflow, safety, customization, installation requirements, validation, and after-sales support.
For projects involving EV batteries, energy storage systems, automotive components, aerospace products, electronics, solar panels, or other large and heat-generating products, a customized walk-in environmental test chamber may provide a better solution than a standard chamber.
KOMEG provides both standard and customized walk-in environmental test chambers and can develop chamber configurations around the customer’s product dimensions, environmental requirements, heat load, loading method, and facility conditions.
Explore KOMEG Walk-In Environmental Test Chambers
https://www.komegtek.com/product-category/walk-in-environmental-chambers/
Walk-In Environmental Test Chambers -
