2026-05-15 at 9:06 am #16080
In modern wire manufacturing, selecting the right wire drawing machine is essential for achieving production efficiency, stable product quality, and long-term operational reliability. Ding Tian offers two advanced models—the LHS220-24 dual inverter tension-rodless small wire drawing machine and the LHST150-24 continuous annealing automatic fine wire drawing machine—designed to meet different industrial production needs. Both systems are engineered for high efficiency, precise control, and stable performance, but they serve different application scenarios.
More product details can be found here:
<a href="https://www.dtwiredraw.com/">wire drawing machine solutions</a>This article provides a structured comparison of the two machines, covering technical parameters, functional design, application fields, and production advantages, helping manufacturers make a more informed equipment selection.
1. Machine Positioning and Core Parameters
LHS220-24 Dual Inverter Tension-Rodless Small Wire Drawing Machine
The LHS220-24 is designed for small to medium wire diameter processing, focusing on cost efficiency and stable mass production. It is widely used in general-purpose wire drawing applications where reliability and consistency are key.
Key specifications:
Inlet wire diameter: φ0.45mm – φ1.2mm
Outlet range: φ0.08mm – φ0.35mm
Die configuration: max 24 dies (1+11+11+1)
Reduction rate: 13%, final 10%
Lubrication system: fan-shaped spray cooling for stable drawing
Take-up system: ball screw transmission with servo bidirectional control
Control system: dual inverter drive, rodless tension structure
Take-up width: 250mm – 280mm
This model emphasizes structural simplicity, stable operation, and easy maintenance, making it suitable for continuous industrial production environments.
LHST150-24 Continuous Annealing Automatic Fine Wire Drawing Machine
The LHST150-24 is developed for high-precision fine wire manufacturing with an integrated continuous annealing system. It is mainly used in applications requiring soft and high-quality finished wire.
Key specifications:
Inlet wire diameter: φ0.12mm – φ0.55mm
Outlet range: φ0.03mm – φ0.12mm
Core process: integrated drawing + continuous annealing
Control system: intelligent closed-loop control (tension + temperature)
Take-up system: automatic precision winding with flat coil formation
This model supports stable production of ultra-fine wire below 0.10mm, addressing the demand for high-end fine wire manufacturing applications.
2. Core Functional and Technical Advantages
LHS220-24: Stability, Simplicity, and Cost Efficiency
The LHS220-24 is designed for durable industrial use in standard wire production environments.
Main advantages:
Rodless tension structure
Reduces mechanical complexity, lowers failure risk, and improves maintenance convenience. -
Dual inverter speed control
Ensures smooth acceleration and stable drawing performance, effectively reducing wire breakage. -
Fan-shaped spray lubrication system
Provides uniform cooling and lubrication, improving die lifespan and wire surface quality. -
Servo automatic take-up system
Delivers consistent winding quality and improves downstream processing efficiency. -
High-rigidity frame structure
Reduces vibration and noise, ensuring stable long-term operation.
This machine is widely used for carbon steel wire, copper wire, alloy wire, and other conventional materials.
LHST150-24: Integrated Process, Precision, and Soft Wire Output
The LHST150-24 focuses on high-end fine wire production with advanced automation and process integration.
Main advantages:
Integrated drawing and annealing process
Eliminates the need for secondary annealing, improving efficiency and reducing handling losses. -
Ultra-fine wire stability
Supports stable production of φ0.04–0.10mm soft wire for electronics, communication, and medical industries. -
Closed-loop intelligent control system
Real-time regulation of temperature, tension, and speed ensures consistent wire properties. -
Smart take-up system
Provides precise coil formation with digital monitoring for better consistency. -
Multi-material compatibility
Suitable for copper, alloy, copper-clad aluminum, and silver-plated wire.
This model is ideal for industries requiring extremely high precision and performance consistency.
3. Application Scenarios and Selection Guide
Choose LHS220-24 if you need:
Large-scale production of standard small-to-medium diameter wire
Cost-effective and easy-to-operate equipment
Low maintenance requirements
Hard wire production without annealing process
Applications such as fasteners, general cables, and hardware wire
Choose LHST150-24 if you need:
Ultra-fine and high-precision wire manufacturing
Soft finished wire with annealing requirements
High automation with reduced labor dependency
Use in electronics, aerospace, medical, or communication industries
Processing of special materials such as alloy or silver-plated wire
4. Technical Comparison Summary
Feature LHS220-24 LHST150-24 Target Market General wire production High-end fine wire Process Type Drawing only Drawing + annealing Wire Range Medium-small diameter Ultra-fine wire Automation Level Standard automation Intelligent closed-loop system Product Output Hard wire Soft finished wire Application Industrial general use High-precision industries
5. Conclusion: Choosing the Right Machine for Maximum Efficiency
The LHS220-24 and LHST150-24 from Ding Tian represent two complementary solutions in modern wire manufacturing equipment.
The LHS220-24 wire drawing machine is designed for stable, efficient, and cost-effective mass production, making it suitable for standard industrial wire processing needs.
The LHST150-24 continuous annealing wire drawing machine focuses on precision, process integration, and ultra-fine soft wire production for advanced industrial applications.
Together, they form a complete equipment portfolio that covers both conventional and high-end wire manufacturing requirements.
Manufacturers can select the most suitable solution based on wire diameter, material type, production scale, and final product specifications to achieve the best balance of efficiency, quality, and cost performance.
For integrated system solutions, visit:
<a href="https://www.dtwiredraw.com/">wire drawing machine manufacturer solutions</a>http://www.dtwiredraw.com
Dingtian -
