Liquid-Cooled HPC Charging Connectors: How They Enable Faster EV Charging
  • #17542
      High-power charging is becoming an increasingly important part of EV infrastructure. As electric vehicles move toward larger battery capacities and shorter charging times, charging stations need to deliver considerably more power than conventional AC or standard DC charging systems.
      For charging station manufacturers and EV infrastructure integrators, however, simply increasing current is not enough. Higher current also means greater heat generation, and this directly affects the design of charging cables and connectors.
      This is one of the reasons liquid-cooled HPC charging connectors are receiving more attention in the EV charging industry.
      For companies sourcing charging components from China, the key question is not only whether a connector supports 600A or 800A. It is also whether the manufacturer has the engineering capability, product range, standards coverage, and production experience required for high-power charging applications.
      Why Liquid Cooling Is Important for HPC Charging
      In a high-power charging system, electrical current passes through the cable, terminals, and connector contacts. Electrical resistance inevitably generates heat.
      As current increases, thermal management becomes more challenging. A conventional approach would be to increase the conductor size to handle higher current. While this can improve electrical performance, it also makes the cable assembly heavier and less convenient for users.
      This creates a practical problem for high-power charging stations.
      An HPC charging connector needs to handle high current while remaining suitable for repeated operation. For charging station operators, a cable that is technically capable of carrying high current but is difficult to handle is not necessarily the best solution.
      Liquid cooling provides another approach.
      Instead of relying only on larger conductors and passive heat dissipation, a liquid-cooled charging system circulates coolant through a dedicated cooling path. Heat generated during high-current charging can be transferred away from the cable and connector assembly.
      This thermal management approach makes liquid cooling particularly useful for high-current HPC applications.
      What Makes an HPC Connector Different?
      An HPC connector is not simply a larger version of a standard EV charging plug.
      When a charging system operates at high current, several factors have to be considered together:
      • Current rating
      • Operating voltage
      • Contact resistance
      • Temperature rise
      • Cooling design
      • Mechanical durability
      • Connector standard
      • Vehicle-side compatibility
      • Charging duty cycle
      • Installation environment
      For example, a charging project may require a connector capable of 600A continuous current. Another project may need an 800A solution. The two projects should not automatically use the same product simply because both are classified as HPC.
      The charging station architecture, vehicle inlet, cable length, cooling system, operating conditions, and expected charging frequency all influence the final selection.
      This is why B2B buyers should discuss the actual application with the manufacturer before placing an order.
      DUOSIDA's HPC Product Range
      Zhangjiagang UCHEN New Energy Technology Co., Ltd., also known as Youcheng Technology, is a China-based charging solution service provider focused on the development and market promotion of high-performance charging products for new energy vehicles.
      Under the DUOSIDA brand, the company provides a range of charging products for EV charging infrastructure and vehicle applications.
      Its HPC Products category includes multiple high-power charging solutions designed around different current, voltage, and connector requirements.
      CCS1 LIQUID COOLED PRODUCTS (Rated Current: 500A Max Constant Current)
      The current product range includes:
      • CHAOJI DC Vehicle Inlet
      • CHAOJI DC Vehicle Connector
      • HPC products with 600A/800A constant-current configurations
      • HPC products with 400A/500A/600A/800A constant-current configurations
      • 600A HPC products rated for 1000V
      • CCS1 liquid-cooled products with up to 500A maximum constant current
      Several of the HPC products are specified for up to 1500V/DC operation.
      This range is particularly relevant to OEMs, charging equipment manufacturers, and system integrators because different EV platforms and charging projects have different technical requirements.
      Instead of looking for a single universal connector, buyers can select a product configuration according to their actual project.
      600A or 800A? Start With the Charging System
      One of the most common questions when purchasing HPC components is whether to choose a 600A or 800A connector.
      There is no universal answer.
      The first step is to determine the charging system's required power and electrical architecture. Current and voltage work together to determine charging power, so increasing current is only one possible way of increasing power.
      For projects designed around high-current charging, an 800A solution may provide additional capacity. However, if the charging system is designed around lower current requirements, a 600A connector may already be sufficient.
      The cooling system also needs to be considered.
      A high-current liquid-cooled connector should not be treated as an independent component. Its performance depends on how the connector, cable, coolant circulation system, charging equipment, and vehicle inlet work together.
      For procurement teams, this means the supplier should be able to discuss the complete application rather than simply provide a current rating.
      1500V HPC Products for High-Power Applications
      Voltage is another important specification when selecting HPC charging components.
      DUOSIDA's current HPC portfolio includes products rated at 1500V/DC. This includes CHAOJI-related products as well as high-current HPC solutions.
      For example, the company's CHAOJI DC vehicle connector is listed with a maximum constant current of 600A and a 1500V/DC rating. Other HPC products are listed with 600A/800A constant-current configurations and 1500V/DC operation.
      For high-power charging infrastructure, these specifications provide charging equipment developers with more options when designing their electrical systems.
      Of course, a 1500V rating does not mean that the product should be used in every charging application. The complete electrical architecture, vehicle platform, applicable standard, and operating requirements still need to be checked.
      This is where communication between the buyer and manufacturer becomes important.
      CHAOJI and CCS1 for Different Markets
      EV charging is not based on one universal connector standard.
      Different regions and vehicle manufacturers may use different charging interfaces, which means an international charging equipment supplier needs to consider market-specific requirements.
      DUOSIDA's charging product portfolio covers multiple regional standards, including European, Japanese, China National, American, Thai, and Australian standards.
      Within the HPC category, the company currently offers both CHAOJI products and CCS1 liquid-cooled products.
      This is useful for customers developing charging equipment for different markets.
      For example, a charging station manufacturer supplying equipment to the North American market may have different connector requirements from a company developing charging infrastructure for China or another regional market.
      Having multiple standards within the same supplier's product portfolio can simplify communication during product development and sourcing.
      Where Can Liquid-Cooled HPC Connectors Be Used?
      Liquid-cooled HPC connectors are particularly relevant where high charging power and frequent charging are required.
      Potential applications include:
      Public Fast-Charging Stations
      Public charging stations need to provide convenient charging within a limited amount of time. High-power charging can help support this objective, particularly at busy charging locations.
      Commercial EV Fleets
      Fleet vehicles often follow fixed operating schedules. Vehicles may return to a depot for charging within a limited time window, making charging capacity an important consideration.
      Heavy-Duty and Commercial EVs
      As electric buses, trucks, and other commercial vehicles become more common, charging infrastructure needs to accommodate larger battery systems and demanding operating schedules.
      High-Power Charging Networks
      For operators developing high-power charging networks, thermal management becomes increasingly important as charger output increases.
      In these applications, the connector needs to be considered as part of the entire charging system rather than as an isolated accessory.
      What Should Importers Ask a Chinese HPC Manufacturer?
      If you are sourcing HPC charging connectors from China, there are several questions worth asking before moving forward.
      1. What current and voltage ratings are available?
      Ask for the actual product range instead of assuming that one model can cover every project.
      2. Which charging standards are supported?
      Confirm whether the manufacturer has products suitable for your target market and vehicle platform.
      3. Is liquid cooling available?
      For high-current applications, understand how the cooling system is integrated with the connector and cable.
      4. What products can be customized?
      For OEM and charging equipment projects, customization may involve connector configuration, cable assembly, electrical parameters, or mechanical requirements.
      5. Can the supplier provide engineering support?
      Technical communication becomes particularly important when integrating a high-power connector into a new charging system.
      6. Does the supplier have other EV charging products?
      A manufacturer with a broader product portfolio may be more convenient for projects requiring several charging components.
      Why Work With a Specialized Charging Manufacturer?
      For an EV charging project, choosing a supplier purely according to a single specification can create problems later.
      For example, an importer may find a connector with the required current rating, but discover that the supplier does not have a compatible vehicle inlet, another regional standard, or the engineering support required for integration.
      A specialized charging manufacturer can provide a broader technical base.
      Youcheng Technology focuses specifically on charging-related products for new energy vehicles. Its product portfolio includes HPC products as well as charging sockets, charging plugs, Mode 2 and Mode 3 charging products, NACS products, electrical discharge products, vehicle outlet sockets, adapters, electric locks, charging stations, connector holders, and high-voltage connector products.
      For B2B customers, this broader range can be valuable when several components are needed for the same EV charging project.
      The DUOSIDA official website provides an overview of the company's charging product portfolio and solutions.
      A Practical Approach to HPC Product Sourcing
      For an overseas buyer, the sourcing process does not need to be complicated, but it should start with the right technical information.
      Before contacting a manufacturer, prepare the basic requirements of your project:
      Target market:
      China, Europe, North America, or another region.
      Connector standard:
      For example, CCS1 or CHAOJI.
      Required current:
      Such as 400A, 500A, 600A, or 800A.
      System voltage:
      For example, 1000V or 1500V/DC.
      Charging environment:
      Public station, fleet depot, commercial vehicle charging, or another application.
      Expected operating conditions:
      Temperature, frequency of use, installation environment, and other relevant requirements.
      Once this information is available, it becomes much easier for the manufacturer to recommend an appropriate product.
      This approach also helps avoid comparing products based on specifications that are not actually relevant to the project.
      A China Supplier for High-Power EV Charging Projects
      The growth of high-power EV charging is creating new requirements for charging connectors. As current levels increase, thermal management becomes an important part of connector design.
      Liquid-cooled HPC connectors provide a practical solution for managing heat in high-current charging applications while supporting the development of more powerful charging infrastructure.
      For B2B buyers, however, the connector itself is only one part of the decision. Current and voltage ratings, charging standards, cooling configuration, vehicle compatibility, operating environment, and manufacturer capabilities should all be considered together.
      Zhangjiagang UCHEN New Energy Technology Co., Ltd. (Youcheng Technology) focuses on high-performance charging products for new energy vehicles and provides a broad portfolio under the DUOSIDA brand.
      With HPC products covering different current configurations, including 400A, 500A, 600A, and 800A solutions, together with 1000V and 1500V/DC options, CHAOJI products, and CCS1 liquid-cooled products, the company can support different requirements in high-power EV charging applications.
      For companies developing charging stations, fleet infrastructure, or other EV charging equipment, reviewing the complete HPC product range is a practical starting point when evaluating high-power charging components from a Chinese manufacturer.
      http://www.duosidaev.com/
