Maintenance free colloidal battery 6-GFM-71
  • #10801
      https://www.tesenbattery.com/Maintenance-free-colloidal-battery-6-GFM-71.html
      6-GFM-71 Colloidal Maintenance-free Battery 12v110Ah Electric Vehicle Sanitation Vehicle Floor Washing Machine Cruise
      Model:
      6-GFM-71
      12V71Ah(C20)
      Size:
      Long 226
      Wide 171
      High 175
      Weight:17+0.5kg
      Suitable for electric sedans, electric tricycles, electric four-wheel vehicles, etc
      The 6-GFM-71 maintenance free colloidal battery is a cutting-edge battery designed for high-performance and reliability in a variety of applications, including electric vehicles, sanitation vehicles, and floor washing machines. This no maintenance golf cart battery represents the pinnacle of battery technology, offering a combination of convenience, efficiency, and durability.
      Product Advantages and Features
      1. Low Maintenance: The 6-GFM-71 maintenance free colloidal battery eliminates the need for regular watering and electrolyte level checks, saving time and effort.
      2. High Energy Density: The battery's design and materials contribute to its high energy density, providing more power in a smaller footprint.
      4. Sealed and Safe: The 6-GFM-71 maintenance free colloidal battery's sealed construction prevents the leakage of acid and the emission of harmful fumes, making it safe for various applications.
      5. Low Self-Discharge: The battery's composition results in a low self-discharge rate, ensuring that the battery retains its charge for longer periods when not in use.
      6. High Discharge Performance: The 6-GFM-71's low internal resistance allows for excellent discharge performance at higher electric currents, making it suitable for demanding applications.
      Applications
      The 6-GFM-71 no maintenance golf cart battery is versatile and can be used in a variety of applications where reliable and consistent power is required. Some of the key applications include:
      1. Electric Vehicles: The battery's compact size and high energy density make it ideal for powering electric sedans, tricycles, and four-wheel vehicles.
      2. Uninterruptible Power Supplies: The battery's reliability and long service life make it a preferred choice for UPS systems that require consistent backup power.
      3. Emergency Lighting: In case of power outages, the 6-GFM-71 can provide the necessary power to keep emergency lights operational.
      4. Signal Systems: The battery's high discharge performance is crucial for signal systems in railways and aviation that require immediate and reliable power.
      5. Security Systems: For security systems that need a constant power supply, the 6-GFM-71 no maintenance golf cart battery offers a dependable solution.
      Instructions for Use
      1. Installation: Upon unpacking, check the battery and accessories against the packing list. Clean the terminals with a steel wire brush to ensure the lowest connection resistance before connecting. All batteries leave the factory with an electric charge, so avoid short circuits and use insulated tools during installation to prevent electrical shocks.
      2. Connection: After connecting the batteries, check the total voltage of the battery unit and the polarity to prevent reversing the poles. Disconnect the batteries and power supply if the device is not powered on immediately after connection to prevent over-discharging.
      3. Charging: Use charging equipment that can restrict the current at constant voltage.
      FAQ
      Q: How often do I need to maintain the no maintenance golf cart batteries?
      A: As a professional supplier of no maintenance golf cart batteries, we can assure you that the 6-GFM-71 is a maintenance free colloidal battery, which means you do not need to perform regular maintenance such as watering or checking electrolyte levels. However, it is still important to periodically check the battery terminals for corrosion and ensure that connections are secure.
      Guangdong Tesen New Energy Technology Co., Ltd.
