2025-06-09 at 4:38 pm #12809
Double chain stitch sewing machines are essential tools in the apparel, home textile, and industrial sewing industries. Known for their durability and strength, these machines produce highly stretchable seams, making them ideal for applications like waistband attachments, knitwear, and decorative stitching. However, like any piece of precision equipment, regular maintenance and timely troubleshooting are key to ensuring peak performance.
As a leading manufacturer in the sewing machine industry, Sanhexin has been at the forefront of designing and producing advanced, high-performance double chain stitch machines. In this guide, we’ll explore essential maintenance tips and provide solutions to common issues, helping you keep your machines running smoothly and efficiently.
Understanding the Double Chain Stitch Mechanism
Before diving into maintenance, it’s important to understand how a double chain stitch machine works. Unlike a single needle lockstitch, a double chain stitch is formed by two or more threads that loop together on the underside of the fabric. This structure provides greater elasticity, making it particularly suitable for seams that need to stretch or bear heavy loads.
Sanhexin’s double chain stitch machines are engineered for high-speed, stable stitching and are widely used in garment factories across the globe due to their reliability and innovative design.
Daily Maintenance Tips
Proper care extends the lifespan of your equipment and ensures consistent stitch quality. Here are Sanhexin’s recommended daily maintenance practices:
1. Clean the Machine Regularly
Remove lint, dust, and thread buildup from the needle plate, looper area, and feed dogs.
Use a soft brush or compressed air to reach tight spaces.
2. Lubricate Key Components
Follow the manufacturer’s lubrication chart.
Sanhexin machines come with a well-marked oiling system to guide users.
Use only high-quality sewing machine oil to avoid residue or clogging.
3. Check Tension Settings
Ensure the thread tension is adjusted for your fabric type and thickness.
Misadjusted tension can cause skipped stitches or puckering.
4. Inspect the Needles
Replace bent, dull, or worn needles daily, or after every major project.
Use the correct needle type and size recommended by Sanhexin for optimal performance.
5. Verify Thread Path and Quality
Ensure that threads are correctly threaded and not tangled or frayed.
Poor thread quality can increase breakage and reduce stitch consistency.
Common Problems and How to Fix Them
Even with regular upkeep, issues can arise. Here are some of the most frequent problems with double chain stitch machines—and how to troubleshoot them effectively:
1. Skipped Stitches
Causes:
Needle is not inserted correctly or is damaged.
Incorrect needle type or size.
Loopers are out of sync.
Solutions:
Check needle position and replace if necessary.
Re-time the looper and needle bar as per the Sanhexin service manual.
2. Thread Breakage
Causes:
Poor quality or incorrect thread.
Tension too tight.
Burrs or damage on needle or thread guides.
Solutions:
Switch to high-quality, smooth threads.
Adjust tension and inspect all threading components for wear or damage.
3. Uneven Stitching or Puckering
Causes:
Fabric not feeding evenly.
Presser foot pressure too high.
Incorrect thread tension.
Solutions:
Adjust feed dog settings and presser foot pressure.
Re-balance upper and lower thread tension.
4. Machine Jamming or Not Running Smoothly
Causes:
Accumulated lint or debris.
Dry or poorly lubricated components.
Internal timing issues.
Solutions:
Perform a full cleaning and lubrication.
Consult Sanhexin’s maintenance guide for timing calibration.
Why Choose Sanhexin for Your Sewing Machine Needs?
As a company deeply rooted in sewing machine R&D, production, and innovation, Sanhexin continues to deliver cutting-edge solutions tailored to meet the evolving demands of the textile industry. Their double chain stitch machines are designed with:
User-friendly interfaces
High-speed operation with low vibration
Durable components for long service life
After-sales support and technical service worldwide
Whether you run a large-scale garment production line or a specialized textile operation, Sanhexin machines provide the reliability and stitching quality you can count on.
Final Thoughts
Maintaining your double chain stitch sewing machine doesn’t have to be complicated. By following a few daily routines and learning how to troubleshoot common issues, you can keep your equipment in top condition and avoid costly downtime.
Partnering with a trusted manufacturer like Sanhexin ensures you not only get a high-quality machine, but also the support and knowledge to maintain it for years to come.
If you're ready to upgrade your production line or simply improve your machine care routine, Sanhexin’s advanced solutions and expert team are here to help.
Double Chain Stitch Sewing Machines: Solutions for Efficient and Durable Stitching
http://www.bedoly.net
Ningbo Sanhexin Automation Co., Ltd. -
