Medium and Large-Scale VPSA Oxygen Plants for Industrial Applications
  • #18079
      https://www.zcqt-vpsa.com/medium-and-large-scale-oxygen-production-equipment.html
      Medium and large-scale VPSA oxygen plants provide an efficient on-site oxygen supply solution for industries that require a continuous and reliable oxygen source. Using air as the raw material, these systems separate oxygen and nitrogen through high-efficiency solid adsorbents, making them suitable for a wide range of industrial applications.
      Key Specifications
      • Oxygen Capacity: 1,000–7,500 Nm³/h per unit
      • Oxygen Concentration: 80%–93%
      • Minimum Order Quantity: 1 unit
      • Packaging: Suitable for ocean shipping
      • Delivery Time: Typically 5 months, adjustable according to project requirements
      • Certifications: ISO quality management, occupational health management, and environmental management systems
      • Standards: Customizable according to client requirements
      Main Industrial Applications
      Medium and large-scale VPSA oxygen plants can support oxygen demand across multiple industries:
      • Steel: Oxygen enrichment for blast furnaces.
      • Non-ferrous Metals: Oxygen supply for smelting furnace combustion.
      • Coal Chemical Industry: Oxygen supply for cracking furnaces.
      • Cement: Oxygen-enriched combustion in rotary kilns.
      • Papermaking and Water Treatment: Oxygen supply for ozone generators.
      • Solid Waste Treatment: Combustion oxygen and kiln shielding gas applications.
      • Glass and Environmental Industries: Oxygen enrichment for glass furnaces and related processes.
      • Medical and High-Altitude Applications: Oxygen diffusion in high-altitude or low-oxygen environments, subject to specific system requirements.
      Core Technology and Advantages
      The VPSA oxygen plant uses lithium-based molecular sieves and proprietary patented technologies in its system design. Optimized adsorption processes help improve separation efficiency and manage energy consumption across different equipment models.
      Key advantages include:
      • High automation: Simplifies routine operation and reduces the need for intensive manual intervention.
      • Energy efficiency: Optimized system design helps reduce operating energy consumption.
      • Simplified operation: Automated controls support straightforward operation and convenient start-up and shutdown.
      • Stable adsorption performance: Patented adsorption tower designs are intended to improve internal flow distribution and adsorption efficiency while minimizing noise and vibration.
      • Lower operating costs: On-site oxygen production can help reduce reliance on externally supplied oxygen, depending on local supply and operating conditions.
      Compared with cryogenic oxygen plants, VPSA systems can offer lower energy consumption, a more compact installation, reduced labor requirements, and simplified operational management for suitable applications.
      Installation, Operation, and Maintenance
      Medium and large-scale VPSA oxygen plants are designed for industrial projects that require substantial oxygen production capacity. Installation requires building construction and equipment foundation work, which should be considered during project planning.
      The equipment features a high level of automation and relatively straightforward routine maintenance. Operators can generally manage normal operations after receiving appropriate basic training.
      The typical service process includes inquiry, needs assessment and proposal, preliminary design, initial quotation, contract signing, detailed design, equipment supply, installation, and commissioning.
      Delivery typically takes around five months, with the schedule adjustable according to project requirements.
      Customized VPSA Oxygen Solutions
      For industrial facilities requiring an oxygen capacity of 1,000–7,500 Nm³/h per unit, a medium or large-scale VPSA oxygen plant offers an on-site oxygen production option with automated operation and application-specific system design.
      Contact the supplier at zcqt2025@163.com to discuss oxygen demand, installation conditions, and project requirements.
      For smaller-capacity applications, see the Small Skid-Mounted VPSA Oxygen Plant.
      http://www.zcqt-vpsa.com
      Hubei Zhongchuan Gas Co., Ltd.
