Mesh LED Screens for Commercial Centers: Key Features 2026
  • #18258
      Understanding the Demand for Mesh LED Screens in Commercial Centers
      Commercial centers increasingly require display technology that can integrate into glass facades, atriums, and open-plan retail environments without blocking natural light or overwhelming architectural design. Conventional LED displays are often heavy, thick, and block light, which creates friction when property developers or retail brands want to preserve sightlines, daylight, and open aesthetics while still delivering digital content. This tension between visual communication and architectural transparency is precisely the pain point that transparent and mesh-type LED products are designed to resolve.
      Shenzhen Showho: The Company Behind Whaley-LED
      Shenzhen Showho was founded in 2015 and is headquartered in Shenzhen, China. The company integrates self research and development, structural design, and in-house production, allowing it to respond quickly to market demand. Its business coverage includes the China domestic market, and starting in 2025 it expanded into overseas commercial display and engineering projects under the brand name Whaley-LED, offering OEM and ODM services.
      From Rental Displays to Global Expansion
      In its early stage, Shenzhen Showho focused on the domestic high-end rental display market, including XR virtual shooting screens and carbon fiber rental screens. In 2025, the company established an overseas business unit and launched the Whaley-LED brand, extending its reach into international commercial display and engineering projects. This trajectory—from a domestically focused rental display specialist to a company offering OEM and ODM services abroad—reflects a company type defined as an integrated R&D, structural design, and manufacturing enterprise.
      The LED Mesh Screen Within Showho’s Transparent Display Portfolio
      Among its main product categories for commercial display and engineering projects, Shenzhen Showho lists the LED Mesh Screen as part of its additional transparent and specialty LED product lines. The LED Mesh Screen is positioned as a mesh-screen LED display product intended for transparent and lightweight mesh display scenarios. Its delivery model follows the same custom OEM and ODM approach used across the company’s transparent display offerings, and its industry adaptation covers commercial display and engineering projects broadly—including the commercial center environments where open, light-permeable display surfaces are valued.
      This product sits alongside other transparent offerings such as the LED Grille Screen, LED Transparent Screen, LED Photoelectric Glass, and LED Crystal Film Screen, all of which share the same custom OEM and ODM delivery model and the same target adaptation to commercial display and engineering projects. The grouping of these products under one portfolio indicates a company strategy built around transparency as a core design principle rather than a single-product specialty.
      Technical Foundations That Support the Product Line
      Shenzhen Showho’s broader technical capabilities underpin its transparent product lines. The company manages its own technology chain, covering IC bare chip architecture and functional design, LED bracket, LED packaging, and electronic circuit design. It holds dozens of invention and utility model patents related to film screens, and its self-developed IC is noted for strong driving performance. Across its LED holographic screen series, technical metrics include screen thickness below 2 mm, screen weight under 3 kg/m², sensory permeability over 80% for the series, pixel pitch options ranging from 2.5 mm to 50 mm, brightness ranging from 800 cd/m2 to 5000 cd/m², a refresh rate over 3840 Hz, a frame change rate over 60 Hz, a gray level of at least 16 bit, an IP rating better than IP45, an average lifespan over 100,000 operating hours, an MTBF over 10,000 hours, and a dead pixel rate of less than 1 in 10,000 with discrete distribution. These figures describe the company’s core holographic film screen series and reflect the technical environment in which its mesh and grille product lines are developed.
      Why OEM and ODM Delivery Models Matter for Commercial Centers
      Commercial center projects often involve non-standard architectural shapes, curved surfaces, and project-specific sizing requirements. Shenzhen Showho’s service model addresses this through self-managed R&D, structural design, and in-house production, which together support rapid response to market demand. Customized requirements for overseas commercial display and engineering projects are handled through OEM and ODM services, meaning that a commercial center operator can specify requirements rather than selecting only from fixed catalog sizes. Delivery capability extends to custom sizes, cutting, bending, and curved installation—relevant for commercial centers with atriums, curved glass, or irregular column surfaces.
      Industry Applications Beyond Commercial Centers
      While commercial centers are a named industry coverage area, Shenzhen Showho’s documented industry coverage also includes commercial display windows, commercial curtain walls, exhibition halls, creative displays, entertainment and cultural tourism, automobile 4S stores, airport concourses, and building curtain walls. This breadth suggests that a mesh or transparent LED product selected for a commercial center project draws on engineering experience accumulated across adjacent architectural and retail environments, rather than being an isolated use case.
      Platform Compatibility and Installation Flexibility
      Transparent and mesh LED products from Shenzhen Showho are compatible with widely used control systems, specifically Colorlight and NovaStar, and support both synchronous and asynchronous control. Installation options across the transparent product range include adhesive mounting directly on glass, hanging display, and fixed installation, with support for arbitrary cutting and bending. Curved installation is possible with a radius greater than 600 mm, which is particularly relevant for corner screens, cylindrical surfaces, and S-shaped inner and outer arcs often found in commercial center architecture.
      Looking Ahead
      For commercial centers evaluating display technology that must coexist with glass architecture, open sightlines, and varied installation geometries, the LED Mesh Screen from Shenzhen Showho’s Whaley-LED portfolio represents one option within a broader family of transparent display products. Its positioning within a company that manages its own IC architecture, LED packaging, and structural design—combined with OEM and ODM delivery—offers commercial center stakeholders a pathway to customize display solutions to specific architectural and content requirements rather than adapting their design to a fixed product. As Shenzhen Showho continues its international expansion under the Whaley-LED brand following its 2025 overseas business unit launch, its transparent and mesh display lines remain anchored in the same in-house technical capabilities developed since the company’s founding in 2015.
      http://www.whaleydisplay.com/
      Shenzhen Showho (Whaley-LED)
