MFB(Z)12-YC Series Wet-Type Solenoids for Hydraulic Valves: Selection and Application Guide
  • #17277
      In industrial hydraulic equipment, directional valves determine how hydraulic fluid is routed to control cylinders, motors, and other actuators. The solenoid is the component that converts an electrical command into the mechanical movement required to shift the valve. When machinery operates continuously or performs frequent switching cycles, solenoid reliability becomes an important part of overall hydraulic system performance.
      The MFB(Z)12-YC Series Wet-Type Solenoids for Valves are developed for hydraulic directional valve applications where stable electromagnetic actuation, smooth movement, and long operating cycles are required. Their oil-immersed construction allows hydraulic oil to provide both lubrication and heat-transfer functions, offering a practical approach for demanding industrial environments.
      What Is a Wet-Type Hydraulic Solenoid?
      A hydraulic solenoid creates electromagnetic force when its coil is energized. This force moves the internal core, allowing the associated directional valve to change position and redirect hydraulic flow.
      Wet-type solenoids differ from conventional dry structures because the moving electromagnetic components operate in an oil-filled environment. The surrounding hydraulic oil can reduce friction between moving parts while helping transfer heat away from components during operation.
      This design is particularly relevant to equipment where valves are actuated repeatedly. Instead of treating electromagnetic actuation, lubrication, and thermal management as completely separate concerns, the wet-type structure integrates these functions into the operating environment of the hydraulic valve.
      For manufacturers selecting solenoids for automated hydraulic machinery, the design can be especially useful when operating cycles are long and switching frequency is high.
      Why Solenoid Performance Affects Hydraulic Equipment
      A directional valve may appear to be a relatively simple component, but its switching behavior can directly influence the movement of the machine.
      If the solenoid does not generate sufficient or consistent electromagnetic force, the valve may not shift as expected. This can affect hydraulic pressure, actuator movement, positioning accuracy, clamping, lifting, pressing, and other machine functions.
      Industrial equipment also places different demands on solenoids depending on how frequently the valves operate. A valve used several times per hour has very different requirements from one controlled repeatedly throughout an automated production cycle.
      For applications such as CNC machinery, injection molding equipment, hydraulic presses, production automation systems, and heavy industrial machines, manufacturers should therefore evaluate the solenoid according to the complete operating cycle rather than considering electrical compatibility alone.
      Oil Immersion Provides Lubrication and Heat Dissipation
      One of the main characteristics of the MFB(Z)12-YC series is its wet-type construction.
      During operation, the internal moving core works in hydraulic oil. The oil helps reduce friction as the core moves, which can support smoother electromagnetic actuation and reduce mechanical wear associated with repeated movement.
      Heat management is another consideration. Energized coils naturally generate heat, particularly during extended operation or frequent switching. The oil environment can assist with transferring heat away from the electromagnetic assembly and into the surrounding hydraulic system.
      This combination of lubrication and heat dissipation makes wet-type solenoids an attractive option for hydraulic equipment that must operate for extended periods.
      The design can also contribute to smoother and quieter mechanical operation because the oil environment reduces direct friction and impact between moving components.
      MFB(Z)12-YC Series Model Options
      The series includes several models for use with corresponding hydraulic directional valve assemblies:
      • MFB12-37YC
      • MFZ12-37YC
      • MFZ12-90YC
      Although these products belong to the same wet-type solenoid series, model selection should be based on the actual valve and machine configuration.
      Before purchasing, equipment manufacturers should verify electrical specifications, mounting dimensions, valve compatibility, operating duty, and installation conditions. A solenoid that looks similar to the required component may still be unsuitable if its mechanical or electrical parameters do not match the valve.
      For OEM hydraulic equipment, confirming these details during the design stage can help prevent compatibility issues during final assembly.
      Stable Electromagnetic Force for Valve Switching
      The basic purpose of a hydraulic solenoid is to generate sufficient electromagnetic force to move the valve core or spool reliably.
      Consistent performance depends on several factors, including the magnetic circuit, core geometry, coil construction, material characteristics, and manufacturing tolerances. Small variations in these areas can affect the behavior of the finished component.
      The MFB(Z)12-YC series is designed for dependable electromagnetic actuation in hydraulic directional valve systems. The combination of electromagnetic design and oil-immersed operation helps support smooth movement during repeated switching.
      In automated machinery, this consistency is important because hydraulic actions often form part of a programmed sequence. A reliable valve transition helps maintain predictable movement from one machine cycle to the next.
      5
      Continuous-Duty Applications and Thermal Management
      Thermal performance deserves particular attention when selecting a solenoid for continuous-duty equipment.
      Every energized electromagnetic coil produces heat. When a machine repeatedly activates hydraulic valves, the cumulative thermal load can become more significant than in occasional-use applications.
      The wet structure of the MFB(Z)12-YC series allows hydraulic oil to participate in the thermal management process. At the same time, the same oil provides lubrication for the moving core.
      For equipment that runs through long shifts or performs frequent valve switching, these characteristics can help maintain more stable operating conditions.
      However, solenoid selection should still take into account the actual duty cycle, ambient temperature, hydraulic oil conditions, voltage, and valve configuration. Wet-type construction is an important design feature, but it does not replace application-specific engineering evaluation.
      Where Wet-Type Solenoids Can Be Used
      The MFB(Z)12-YC series can be considered for a variety of industrial hydraulic systems, including:
      • Hydraulic power units
      • CNC machine tools
      • Injection molding machines
      • Hydraulic presses
      • Industrial automation equipment
      • Metallurgical machinery
      • Construction machinery
      • Mining equipment
      • Material handling systems
      • Automated manufacturing lines
      In CNC equipment, hydraulic valves may control clamping or auxiliary movements. In injection molding machines, multiple hydraulic actions can occur sequentially, making reliable valve switching important to production consistency.
      Hydraulic presses and metallurgical equipment can place substantial demands on components because of their working loads. Construction and mining machinery may additionally experience vibration, dust, temperature changes, and other environmental stresses.
      The solenoid should therefore always be evaluated as part of the complete hydraulic system.
      How to Select a Hydraulic Valve Solenoid
      Selecting the correct solenoid begins with identifying the directional valve it needs to operate. Several technical factors should be reviewed before placing an order.
      1. Valve compatibility
      Confirm that the solenoid interface and dimensions match the hydraulic directional valve.
      2. Electrical requirements
      Check the rated voltage, coil configuration, control circuit, and other electrical parameters.
      3. Installation dimensions
      Mounting dimensions and available equipment space should be verified during mechanical design.
      4. Duty cycle
      Determine whether the solenoid will operate intermittently, continuously, or through frequent switching cycles.
      5. Operating environment
      Consider ambient temperature, vibration, dust, moisture, hydraulic oil characteristics, and other site conditions.
      6. Switching frequency
      Automated machinery may require substantially more switching cycles than manually operated equipment.
      7. Maintenance requirements
      The accessibility of the valve and solenoid should be considered when designing the equipment for long-term service.
      These factors provide a more reliable basis for product selection than choosing a solenoid solely according to nominal size or appearance.
      Wet-Type vs. Dry-Type Considerations
      The choice between wet-type and dry-type solenoid construction should be based on the hydraulic system and operating requirements.
      A wet-type structure is particularly suitable when the solenoid operates directly within a hydraulic oil environment. The oil can provide lubrication and assist with thermal transfer during operation.
      For equipment with frequent valve switching or long working cycles, these characteristics can be beneficial. In contrast, systems with different structural arrangements may require another solenoid configuration.
      The key point is that there is no universal solenoid design for every hydraulic machine. The valve construction, duty cycle, electrical control system, working fluid, and installation environment all need to be considered together.
      Manufacturing Consistency Matters
      Hydraulic solenoid performance is influenced not only by the product design but also by manufacturing consistency. Magnetic materials, core dimensions, coil winding, assembly tolerances, and inspection procedures can all affect electromagnetic behavior.
      Wuxi Huilifu Intelligent Technology Co., Ltd. focuses on the development, manufacturing, and sales of electromagnets and electromagnetic coils. Its capabilities are supported by experience in precision manufacturing and the use of high magnetic permeability materials.
      The company operates a standardized production facility of approximately 2,500 square meters, incorporating R&D, manufacturing, testing, and warehousing functions. Production and inspection equipment support component processing and performance verification.
      Its powder metallurgy capabilities and one-step forming technology are also applied to electromagnetic components. Such manufacturing methods can help improve consistency in magnetic components and support efficient utilization of magnetic energy.
      For hydraulic solenoids, manufacturing control is particularly important because electromagnetic performance is closely related to material characteristics, magnetic circuit geometry, coil construction, and dimensional accuracy.
      OEM and Customized Hydraulic Applications
      Hydraulic equipment manufacturers frequently have different requirements depending on machine structure and application.
      A compact automated machine may prioritize installation space and high switching frequency, while a large hydraulic press may focus more heavily on continuous operation and mechanical robustness. Mobile machinery can introduce additional requirements related to vibration and environmental conditions.
      For these applications, solenoid selection should be incorporated into the hydraulic valve and equipment design process from the beginning.
      MFB(Z)12-YC Series Wet-Type Solenoids for Valves can be evaluated according to the valve configuration, electrical control requirements, operating cycle, and actual working environment. For OEM projects, customized electromagnetic components can also provide an option when a standard configuration does not fully match the equipment design.
      Practical Checklist for Hydraulic Equipment Manufacturers
      Before integrating a hydraulic solenoid into production equipment, buyers and engineers can review the following points:
      • What hydraulic directional valve will the solenoid operate?
      • Does the mounting interface match?
      • What voltage and electrical configuration are required?
      • Is the application continuous-duty or intermittent?
      • How frequently will the valve switch?
      • What hydraulic oil and operating temperature will be involved?
      • Is the equipment exposed to vibration, dust, or other harsh conditions?
      • Is sufficient installation and maintenance space available?
      • Does the selected model match the required electromagnetic force and mechanical movement?
      • Are customized dimensions or electrical specifications required?
      Answering these questions early can reduce redesign work and help ensure that the solenoid performs as intended after installation.
      A Practical Solution for Industrial Hydraulic Control
      For hydraulic machinery operating through long production cycles, solenoid performance can have a direct influence on valve response and equipment reliability. Repeated electrical activation places demands on electromagnetic force, thermal management, mechanical movement, and component durability.
      The MFB(Z)12-YC Series Wet-Type Solenoids for Valves address these requirements through an oil-immersed design that combines electromagnetic actuation with lubrication and heat-transfer benefits. Models including MFB12-37YC, MFZ12-37YC, and MFZ12-90YC provide options for corresponding hydraulic directional valve configurations.
      Rather than selecting a solenoid based only on nominal specifications, manufacturers should evaluate the complete combination of valve compatibility, electrical parameters, duty cycle, switching frequency, hydraulic environment, and installation conditions.
      For equipment manufacturers and hydraulic system integrators seeking a wet-type electromagnetic solution for demanding valve applications, MFB(Z)12-YC Series Wet-Type Solenoids for Valves offer a practical option for continuous-duty industrial hydraulic control. Through the manufacturing and engineering capabilities of Wuxi Huilifu Intelligent Technology Co., Ltd., the series can be considered for both standard hydraulic equipment and OEM-oriented applications.
      http://www.huilishen.com
