MKP – Monopotassium Phosphate for Food, Fermentation and Industrial Applications
  • #17269
      Potassium and phosphorus are important components in many manufacturing and agricultural processes. When these nutrients need to be supplied in a highly water-soluble form without introducing nitrogen, Monopotassium Phosphate can be a practical choice. It is used across food processing, fermentation, animal nutrition, fertilizer production, hydroponics, and other industrial applications.
      The MKP – Monopotassium Phosphate offered by Wuhan Waking Lion Chemicals Co., Ltd. is available for different application requirements and quality grades. For international buyers, choosing the right MKP is not simply a matter of looking for a high-purity product. The intended use, applicable standard, impurity limits, solubility, pH, packaging, and supporting documentation should all be evaluated before purchase.
      What Is MKP – Monopotassium Phosphate?
      Monopotassium Phosphate, commonly abbreviated as MKP, is an inorganic compound with the chemical formula KH₂PO₄. It is also known as potassium dihydrogen phosphate and has CAS No. 7778-77-0 with a molecular weight of 136.09.
      One of its main advantages is that it provides both potassium and phosphorus in a water-soluble compound. This makes it useful when manufacturers need to introduce these two nutrients without adding nitrogen to the formulation.
      Depending on its grade and specification, MKP can be used as a nutrient source, acidity regulator, mineral ingredient, fermentation nutrient, or fertilizer raw material. The same chemical compound can be manufactured for different end uses, but food-grade, feed-grade, and industrial-grade products should not be considered automatically interchangeable.
      MKP in Food and Beverage Manufacturing
      Food-grade Monopotassium Phosphate can perform several functions in suitable food formulations. It may be used for acidity adjustment, moisture retention, mineral supplementation, and other formulation requirements depending on the specific product.
      Its good water solubility is particularly useful in liquid food and beverage systems. Ingredients that dissolve efficiently can help manufacturers maintain more consistent formulations and reduce the risk of undissolved material remaining in the finished mixture.
      MKP can also be used as a source of potassium and phosphorus in selected functional beverages and nutritional formulations. Where mineral content and acidity need to be controlled simultaneously, its combined nutrient composition can simplify ingredient selection.
      For food manufacturers, however, chemical purity alone is not enough. The product should comply with the food additive requirements applicable to the destination market and the specific formulation.
      Food-Grade MKP Specifications
      When purchasing food-grade MKP, quality teams should review the actual specification and supporting Certificate of Analysis rather than relying on general descriptions such as "high purity."
      Depending on the required market standard, food-grade MKP may comply with specifications such as GB1886.337-2021, FCC, and E340i.
      A representative specification includes:
      • MKP content: minimum 98.0% on a dry basis
      • Water-insoluble matter: maximum 0.2%
      • pH of a 10 g/L solution: approximately 4.2-4.7
      • Arsenic: maximum 3.0 mg/kg
      • Lead: maximum 2.0 mg/kg
      Other parameters and contaminant limits should be verified according to the applicable standard and purchasing specification.
      For international food ingredient procurement, buyers should request the relevant technical data sheet, Certificate of Analysis, safety documentation, and compliance information before placing a large order.
      Why MKP Is Used in Fermentation
      Microorganisms require a balanced supply of nutrients to grow and perform their intended metabolic functions. Phosphorus and potassium are both important nutrients in fermentation systems, making MKP a useful component of certain fermentation media.
      Because it supplies two nutrients in one water-soluble compound, MKP can simplify nutrient formulation for processes involving yeast, amino acids, enzymes, and other biotechnology products.
      In yeast production, phosphorus and potassium can contribute to microbial growth and cellular metabolism. In amino acid and enzyme fermentation, controlled nutrient availability is also important for maintaining a stable process environment.
      The correct addition level depends on the microorganism, medium composition, process conditions, and production objective. Manufacturers should therefore establish dosage through their own process requirements rather than applying one universal formula.
      MKP for Yeast, Amino Acid and Enzyme Production
      Fermentation manufacturers generally require raw materials with predictable composition and stable batch quality. Variations in purity or impurities can affect process consistency, particularly in large-scale production.
      MKP can be incorporated into nutrient solutions used for yeast cultivation and other fermentation processes. Its water solubility allows it to be handled as part of liquid nutrient systems.
      For industrial fermentation buyers, important purchasing factors can include:
      • MKP purity
      • Phosphorus and potassium content
      • Water solubility
      • pH
      • Impurity profile
      • Batch consistency
      • Packaging
      • TDS and CoA availability
      The final specification should be matched to the fermentation process and quality management requirements of the manufacturer.
      Food Grade vs Feed Grade vs Industrial Grade
      Although food, feed, and industrial MKP products are all based on KH₂PO₄, their quality controls and intended uses can be different.
      Food Grade
      Food-grade MKP is produced for food and beverage applications and must meet the applicable food additive requirements. Purity, contaminant limits, documentation, and regulatory compliance are important considerations.
      Feed Grade
      Feed-grade MKP is intended for animal nutrition. According to the supplied specification, it contains at least 98.0% MKP on a dry basis, with phosphorus around 22.3% and potassium around 28.0-32.0%.
      It can provide bioavailable phosphorus and potassium in livestock and poultry feed formulations.
      Industrial Grade
      Industrial-grade MKP follows specifications such as HG/T 4511-2013 and is commonly supplied in white crystal or powder form. It is used in fertilizer production, nutrient solutions, industrial biotechnology, and other technical applications.
      The grade should always correspond to the end use. An industrial-grade product should not be substituted for food-grade MKP merely because both have the same chemical formula.
      Industrial MKP as 0-52-34 Fertilizer
      One of the major agricultural applications of MKP is as a 0-52-34 fertilizer grade. The formulation supplies phosphorus and potassium while containing no nitrogen.
      This makes it suitable for applications where growers need to control nitrogen input while supplying phosphorus and potassium.
      Potential applications include:
      • Fertigation
      • Drip irrigation
      • Hydroponic cultivation
      • Foliar feeding
      • Controlled nutrient solutions
      • Specialty fertilizer formulations
      Phosphorus plays an important role in plant energy metabolism and root development, while potassium is associated with plant growth and crop quality. The high water solubility of MKP makes it convenient for nutrient solutions where accurate nutrient delivery is required.
      For agricultural use, buyers should review parameters such as MKP content, P₂O₅, K₂O, moisture, water-insoluble matter, pH, and solubility.
      How to Select MKP for Different Applications
      The first step in purchasing Monopotassium Phosphate is identifying the final application.
      For food and beverage production, buyers should focus on food-grade certification, purity, impurity limits, pH, applicable standards, and documentation.
      For fermentation, manufacturers should pay particular attention to solubility, nutrient composition, purity, process compatibility, and batch-to-batch consistency.
      For animal nutrition, feed-grade specifications, phosphorus and potassium content, contaminant limits, and feed-use documentation should be confirmed.
      For fertilizers, hydroponics, and fertigation, industrial-grade 0-52-34 MKP may be suitable. In these applications, nutrient content, water solubility, moisture, pH, and insoluble matter are important purchasing criteria.
      Packaging and Supply Requirements
      Packaging can become an important issue for companies purchasing MKP regularly or importing large quantities. The packaging format should protect the material during transportation and storage while matching the buyer's handling system.
      Available packaging can include 25 kg and 50 kg bags as well as 1,000 kg jumbo bags. Customized packaging may also be discussed according to customer requirements.
      For long-term procurement programs, buyers should also evaluate production capacity, delivery schedules, batch consistency, documentation, and the supplier's ability to maintain stable supply.
      Working with an Experienced Phosphate Supplier
      Wuhan Waking Lion Chemicals Co., Ltd. is a phosphate products manufacturer and exporter with production capabilities covering industrial, food, feed, pharmaceutical, electronic, and reagent grades.
      The company operates a production facility of approximately 200,000 square meters and has more than 400 employees, including nearly 100 technical professionals. Its reported production capabilities include approximately 150,000 tons of phosphoric acid and 200,000 tons of fine phosphates annually.
      For international customers, the company exports phosphate products to markets in Europe, the Americas, Southeast Asia, the Middle East, and other regions.
      Its quality and management certifications include ISO 9001, ISO 22000, ISO 14001, ISO 45001, ISO 50001, BRC, KOSHER, and HALAL, depending on the relevant production and application requirements.
      The supplier can also provide technical and shipping documentation such as TDS, SDS, CoA, and customs-related documents, which can be useful for international procurement and quality control.
      What Buyers Should Request Before Ordering
      A complete technical inquiry can help ensure that the supplied MKP matches the intended application.
      Before requesting a quotation, buyers should clarify:
      1. Required MKP grade
      2. End application
      3. Applicable standard
      4. Minimum purity
      5. pH requirements
      6. Water-insoluble matter limit
      7. Nutrient composition where applicable
      8. Heavy-metal and impurity limits
      9. Required packaging
      10. Order quantity
      11. Certificate and documentation requirements
      12. Destination market and shipping requirements
      For food, feed, and regulated applications, buyers should confirm compliance documentation before approving the raw material for production.
      Why Specification Matters More Than Purity Alone
      A common mistake in chemical sourcing is to compare products primarily by purity percentage. While purity is important, it does not fully describe whether a particular MKP product is suitable for a specific application.
      Two products can both have approximately 98% MKP content but have different standards, impurity profiles, documentation, packaging, and intended applications.
      For this reason, purchasing teams should compare the complete technical specification. The applicable standard, pH, insoluble matter, contaminant limits, nutrient content, CoA, and production consistency may be just as important as the headline purity figure.
      Final Considerations
      The MKP – Monopotassium Phosphate is a versatile source of potassium and phosphorus used in food manufacturing, fermentation, animal nutrition, fertilizer production, hydroponics, and other technical applications.
      Its high water solubility and combined potassium-phosphorus composition make it useful in formulations where these nutrients need to be introduced efficiently. However, selecting the appropriate grade is essential because food, feed, and industrial applications have different quality and regulatory requirements.
      For food and beverage manufacturers, food-grade MKP can support selected formulation and mineral-supplementation requirements. Fermentation producers can use it as a source of phosphorus and potassium, while feed-grade products are intended for animal nutrition. Industrial-grade MKP, including 0-52-34 fertilizer products, is widely relevant to agricultural and nutrient-solution applications.
      For companies evaluating international suppliers, MKP – Monopotassium Phosphate should be selected according to the complete technical specification rather than purity alone. By confirming the grade, applicable standard, impurity limits, documentation, packaging, and supply requirements in advance, buyers can select a phosphate material better suited to their production process. Wuhan Waking Lion Chemicals Co., Ltd. provides multiple phosphate grades and related supply capabilities for customers requiring MKP across food, fermentation, feed, agricultural, and industrial applications.
      http://www.xingshichemical.com
