Mobile SCADA Monitoring for More Flexible PV Plant O&M
  • #17524
      Operating a photovoltaic plant involves much more than watching a centralized monitoring screen. O&M engineers may be inspecting trackers, checking field equipment, moving between plant areas, visiting another site, or working outside normal office hours. During these activities, they still need access to current plant information when an unexpected event occurs.
      A fixed control-room workstation can provide detailed monitoring, but it cannot follow personnel around the site. This creates a practical gap between where plant information is available and where O&M work is actually being performed.
      The SolarTracker SCADA APP addresses this gap by extending essential PV monitoring functions to smartphones and tablets. With mobile access to plant data, alarm notifications, reports, and selected control functions, O&M personnel can remain connected to operating conditions without having to return to a desktop monitoring station every time they need an update.
      The Operational Gap Between the Plant and Control Room
      A utility-scale or commercial PV plant can cover a considerable physical area. The equipment being inspected may be far from the main control building, while the SCADA workstation remains in one fixed location.
      Consider a routine field inspection. A technician may discover an unusual tracker position or equipment condition and need to check whether the monitoring system has recorded a corresponding event. Walking back to the control room just to verify the latest data adds unnecessary time to the task.
      The same issue appears when an O&M manager is responsible for several plants. The person may not be physically present at the site when an alarm occurs, yet still needs to understand the situation and coordinate the next step.
      Mobile SCADA does not eliminate the central SCADA platform. Instead, it adds another access point for situations where personnel are away from the main workstation.
      Real-Time Information During Field Work
      Field inspections combine physical observation with operating data. A technician might see a mechanical issue, unusual tracker behavior, communication problem, or environmental condition and then need to compare those observations with the latest plant status.
      Having monitoring information available on a mobile device can make this process more direct.
      Instead of separating the physical inspection from the digital monitoring task, personnel can review relevant operating information while they are still in the field. This can help them determine whether an observed condition appears to be isolated, part of a larger plant event, or already reflected in the monitoring system.
      For large installations, the time saved by avoiding repeated trips to the control room can become meaningful over the course of daily maintenance activities.
      Alarm Notifications When Personnel Are Away
      A SCADA system may detect an abnormal condition immediately, but the response process depends on whether the responsible personnel become aware of it in time.
      Desktop-based monitoring often assumes that someone is actively watching the interface. In real O&M operations, however, staff may be performing inspections, attending meetings, traveling between sites, or handling other maintenance work.
      Mobile alarm push notifications provide another way to communicate important events.
      An O&M team member may receive an alert while:
      • Inspecting equipment in the field
      • Working in another section of the plant
      • Traveling between PV sites
      • Performing night-shift duties
      • Away from the control room
      • Managing several plants from a remote location
      The purpose is not to generate more notifications for their own sake. Effective alarm management is about getting relevant information to the right person quickly enough for an appropriate response to begin.
      From Alarm Detection to Operational Decision
      Receiving an alarm is only the first stage of fault handling. The next questions are usually more important: What happened? Is the event still active? Which equipment is affected? Does the situation require immediate intervention?
      When the operator is away from the control room, accessing this information can become the source of additional delay.
      A mobile SCADA interface can shorten this information path by allowing authorized personnel to review current plant conditions directly from a smartphone or tablet.
      Depending on the system configuration and operating procedures, selected remote control or parameter adjustment functions may also be available. These capabilities should always be used within established authorization and safety procedures. Remote access is not intended to replace physical intervention when an issue requires a technician on site.
      Its value lies in giving qualified personnel another option for assessing and responding to events without first returning to a fixed terminal.
      Making Routine O&M Less Dependent on Location
      Not every monitoring task involves an emergency. PV plant management also includes many small, repetitive activities.
      Managers may want to check current plant status before visiting a site. Engineers may need to confirm whether a previously reported issue has been resolved. Supervisors may review operating information at the end of a shift. Performance reports may need to be checked while traveling between locations.
      If every one of these tasks requires access to a dedicated workstation, the O&M workflow becomes unnecessarily location-dependent.
      Mobile access changes that workflow. Basic monitoring and reporting tasks can be performed from wherever the responsible person is working, provided the required network and system access are available.
      For organizations managing multiple PV plants, this flexibility can be particularly useful because operational awareness does not have to depend entirely on physical presence in one control room.
      Mobile Access for Night Operations
      PV generation is closely associated with daylight hours, but plant operation does not stop when the sun goes down. Communications, equipment status, alarms, control systems, and other plant functions may still require attention.
      Night-shift personnel may not need to remain continuously in front of a monitoring workstation. A mobile device can provide an additional channel for checking plant conditions and receiving important alerts.
      The same principle applies to emergency situations. When an abnormal event occurs outside normal working hours, the responsible engineer or manager may be away from the main monitoring station.
      A mobile notification can bring the event to their attention first. They can then review available plant information and determine whether the situation requires remote action, further investigation, or dispatching personnel to the site.
      This approach does not replace established emergency procedures. Rather, it can help the O&M team begin the assessment sooner.
      What Mobile SCADA Should Actually Provide
      A mobile application is most useful when it focuses on the information and functions that O&M personnel genuinely need outside the control room.
      For PV plant operations, several functions are particularly practical:
      Real-time plant data provides visibility into current operating conditions.
      Mobile alarm notifications help personnel become aware of important events without continuously watching a screen.
      Remote control and parameter adjustment can offer authorized users additional operational options when the system and procedures permit such actions.
      Daily and weekly reports allow managers to review plant information without returning to a desktop workstation.
      These functions serve different purposes, but together they create a mobile layer around the existing SCADA infrastructure.
      The objective is not to place every advanced SCADA function on a smartphone. A better approach is to make the most frequently needed operational information accessible in situations where personnel cannot conveniently use the main control-room system.
      Mobile SCADA as an Extension, Not a Replacement
      Centralized SCADA remains important for detailed plant supervision, historical analysis, configuration, and broader operational management. Mobile access serves a complementary role.
      The distinction matters because field conditions are different from control-room conditions. A technician standing beside a tracker has different information needs from an operator working at a dedicated monitoring workstation.
      A mobile interface should therefore prioritize quick access, relevant status information, notifications, and practical operational actions.
      This makes mobile monitoring particularly suitable for the moments between major O&M activities: before an inspection, during field work, while traveling, after an alarm, or when a manager needs a quick update.
      Supporting Multi-Site O&M Management
      As solar portfolios expand, O&M responsibilities are increasingly distributed across multiple locations. One team may supervise several PV plants, while individual technicians move between sites according to maintenance schedules.
      This operating model makes location-independent access more valuable.
      A mobile SCADA application can help managers maintain awareness of different plants without being physically present at each control room. At the same time, field engineers can access information from the site where they are currently working.
      This creates a more connected workflow between centralized supervision and local maintenance.
      The advantage is not simply convenience. Faster access to information can help teams prioritize tasks, identify which events require attention, and avoid unnecessary movement between different work areas.
      Developed Around Solar Tracking and Control Requirements
      The SolarTracker SCADA APP forms part of a broader solar tracking control approach developed by Shanghai SolarSurges Technology Co., Ltd. The company focuses on intelligent solar tracking solutions combining hardware, software, and AI-driven algorithms.
      With more than 10 years of industry experience, the company has developed proprietary technologies and patents related to tracking control. Its work emphasizes the practical relationship between control technology, equipment operation, and the conditions encountered by solar plants.
      For mobile SCADA, this practical perspective is important. The value of a mobile application is determined not by how many functions appear on the screen, but by whether those functions help O&M personnel make better decisions during actual plant operation.
      Practical Points When Introducing Mobile Monitoring
      Before deploying mobile SCADA access, plant operators should consider several operational factors.
      First, define which users need access and what each user is authorized to view or control. Not every O&M role requires the same permissions.
      Second, determine which alarms should trigger mobile notifications. Excessive notifications can reduce the value of an alarm system if personnel receive too many low-priority messages.
      Third, consider network availability across the plant and during off-site access. Mobile monitoring depends on reliable communication between the application and the underlying SCADA environment.
      Fourth, establish clear procedures for remote control. Any function that can affect equipment operation should be governed by appropriate authorization, safety requirements, and site procedures.
      Finally, evaluate the application based on actual O&M workflows rather than only on its feature list. The most useful mobile SCADA system is one that reduces friction during routine monitoring and helps personnel respond efficiently when abnormal conditions occur.
      A More Connected Approach to PV Plant O&M
      The physical size of a solar plant makes it unrealistic to expect O&M personnel to remain beside a monitoring workstation throughout the day. Engineers need to move, inspect equipment, coordinate maintenance, and sometimes manage several plants at once.
      Mobile SCADA provides a practical way to keep essential plant information within reach during these activities.
      With real-time monitoring, mobile alarm notifications, selected remote operating functions, and daily or weekly reports, SolarTracker SCADA APP can extend the reach of a PV plant's monitoring system beyond the control room.
      The central SCADA platform remains the foundation for plant management, while mobile access provides flexibility where field work and remote supervision demand it.
      For solar operators looking to make O&M workflows less dependent on a fixed location, mobile monitoring is not simply another interface. It is a way to connect plant data with the people responsible for acting on that information, wherever their work takes them.
      For more information about solar tracking control and related intelligent PV solutions, Shanghai SolarSurges Technology Co., Ltd provides technology covering solar tracking hardware, software, and control applications.
      http://www.solarsurges.com
