2026-08-31 at 7:59 pm #17395
Understanding the Power Reliability Challenge in Telecom and Broadband Networks
Network equipment such as routers, modems, and ONTs often reboot or lose service during short power outages, voltage drops, or unstable grid conditions. For telecom operators, Internet Service Providers (ISPs), broadband network companies, fiber network operators, and system integrators, this kind of service interruption directly affects subscriber experience and network uptime. Compounding the issue, improper UPS selection regarding voltage, current, peak load, or connectors can lead to application failure even after a backup power unit has been installed. This makes precise technical matching—not just product availability—the real determinant of a successful deployment.
MYLION: A Global B2B Partner for Mini UPS and DC Backup Power
Shanghai Mylion New Energy Co., Ltd., operating under the brand name MYLION, is a global B2B provider of Mini UPS products, DC backup power solutions, and project support for telecom, ISP, broadband, and security applications. Headquartered in Shanghai, China, with business coverage extending globally, MYLION positions itself as a B2B backup power partner and OEM/ODM project partner rather than a general consumer electronics seller. The company brings 13+ years of experience in lithium battery technology and 10+ years of experience in Mini UPS development, giving it a long-term technical foundation for addressing the specific reliability requirements of network-edge equipment.
MYLION’s differentiated approach centers on evaluating solutions based on real device voltage, working current, peak or startup behavior, and installation environment, followed by technical confirmation and connector or cable matching to reduce selection errors. This value proposition—supporting more reliable DC backup deployment and reducing avoidable selection risks—is particularly relevant for professional project customers who cannot afford trial-and-error deployments across large subscriber bases.
Engineering High-Power 12V Mini UPS Solutions for Demanding Loads
Within its 12V product architecture, MYLION offers a dedicated High-Power Series and a High-Power Long-Runtime Series designed specifically for equipment that exceeds standard current thresholds.
MU65W: High-Power Series for Heavy-Load CPE and Gateways
The MU65W is positioned as a 12V high-power Mini UPS built to address high-load CPE or gateways that exceed standard 2.5A thresholds. It supports a 12V DC input of up to 6A and delivers a 12V DC output of 4A continuous, 5A maximum, for a total of 60W. Its battery energy capacity is 56.16Wh. This combination of high continuous current and substantial input headroom makes the MU65W suitable for high-performance WiFi equipment and storage-integrated gateways, where power draw is significantly higher than that of basic routers or ONTs.
MU35W / MU35L: Combining High Output with Extended Battery Capacity
For scenarios that demand both high current and extended runtime, MYLION’s MU35W and MU35L models form the 12V High-Power Long-Runtime Series. These units support 4A continuous output with 5A maximum, matching the MU65W’s current capability, while offering a larger 75.6Wh battery energy capacity. This pairing of performance and duration is intended for professional gateways requiring high peak current and long backup time, an important consideration for remote installations or areas prone to extended outages.
Beyond Standard Backup: Multi-Output and AC-Input Options
While the high-power series addresses single-device, high-current needs, MYLION also maintains a 12V + USB Multi-Output Series for installations where a router and a USB-powered accessory must be backed up simultaneously. The MUJ46 model, for example, provides a 12V DC output of 1.5A continuous and 2A maximum, alongside dual 5V/3A USB-A and USB-C outputs, within an 18W maximum total output limit and a 37.44Wh battery. The MUJ435 variant extends this to a 50.4Wh battery for longer-runtime multi-port use.
For deployments involving two separate 12V devices, such as a combined ONT and router installation, the AC-Input Dual Output Series—represented by the ML1202AC—accepts 100–240V AC input and delivers two independent 12V DC outputs at 2A each, within a 24W total system limit, using LiFePO4 battery chemistry and 25.6Wh of energy. This design simplifies deployment by removing the need for an external DC adapter.
Technical Rigor Behind Every MYLION Mini UPS
MYLION’s overall Mini UPS portfolio covers 12V DC systems up to 60W, LiFePO4 chemistry integration, and emerging USB-C PD 100W input/65W output capabilities, reflecting a technical scope that spans both established and next-generation power requirements. All products are compatible with routers, ONTs, ONUs, modems, gateways, CPE devices, and security or CCTV equipment, subject to electrical verification—an important caveat that underscores MYLION’s emphasis on confirming voltage and current compatibility before deployment rather than assuming universal fit.
On the compliance side, MYLION adheres to lithium battery transport documentation and model-specific compliance requirements, including UN38.3 and MSDS certifications where applicable to the specific model. This attention to documentation is particularly relevant for B2B customers managing cross-border shipments of lithium-based backup power products.
Service Model: From Requirement Analysis to Mass Production
MYLION’s service capabilities are structured around B2B project support, OEM/ODM services, and sample validation. The scope of service includes requirement analysis, model matching, sample testing support, connector and cable matching, private labeling, and documentation coordination. This end-to-end process is designed to guide project customers from initial technical evaluation through managed pilot evaluation and into mass-production preparation, reducing the friction commonly associated with sourcing specialized DC backup hardware.
Pricing follows a custom enterprise and project-based quote model rather than fixed retail pricing, reflecting the company’s focus on tailored deployments rather than one-size-fits-all consumer sales. Deployment itself is handled through device-side hardware installation for subscriber-side equipment, with after-sales support covering technical evaluation, model matching, and project-specific documentation coordination.
Why Global ISPs and System Integrators Choose MYLION
MYLION serves telecom operators, Internet Service Providers, system integrators, distributors, brand owners, and OEM/ODM customers across the telecom, ISP, broadband, fiber networking, and security industries. Its technology partnerships with network equipment companies and fiber network operators further reinforce its role as a B2B partner for global ISP and broadband customer-premises deployments.
For organizations evaluating high-power 12V Mini UPS options, MYLION’s combination of technical verification, model-specific documentation, and OEM/ODM project support—paired with specific high-current models like the MU65W, MU35W, and MU35L—offers a structured pathway to more dependable DC backup power for demanding network equipment. As development continues on directions such as the MUC85 USB-C PD Mini UPS and the MU248 24V/48V telecom backup platform, MYLION’s product matrix continues to expand in step with evolving network hardware requirements.
http://www.myliontech.com
Shanghai Mylion New Energy Co.,Ltd. -
