MYLION Mini UPS Network Backup Power: A Complete 2026 Guide
  • #18505
      Understanding the Network Outage Problem
      Short power outages, voltage drops, and unstable grid conditions are a persistent challenge for network equipment such as routers, modems, and ONTs. These devices often reboot or lose service entirely when power is interrupted, even briefly. For telecom operators, Internet Service Providers (ISPs), broadband network companies, fiber network operators, and system integrators, this translates into service interruptions, support tickets, and dissatisfied end users. Compounding the issue, improper UPS selection — mismatched voltage, current, peak load, or connector type — can cause application failure even when a backup unit is installed. This is the core pain point that Shanghai Mylion New Energy Co., Ltd., operating under the brand MYLION, was built to solve.
      Why Mini UPS Matters for Network Backup Power
      A Mini UPS is a compact DC backup power solution designed specifically for customer-premises network equipment. Unlike traditional UPS systems built for large appliances, Mini UPS products are engineered to match the exact electrical profile of routers, ONTs, ONUs, modems, gateways, CPE devices, and security or CCTV equipment. Selecting the right unit requires evaluating real device voltage, working current, peak/startup behavior, and the installation environment — then confirming connector and cable compatibility to reduce selection errors. This is precisely the differentiated approach that MYLION applies to every project: technical confirmation and connector/cable matching before deployment, not after.
      MYLION’s Position in the Global B2B Market
      MYLION operates as a global B2B provider of Mini UPS products, DC backup power solutions, and project support for telecom, ISP, broadband, and security applications. Headquartered in Shanghai, China, the company serves customers worldwide and functions both as a B2B backup power partner and an OEM/ODM project partner. This dual role allows MYLION to support everything from initial requirement analysis and model matching to sample testing, private labeling, and documentation coordination for mass production.
      The company brings 13+ years of experience in Lithium Battery technology and 10+ years of experience in Mini UPS development to its project engagements. This background underpins its ability to evaluate solutions based on actual device behavior rather than generic specifications, helping professional project customers avoid avoidable selection risks and deploy more reliable DC backup power.
      A Product Matrix Built Around Real-World Load Profiles
      MYLION’s product portfolio spans ten products organized into distinct series, each addressing a specific category of network backup need.
      12V Standard Series
      The MU26W, MU48W, and MU68W form the entry-level to mainstream backup tier. The MU26W delivers 2.5A continuous / 3A maximum 12V DC output with 18.72Wh of battery energy, using a DC5521 input and DC5525 output — suitable for telecom, ISP, and home networking equipment. The MU48W steps up to 29.6Wh with a center-positive DC5525 output for ISP and broadband network equipment, while the MU68W extends capacity further to 44.4Wh with a maximum 36W output (12V/3A) for professional ISP projects.
      12V Long-Runtime Series
      The MU635W / MU635L models carry 75.6Wh of battery energy while maintaining the same 2.5A continuous / 3A maximum 12V DC output, built for long-duration power outages in residential or remote areas.
      12V High-Power Series
      The MU65W is engineered for high-load CPE or gateways that exceed standard 2.5A thresholds. It accepts up to 6A of 12V DC input and outputs 4A continuous / 5A maximum (60W total), backed by 56.16Wh of battery energy — suited to high-performance WiFi equipment and storage-integrated gateways.
      12V High-Power Long-Runtime Series
      The MU35W / MU35L combine 60W output capability with 75.6Wh capacity, targeting professional gateways that require both high peak current and long backup time.
      12V + USB Multi-Output Series
      The MUJ46 and MUJ435 address the need to power a router and a USB accessory simultaneously. The MUJ46 provides 1.5A continuous / 2A maximum 12V DC output plus dual 5V/3A USB-A and USB-C outputs within an 18W total system limit, with 37.44Wh battery energy — ideal for small office/home office (SOHO) setups. The MUJ435 extends battery energy to 50.4Wh while keeping the same 12V DC + 5V USB-A + 5V USB-C port configuration and 18W system limit.
      AC-Input Dual Output Series
      The ML1202AC uses LiFePO4 battery chemistry with a 100–240V AC input and two 12V DC output ports (2A each, 24W total system limit), plus 25.6Wh of battery energy. It simplifies deployment for ONT + Router combined installations by removing the need for an external DC adapter.
      Development and Project-Evaluation Directions
      Looking ahead, MYLION is evaluating the MUC85, a USB-C PD Mini UPS for modern WiFi 6/7 devices requiring USB-C Power Delivery, with 65W standard / 100W max input, dual USB-C outputs (up to 20V/3.25A and up to 12V/2.5A), and 92.16Wh battery energy. Also under development is the MU248, targeting the 24V/48V telecom backup direction for higher-voltage wireless CPE and radio bridge equipment, built on LiFePO4 chemistry with 48V/60V DC input, independent 24V (3A) and 48V (1A) outputs, a 100W system limit, and 102.4Wh battery energy. Both remain in project evaluation stages.
      Technical and Service Capabilities Behind the Products
      MYLION’s technical capability centers on proprietary R&D in Mini DC UPS technical content and ISP/broadband backup power applications. Its portfolio spans 12V DC systems up to 60W, LiFePO4 chemistry integration, and emerging USB-C PD 100W input/65W output capabilities. On compliance, MYLION adheres to lithium battery transport documentation and model-specific requirements, including UN38.3 and MSDS certifications where applicable to specific models.
      On the service side, MYLION supports B2B project engagements, OEM/ODM services, and sample validation. This includes requirement analysis, model matching, sample testing support, connector/cable matching, private labeling, and documentation coordination — covering the full path from managed pilot evaluation through mass-production preparation.
      Who Benefits From MYLION’s Approach
      MYLION’s coverage spans telecom, ISP, broadband, fiber networking, and security industries, serving telecom operators, Internet Service Providers, system integrators, distributors, brand owners, and OEM/ODM customers. Platform compatibility extends to routers, ONTs, ONUs, modems, gateways, CPE devices, and security/CCTV equipment, subject to electrical verification for each deployment.
      Pricing follows a custom enterprise and project-based quote model, reflecting the technical, project-driven nature of each engagement. Deployment typically involves device-side hardware installation for subscriber-side equipment, supported by after-sales technical evaluation, model matching, and project-specific documentation coordination.
      A Practical Path Forward
      For organizations facing network equipment downtime during power interruptions, the underlying issue is rarely a lack of UPS options — it is the mismatch between generic backup products and the specific voltage, current, and connector requirements of the equipment being protected. MYLION’s approach of evaluating real device behavior before recommending a model, combined with a structured product matrix covering standard, long-runtime, high-power, multi-output, AC-input, and emerging high-voltage directions, positions the company as a structured resource for project teams evaluating DC backup power for telecom, ISP, broadband, and security applications. More information is available at http://www.myliontech.com.
      Shanghai Mylion New Energy Co.,Ltd.
