2026-08-21 at 11:50 am #17266
As utility-scale photovoltaic plants continue to expand, solar tracking systems are becoming increasingly dependent on real-time data, reliable communications, and automated decision-making. A modern tracker controller needs to do more than calculate panel angles. It must also respond to environmental conditions, coordinate distributed field devices, detect abnormal situations, and maintain stable communication across large PV sites.
The Network Control Unit (NCU) is designed to address these requirements through an edge-computing architecture. Instead of acting only as a communication interface between tracking equipment and an upper-level SCADA platform, the NCU processes important field information locally and supports operational decisions closer to the actual tracking equipment.
Why Edge Computing Is Valuable for Solar Tracker Control
A large photovoltaic plant may contain thousands of tracker units operating across an extensive geographic area. Each unit can generate continuous information related to position, motor status, communication conditions, sensor readings, and environmental parameters.
Traditional architectures may transfer substantial amounts of this information to centralized servers before processing. While cloud platforms remain valuable for supervision, reporting, and historical analysis, relying entirely on remote processing can introduce communication delays and increase dependence on network availability.
An edge-based architecture creates a more responsive workflow:
Sensors and field devices → NCU local processing → tracker control decisions → SCADA/cloud communication
With this structure, time-sensitive information can be analyzed locally while higher-level systems receive processed and relevant operational data. This can help reduce unnecessary communication traffic while keeping important control functions closer to the field.
From Data Collection to Intelligent Local Control
A conventional gateway mainly transfers information between different systems. The NCU takes a more active role by using embedded algorithms to process field data and support control decisions.
Real-time data aggregation, abnormal-condition identification, and operating-state management can therefore be handled closer to the tracking equipment.
The NCU supports multiple operating modes, including Auto, Fault, Night, Fixed Angle, Heavy Rain, Strong Wind, Heavy Snow, Maintenance, Stop, and Farm modes. These operating states allow the tracking system to respond differently according to weather conditions, maintenance activities, production requirements, or abnormal situations.
This distributed approach also creates a clearer division between field control and plant-level management. The NCU can handle rapid operational logic locally, while SCADA and cloud platforms remain responsible for visualization, centralized supervision, historical records, and broader plant management.
Connecting Weather Data with Tracker Protection
Weather conditions can change quickly and directly affect the operating strategy of solar trackers. Wind, rainfall, snow, temperature, humidity, and solar irradiation are all useful parameters when determining how a tracker should operate.
The NCU can connect with intelligent weather stations and meteorological sensors to obtain environmental information. Parameters such as wind speed, wind direction, rainfall, snow depth, temperature, humidity, and solar radiation can be incorporated into the tracking control architecture.
For example, when wind conditions approach a predefined protection threshold, the system can use the available weather information as part of its control logic. Local processing allows the relevant data to be evaluated at the site rather than requiring every sensor value to travel to a remote platform first.
Optional wind-speed and wind-direction protection functions provide additional flexibility for projects where tracker protection strategies need to be adapted to local environmental conditions.
Communication Options for Large PV Sites
A solar tracking network must remain reliable even when equipment is distributed over a large area. Different project sites can have very different requirements for wireless coverage, wired infrastructure, network topology, and communication distance.
The Network Control Unit (NCU) supports several communication technologies, including Sub-1GHz, LoRa Mesh, RS485, 4G, and Ethernet. Communication protocols such as Modbus RTU and MQTT are also supported.
This combination allows system designers to select communication methods according to the actual PV plant layout and project requirements.
Wireless networking can be particularly useful when deploying a large number of tracking units. Rather than configuring every TCU as an isolated device, the NCU can provide a higher-level networking point for the tracker system.
This can simplify commissioning and provide maintenance teams with a more centralized method for diagnosing communication problems, changing parameters, and managing system upgrades.
Centralized Parameter Management and OTA Updates
Managing thousands of individual tracker controllers manually can create a considerable maintenance workload. Even relatively simple parameter changes can become inefficient when technicians need to access each field device separately.
The NCU supports bulk parameter modification, allowing multiple settings to be managed in a more centralized manner. This can be useful during initial commissioning, debugging, preventive maintenance, and system optimization.
OTA capabilities are another practical feature. NCU OTA and TCU OTA functions support wireless software updates, reducing the need for repeated physical access to field equipment.
Historical data query functions can also assist with troubleshooting and operational analysis. Maintenance teams can use recorded information to investigate system behavior rather than relying entirely on on-site inspection.
For large PV plants, these functions can turn tracker management from a device-by-device process into a more coordinated network-level workflow.
GPS and Tracking Accuracy
Precise positioning is fundamental to solar tracking. The control system needs accurate location and time information to calculate the expected solar position and determine the appropriate tracker angle.
The NCU supports GPS connectivity and works with astronomical algorithms and position-sensor-based control methods. Its specified tracking accuracy is below ±1°.
Combining astronomical calculations with actual position feedback provides a practical approach to maintaining tracker positioning throughout changing solar conditions.
GPS can also contribute to consistency across large installations, particularly when many trackers are distributed across a geographically extensive project. Accurate time and location information helps establish a common reference for coordinated tracking operations.
NCU vs. a Conventional Communication Gateway
The most significant difference between an edge computing controller and a basic communication gateway is how data is handled.
A conventional gateway primarily forwards information. An edge controller can analyze information, execute embedded logic, identify abnormal conditions, and participate directly in equipment control.
For a solar tracking application, this distinction can be important.
The NCU can collect information from field devices, process relevant data, execute control algorithms, coordinate tracker-related operations, and then send meaningful information to SCADA or cloud platforms.
Instead of continuously transferring every raw data point, the system can prioritize information that is operationally relevant. This can make communication more efficient while giving centralized platforms cleaner and more useful information.
In other words, edge computing does not eliminate SCADA or cloud management. It gives field-level control and centralized management different responsibilities.
Designed for Outdoor PV Operating Conditions
Solar tracker controllers operate in outdoor environments where temperature, dust, humidity, and other conditions can vary considerably. Hardware specifications therefore need to reflect actual PV site requirements.
The NCU supports an ambient operating temperature range of -30°C to 60°C, an IP65 protection rating, and operation at altitudes below 4,000 meters. It can operate with either 220VAC or 24VDC power supplies.
These specifications allow the controller to be considered for a wide range of outdoor photovoltaic projects, including installations exposed to significant temperature fluctuations and demanding environmental conditions.
For developers and EPC companies, environmental specifications should still be evaluated together with the complete installation design, including enclosure placement, power distribution, communication infrastructure, and local weather conditions.
SolarSurges' Focus on Intelligent Tracking Technology
The development of an edge controller requires expertise in more than traditional electrical control. Embedded software, communication technologies, power electronics, data processing, and tracking algorithms all contribute to the performance of the overall system.
Shanghai SolarSurges Technology Co., Ltd focuses on intelligent solar tracking technologies by combining power electronics, embedded systems, AI algorithms, and communication engineering.
The company develops integrated hardware and software solutions for photovoltaic tracking applications and has deployed its TCU solutions across more than 30 PV plants. Its development approach emphasizes improved tracking algorithms, intelligent control, and reliable operation in demanding outdoor environments.
For PV developers and system integrators, this type of integrated engineering capability can be useful when evaluating a controller as part of a complete tracking architecture rather than as an isolated electronic component.
How an NCU Can Support Future PV Plant Operations
As photovoltaic installations become larger, the number of field devices and the volume of operational data will continue to increase. This creates several challenges for plant operators, including communication management, fault detection, weather response, software maintenance, and centralized parameter control.
An edge-based Network Control Unit provides one way to manage these challenges.
By processing selected information locally, the NCU can reduce dependence on remote communication for time-sensitive decisions. Its communication interfaces allow integration with different network structures, while GPS, weather-station connectivity, OTA upgrades, bulk parameter management, and multiple operating modes provide additional functionality for large-scale tracking systems.
The broader value of the NCU is therefore not simply faster data transmission. It is the ability to create a more distributed control architecture in which local equipment can make appropriate decisions while SCADA and cloud platforms focus on plant-wide supervision and analysis.
Final Considerations for Solar Tracking Developers
When selecting a tracking controller, developers should consider more than tracking-angle accuracy. Communication architecture, weather protection logic, field networking, maintenance methods, software updates, environmental resistance, power supply, and integration with SCADA all influence long-term system performance.
The Network Control Unit (NCU) provides an edge-computing approach for solar tracking applications, combining local data processing with multi-protocol communication, environmental monitoring integration, GPS connectivity, OTA management, and centralized tracker parameter control.
For utility-scale PV projects seeking a more responsive and maintainable tracking architecture, Network Control Unit (NCU) technology can help bridge the gap between distributed field equipment and centralized plant management. By bringing selected intelligence closer to the trackers themselves, it provides a practical foundation for building more efficient, connected, and resilient solar tracking systems.
http://www.solarsurges.com
Shanghai SolarSurges Technology Co., Ltd -
