2026-04-10 at 3:40 pm #15736
In today’s multi-device world, people rarely rely on just one screen. A typical day might involve watching TV in the evening, working or learning on a computer, and enjoying music or videos on a smartphone. However, many headphones are designed with only one of these use cases in mind, forcing users to switch devices—or even headsets—throughout the day.
The ARKON BH980E is built to solve this problem. By combining dual wireless technologies and practical design features, it offers a seamless listening experience across TV, PC, and mobile devices.
Designed for Modern Listening Habits
Different devices demand different audio performance. TVs and PCs often require stable, low-latency connections to keep sound in sync with visuals, while mobile devices prioritize convenience and quick pairing.
The BH980E addresses both needs through a dual-mode system. It supports 2.4GHz wireless transmission for stable, home-based listening, and Bluetooth for flexible mobile use. This means users can rely on a single headset instead of juggling multiple devices.
Dual-Mode Connectivity: Practical, Not Just Technical
The combination of 2.4G and Bluetooth is more than just a feature—it directly impacts everyday usability.
2.4GHz mode delivers consistent, low-latency audio, ideal for watching TV or using a computer
Bluetooth mode ensures easy connection with smartphones and tablets
This flexibility allows users to move between different environments without changing their listening setup, simplifying daily routines.
Flexible Connectivity with Multi-Interface Support
Compatibility is often a challenge with wireless audio devices. Some setups rely on modern USB-C ports, while others still use traditional 3.5mm audio jacks.
The BH980E includes a dongle that supports both interfaces, making it adaptable to a wide range of devices—from older TVs to newer laptops and mobile devices. This design reduces the need for extra adapters and makes switching between devices more convenient.
Charge While You Listen
One standout feature of the BH980E is its ability to charge a phone or tablet while the dongle is in use. This solves a common frustration where a single port must handle both audio output and charging.
With this feature, users can:
Watch long videos without worrying about battery life
Use their phone as a media source while keeping it powered
Enjoy uninterrupted listening during extended sessions
This small but thoughtful detail significantly improves real-world usability.
Built for Multi-Device Compatibility
The BH980E is designed to work seamlessly with TVs, PCs, smartphones, and tablets. Instead of being optimized for a single environment, it functions as an all-in-one audio solution.
This makes it especially useful in households where multiple devices are used daily, allowing one headset to serve different users and purposes without complicated setup.
Balanced Performance for Everyday Use
The specifications of the BH980E reflect a balance between sound quality and endurance:
40mm drivers for full-range audio
Frequency response of 20Hz–20kHz for complete sound coverage
Low distortion (0.03%) for clean playback
30-hour battery life for extended use
In practical terms, this means clear dialogue for TV viewing, immersive sound for movies, and reliable performance for music and everyday listening.
Real-Life Usage Scenarios
The strength of the BH980E becomes clear in everyday situations:
Evening TV, daytime mobile use: Switch from 2.4G mode to Bluetooth without changing headphones
Tablet streaming sessions: Keep the device charged while watching content
PC learning or work: Maintain stable audio during long sessions
Shared environments: One headset works across multiple devices and users
These scenarios highlight how the BH980E is designed around real usage patterns rather than isolated features.
The ARKON BH980E is more than just a wireless headphone—it’s a practical solution for people who use multiple devices throughout the day. By combining dual-mode connectivity, flexible interfaces, and user-focused features like pass-through charging, it simplifies the listening experience across different environments.
For users who want one reliable headset for TV, PC, and mobile use, the BH980E offers a well-rounded and convenient choice.
http://www.arkon.com.hk
ARKON -
