Orchard Anti Hail Netting DAHN-B50P/3*9
  • #1914
      https://www.dagongnets.com/Anti-hail-Net-DAHN-B50P.html
      REASONS TO CHOOSE DAHN-B50P/3*9:
      1.Easy for installation. Flexible, light, strong and easy to spread, and can be placed on trees with a simple support.
      2.Less damage to plants. Hailstones which is bigger than the mesh can be intercepted directly while smaller hailstones can be decelerated by DAHN. And DAHN will not affect the sunlight which is important to the growth of plants.
      3.Various functions. DAHN can prevent damage from not only hailstones but also frost and pollen.
      PRODUCT SPECIFICATIONS:
      Material Weave Color Measure Wire Diameter Weight/m² Shade Rate Warp Density Weft Density Mesh Size UV Radiation Warranty Reinforce Package
      HDPE Plain Weave Black 4*200m 700D 50g 3*9mm Yes Plastic Bag
      Orchard anti-hail netting is a protective net specially used for fruit tree planting. It can effectively prevent hail damage to fruits. At the same time, it can also provide sunshade, moisturizing, and wind protection, which is beneficial to the growth and development of fruits.
      Advantages of orchard anti hail netting
      1. Remarkable anti-hail effect
      Orchard anti hail netting is made of high-strength polyethylene material, which has strong tensile strength and wear resistance, and can effectively prevent hail damage to fruits. At the same time, the mesh size of orchard anti hail netting is moderate, which can prevent hail damage without affecting the growth and development of fruits.
      2. Multifunctional protection
      In addition to anti-hail, orchard anti-hail netting can also function as sunshade, moisturizing, and windproof. In the hot summer, orchard anti-hail netting can effectively shade the sun, reduce the evaporation of the fruit, maintain the moisture of the fruit, and is beneficial to the growth and development of the fruit. At the same time, orchard anti hail netting can also prevent strong winds from attacking fruit trees and protect the fruits from damage.
      3. Easy to install
      Dagong is an orchard anti hail netting manufacturer. The anti-hail net adopts the Plain Weave design. The installation of the plain weave anti-hail net is very simple. You only need to cover the net above the fruit trees and then fix it with ropes or clips. The installation process of plain weave anti hail net is quick and easy.
      4. Strong durability
      orchard anti hail netting can be used for a long time without breaking or deforming. At the same time, the color of orchard anti hail netting is bright, not easy to fade, and can remain beautiful for a long time.
      In short, orchard anti-hail netting is a very practical fruit tree protection net. It can effectively prevent hail damage to fruits, and at the same time, it can also play the role of sunshade, moisturizing, and windproof, which is beneficial to the growth and development of fruits. If you are a fruit tree grower, consider using orchard anti hail netting to protect your fruit.
      Vivi
      joe@dagongnets.com
