2026-07-17 at 2:50 pm #16795
Understanding technical frameworks, test requirements and procurement boundaries across railway markets
Note: This technical overview reflects information checked through July 2026. It does not replace official standards, project specifications or contractual documents.
Rail fastening systems directly affect rail positioning, gauge retention, load transfer, vibration control and electrical insulation. In international railway projects, the same fastening name does not necessarily mean the same technical requirements. A system supplied to different markets may be subject to different performance categories, test methods, material rules and acceptance documents.
AREMA, DIN, BS, UIC, GOST and GB are frequently referenced in enquiries, drawings and technical agreements. However, they are not six interchangeable product standards that can be matched clause by clause. Understanding the role of each framework is the first step toward reliable selection, quotation, sample approval and production delivery.
Why These Standard Systems Are Not Directly Interchangeable
A rail fastening project is normally governed by several layers: industry standards, national standards, infrastructure-manager specifications, approved drawings and contract requirements. AREMA is closely associated with North American railway engineering practice and recommended guidance. DIN and BS are the German and British national standards systems and commonly adopt EN or EN ISO documents. UIC provides internationally harmonized railway solutions and guidance. GOST covers interstate and national standardization across parts of the Eurasian market. GB is China's national standards system, while many railway-specific fastening requirements are issued as TB/T railway industry standards.
For this reason, statements such as 'to DIN', 'according to AREMA' or 'GB compliant' are not complete purchasing requirements. The standard number, edition year, applicable component, track structure, required tests and acceptance criteria should also be identified.
The Main Role of Each Framework
AREMA: A Key Reference for North American Railway Engineering
AREMA is the American Railway Engineering and Maintenance-of-Way Association. Its Manual for Railway Engineering covers the design, construction and maintenance of railway infrastructure, with Chapter 5 dedicated to Track. In North American projects, AREMA documents are often used together with railroad standards, owner specifications, procurement drawings and approved samples.
For fastening supply, AREMA-related requirements must be interpreted in the context of rail section, sleeper or tie type, track gauge, axle load, route class, curvature and the infrastructure manager's own specifications. Compliance with a general material grade or bolt property class alone does not demonstrate the suitability of a complete fastening system.
DIN: German Standards and National Adoption of EN/ISO Documents
DIN is the German standards system. In rail fastening projects, a DIN reference may identify a component standard for bolts, nuts or washers, or a German adoption of a European or international standard. Examples include the DIN EN 13481 series for fastening-system performance requirements and the DIN EN ISO 22074 series for fastening-system test methods.
DIN EN 13481 is divided by applications such as concrete sleepers, wood sleepers, steel sleepers, ballastless track, and special systems for switches and crossings. Its focus is the performance and type approval of the complete assembly. At the same time, parts of the former EN 13146 test-method framework are transitioning in some markets toward EN ISO 22074. The current status of each part must therefore be checked rather than copied from an older test report.
BS: British National Adoption and Project Requirements
BS is the British standards system. British rail fastening projects may reference BS EN 13481, BS EN 13146 or BS EN ISO 22074 documents. These publications are closely related to the corresponding EN or ISO technical frameworks, but their British publication dates, withdrawal status, national forewords and project additions still require separate confirmation through BSI and the purchasing specification.
Even where DIN EN and BS EN adopt the same European technical basis, a supplier should not simply change the prefix in a quotation. The edition year, scope, test-report reference and purchaser requirements for certification or laboratory competence must be reviewed.
UIC: International Railway Harmonization and Technical Guidance
UIC is the International Union of Railways. Through International Railway Solutions (IRS) and the historical UIC Leaflets, UIC provides harmonized solutions, recommendations and assessment frameworks for railway design, construction, operation and maintenance. Some component enquiries continue to refer to UIC publications or related supply specifications.
UIC documents have broad international engineering influence, but they do not automatically replace national regulations, national standards or infrastructure-manager specifications. Any UIC reference should identify the publication number, edition, applicable product and inspection requirements.
GOST: An Important Framework in Eurasian Railway Markets
GOST includes interstate standards and national adoptions used across parts of the Eurasian region. In 1520 mm gauge railway markets, fastening standards may define the applicable track structure, component form, safety performance and control methods. For example, GOST 32698-2014 addresses safety requirements and control methods for intermediate fastenings on concrete sleepers, while GOST 34078-2017 concerns rail fastening pads.
Procurement documents must also distinguish between GOST, GOST R and the adoption status in the destination country. A reference may be revised, replaced or withdrawn over time, so standards cited in old drawings, certificates or historical quotations should be checked again.
GB and TB/T: National and Railway Industry Standards in China
GB and GB/T identify mandatory and recommended Chinese national standards respectively. General fasteners used in rail fastening assemblies may be subject to standards such as the GB/T 3098 series for mechanical properties and GB/T 90.1 for acceptance inspection.
Complete railway fastening systems and dedicated railway components are not governed by GB documents alone. China also uses TB/T railway industry standards, including TB/T 3519-2018 for general technical requirements of fastenings for mixed passenger and freight railways, TB/T 1495-2020 for Type I spring-clip fastenings, TB/T 3065-2020 for Type II systems and TB/T 3570-2021 for Type III systems. Separate TB/T series apply to high-speed and other specialized systems.
When a customer requests production 'to GB', the technical review should therefore determine whether the requirement concerns a general threaded fastener, a dedicated fastening component or a complete railway fastening assembly.
Performance Topics Commonly Covered Across Standards
Although their structures and test conditions differ, rail fastening standards commonly address the following performance topics:
1. Longitudinal rail restraint. This evaluates the ability of a fastening system to limit rail slip and provides data for continuously welded rail and track-bridge interaction analysis.
2. Torsional resistance and gauge retention. These characteristics indicate the tendency of the rail to rotate or allow gauge change under lateral loading.
3. Clamping force and uplift stiffness. These tests characterize the hold-down action of the resilient component and the response of the assembly to uplift.
4. Repeated loading and fatigue. Cyclic testing is used to assess the long-term behavior of clips, anchors, insulators, gauge blocks and pads.
5. Static and dynamic stiffness. These measurements describe the deformation characteristics of rail pads, baseplate pads and complete assemblies under load and vibration.
6. Impact attenuation and load distribution. The fastening and resilient layers are assessed for their influence on impact, vibration and support loading.
7. Electrical resistance. Wet-condition testing evaluates the resistance between running rails provided by the fastening system for signalling and track-circuit applications.
8. Anchorage pull-out and environmental durability. These checks address the security of cast-in or attached components and the stability of the assembly under corrosion, temperature, salt and contaminated conditions.
The specimen configuration, support condition, loading sequence, measurement position and acceptance rules may differ between standards. Results with similar names should not be compared directly until the underlying test methods have been reviewed.
Turning a Standard Reference into an Executable Purchase Specification
A clear enquiry or technical agreement for rail fastenings should address at least the following points:
9. Define the application. State the route type, track gauge, rail section, sleeper or slab support, axle load, speed, curve radius, climate and signalling-insulation requirements.
10. Define the system boundary. List the complete bill of materials, quantity per assembly, interfaces and which party supplies the rail, sleeper or embedded components.
11. State the standard number and edition. Do not use AREMA, DIN, BS, UIC, GOST or GB as a stand-alone label, and identify any owner or infrastructure-manager specification.
12. Confirm material and manufacturing requirements. Include steel or polymer grade, heat treatment, hardness, coating, dimensional tolerance and marking.
13. Specify system-performance testing. Define the scope and acceptance basis for type tests, sample tests, factory inspection and third-party testing.
14. Agree on documentation. Identify material certificates, dimensional reports, heat-treatment records, coating reports, test reports and batch traceability information.
15. Control technical changes. After sample approval, establish a re-approval process for changes to materials, processes, tooling or critical dimensions.
How HuiBo Railway Supports Standards-Based Projects
For projects involving different national and infrastructure-manager requirements, HuiBo Railway can review the customer's drawings, standards list and technical specification to confirm product scope, materials, dimensions, heat treatment, surface treatment and required inspection documents. For complete fastening assemblies, the technical interface should also cover the rail, sleeper, gauge blocks, resilient pads, anchorage components and installation tools.
Confirming the applicable standard and edition during quotation and sample development helps reduce repeated prototyping, omitted tests and delivery disputes. Final production and acceptance should always follow the drawings, technical agreement and contract documents approved by both parties.
AREMA, DIN, BS, UIC, GOST and GB reflect different regional and organizational approaches to railway engineering. They share an emphasis on safety, stability, durability and verifiable performance, but they do not have a simple one-to-one relationship in document hierarchy, scope or test method.
For international rail fastening procurement, the most reliable approach is not a single broad compliance label. It is a defined technical baseline combining application conditions, complete system configuration, current standard editions, test methods and deliverable documentation.
Standard Status Notice
Standards are periodically reviewed, amended, replaced or withdrawn. The references in this article illustrate the typical structure of each framework. Before project execution, the latest valid editions should be confirmed with the relevant standards body, purchaser or railway infrastructure manager.
Contact Us
Telephone: +86 15366202830 / +86 13962481343 / +86 512 5259 1998
Contacts: Miss Cecilia Lin / Mr. Jordon Liu
Address: 2302, Block B, World Trade Center, 45 Haiyu North Road, Changshu, Suzhou, China
http://www.hbrailwayfastening.com
https://www.hbrailwayfastening.com/ -
