2025-03-17 at 3:04 pm #12224
Parquet flooring is a decorative and practical floor material that is popular among consumers for its unique design, rich texture and high-quality materials. Whether in home decoration, commercial space or high-end hotels, parquet flooring has shown extraordinary charm. However, choosing parquet flooring is not just about choosing the style and color you like. The size and laying method of the floor are also very important, which directly affects the beauty and service life of the floor. This article will explore the size selection and laying suggestions of parquet flooring in depth to help you make wise decisions when purchasing and installing.
1. Selection of parquet flooring size
Parquet flooring has a variety of sizes, mainly including different specifications such as length, width, thickness, etc. The correct size selection can affect the effect and visual experience of floor laying. The following aspects are the factors that need to be considered when choosing the size.
1.1. Size of space
First of all, the size of parquet flooring should be determined according to the size of the room. When the space is large, you can choose a larger floor size, so that the floor after laying looks more coordinated and atmospheric. On the contrary, for smaller spaces, using small-sized parquet flooring can avoid the space appearing too depressing or heavy. Smaller floor sizes have better adaptability and can be laid more flexibly in a small area, increasing the visual flow.
For example, in a large living room, you can choose a large-sized parquet floor (such as 1200mm×200mm), which can create a more spacious and open feeling. In relatively small spaces such as bedrooms or study rooms, choosing a smaller-sized parquet floor (such as 600mm×600mm) will make the space look more compact and warm.
1.2. The impact of parquet design
The design method of parquet floor is directly related to its size. Generally speaking, there are many styles of parquet design, such as rectangle, square, diamond, hexagon, etc., and each design style has different requirements for size. When choosing parquet floor, you should choose the appropriate parquet style and size according to the decoration style of the room and personal preferences. For example, if it is a classic traditional style, a smaller and finer parquet design may be more in line with the overall atmosphere, while a modern minimalist style can choose a larger parquet floor to create a simple and open space effect.
The splicing form of parquet floor will also affect its visual effect. For example, square parquet flooring is suitable for simple and direct geometric shapes, which can enhance the modern sense of space; while irregular parquet is suitable for traditional, European or classical style decoration, which can bring a more complex and rich visual experience.
1.3. Floor thickness
The thickness of parquet flooring is generally between 8mm and 15mm. Thicker floors are usually more durable and suitable for high-frequency commercial spaces or large venues. Relatively speaking, thinner floors are more suitable for home decoration, especially when the height and ground flatness are required. Choosing the appropriate floor thickness should take into account factors such as the use requirements of the space, the bearing capacity of the ground, and the personal budget.
In addition, the choice of thickness will also affect the sound insulation and comfort of the floor. Thicker floors are usually more comfortable to the feet and can effectively isolate noise, especially suitable for bedrooms or study rooms where a quiet atmosphere is required.
1.4. Floor size standards
The size standards of parquet flooring vary depending on the brand and market demand. In the international market, common parquet flooring specifications include 600mm×600mm, 1200mm×200mm, 900mm×150mm, etc. These are relatively standardized sizes that can meet the needs of most homes and commercial spaces. According to your needs, choosing the right size standard can make installation more convenient and avoid waste due to inappropriate size.
2. Recommendations for laying parquet flooring
After choosing the right size of parquet flooring, laying is another important link. The laying method directly affects the visual effect, performance and maintenance difficulty of the floor. Here are some laying suggestions to help you achieve the best results when installing parquet flooring.
2.1. Preparation before laying
Before laying parquet flooring, you first need to check and clean the basic ground. Make sure the ground is flat, dry and oil-free to ensure the firmness and long-term use of the floor. If the ground is uneven, it may be necessary to level it first to ensure the flatness and stability of the laying effect. In addition, parquet flooring should be properly adapted to the environment first to avoid expansion or contraction due to changes in humidity.
2.2. Choose the right laying direction
When laying parquet flooring, choosing the right laying direction can affect the visual effect of the space. Generally speaking, the laying direction of parquet flooring should be coordinated with the direction of light flow, the length and width ratio of the space, and the design style. For example, in a long and narrow corridor, you can choose to lay the floor along the length of the corridor, which can make the space look more spacious; while in a wide living room, you can choose to lay it horizontally to enhance the layering and depth of the space.
For complex parquet designs, it is usually recommended to adjust the laying direction according to the characteristics and size of the pattern to maximize its design beauty.
2.3. Reasonable gap
When laying parquet flooring, gaps are very important. The floor will expand or contract when the temperature and humidity change. If there is no proper gap, it may cause the floor to warp or deform. Therefore, when laying, it is usually necessary to leave a certain expansion gap between the wall and the floor so that the floor can adjust naturally.
The size of the gap is generally determined by the thickness of the floor, the size of the space, and the material of the floor. In general, the gap width is between 8mm and 10mm. If you choose a larger parquet floor, the width of the gap can be appropriately increased to avoid floor deformation caused by changes in temperature and humidity.
2.4. Choose the right laying method
There are many ways to lay parquet floors, including straight laying, diagonal laying, and herringbone laying. The effect and applicable scenarios of each laying method are different. Choosing the right method can improve the beauty and comfort of the space.
Straight laying: suitable for simple and modern home design, the laying effect is simple and atmospheric, and easy to construct.
Diagonal laying: suitable for larger or irregular spaces, can increase visual dynamics and changes, and is commonly seen in European or classical style decoration.
Herringbone laying: suitable for luxurious and retro spaces, can enhance the layering and artistic sense of the space, but the laying is difficult and requires higher construction skills.
2.5. Maintenance and maintenance
The maintenance of parquet floors is equally important. Regular cleaning and maintenance can effectively extend the service life of the floor. During daily use, avoid hard objects hitting the floor surface to avoid scratches; at the same time, avoid long-term water accumulation or exposure to the sun on the floor to prevent the wood from getting damp or fading. Waxing or oiling the floor regularly can increase the gloss and stain resistance of the floor.
The size selection and laying method of parquet flooring directly affect the overall decoration effect and its service life. Choosing the right size, laying method and reasonable maintenance measures can not only improve the beauty of the home, but also enhance the durability of the floor. Whether in home decoration or commercial space design, parquet flooring is an important element that cannot be ignored. Through careful selection and professional installation, you will definitely get a high-quality floor that is both beautiful and practical.
http://www.boruiwoodfloor.com
Borui floor -
