PAY EQUAL ATTENTION TO SAFETY AND DELICIOUSNESS: CORRECT INSTALLATION AND USE OF SODA MAKER GAS CYLINDER
  • #8642
      https://www.cnhfprecision.com/news/6453.html
      The soda maker gas cylinder is an important accessory for making carbonated drinks. Correct installation and use can ensure the effectiveness and safety of carbonated drinks.
      Gas cylinder installation:
      1. Confirm the installation position of the soda maker's gas bottle, align the interface at the bottom of the gas bottle with the soda maker's connection port, and gently rotate the gas bottle until it is firmly installed.
      2. Carefully check whether the connection port between the gas bottle and the soda maker is sealed to ensure that there is no gas leakage.
      3. Be careful not to use too much force or too little force to avoid damaging the connection port of the gas bottle or soda maker.
      To make carbonated drinks:
      1. Pour clean water into the container for making carbonated drinks, making sure the water level in the container does not exceed the mark line.
      2. According to the soda maker's operating instructions, follow the correct steps to connect the gas bottle to the soda maker and open the gas valve to release the carbon dioxide gas.
      3. Select the appropriate amount of gas injection according to your personal taste, and wait for a moment for the carbon dioxide gas to completely dissolve.
      4. Gently shake or stir the container to allow the carbon dioxide gas to fully dissolve in the water to form a satisfying bubble taste.
      5. Add juice, syrup or other flavorings as needed to adjust the taste of carbonated drinks.
      Vivi
      hf@hfinnovation.cn
