PPWR Compliance for Metal Packaging: Heavy Metals, PFAS, and Material Safety Requirements
  • #18561
      The European Union's Packaging and Packaging Waste Regulation (PPWR) is introducing stricter requirements for packaging materials, placing greater emphasis on chemical safety, recyclability, and environmental responsibility. For metal packaging manufacturers exporting to the EU, controlling hazardous substances and maintaining reliable material documentation are becoming essential parts of supply chain management.
      Among the most important compliance requirements are restrictions on heavy metals and PFAS in packaging. These rules require manufacturers to review not only their primary metal materials but also coatings, closures, gaskets, printing inks, and adhesives.
      Understanding the Heavy Metal Restrictions
      Under the PPWR, the combined concentration of lead, cadmium, mercury, and hexavalent chromium in packaging must not exceed 100 mg/kg. This limit applies to the packaging as a whole, making material selection and supplier management particularly important.
      Although steel and tinplate generally present relatively low heavy metal risks, other components may introduce unwanted substances. Surface treatments, coating pigments, plastic closures, rubber seals, printing inks, and adhesives all deserve careful attention.
      Metal packaging manufacturers should establish a systematic inspection process covering every material used in production. Supplier declarations, chemical composition records, and laboratory testing can help identify potential risks before finished packaging enters the European market.
      PFAS Restrictions and Food-Contact Packaging
      PFAS restrictions are another significant challenge for the metal packaging industry, especially manufacturers producing food-contact containers. Certain fluorinated chemicals may be present in protective coatings, gasket materials, surface treatments, or manufacturing auxiliaries.
      The PPWR establishes specific PFAS concentration thresholds for food-contact packaging, requiring manufacturers to evaluate their material formulations and production processes. Internal coatings and sealing components are particularly important because they may come into direct contact with food or influence packaging safety.
      Companies should work closely with coating and gasket suppliers to obtain detailed PFAS declarations and identify suitable alternatives where necessary. Depending on the application, alternative sealing materials and PFAS-free coating technologies may help reduce compliance risks.
      The Importance of Coatings and Material Selection
      Protective coatings play an important role in metal packaging by improving corrosion resistance, chemical compatibility, and product protection. However, changing environmental regulations are encouraging manufacturers to reconsider traditional coating formulations.
      BPA-related restrictions and growing demand for safer food-contact materials are accelerating the development of BPA-free epoxy coatings, water-based systems, and other innovative solutions. Investing in compliant materials can help manufacturers maintain product quality while adapting to changing European requirements.
      Practical Steps for PPWR Compliance
      Metal packaging manufacturers can strengthen their compliance management through several practical measures:
      • Create a material inventory covering steel, coatings, closures, gaskets, inks, and adhesives.
      • Request updated declarations of conformity and relevant laboratory test reports from suppliers.
      • Identify high-risk materials containing heavy metals or fluorinated substances.
      • Conduct separate PFAS and chemical assessments for food-contact packaging.
      • Maintain batch records, supplier documentation, and retained samples for traceability.
      A well-organized documentation system can make customer audits more efficient and help manufacturers respond quickly to regulatory inquiries.
      PPWR compliance is becoming an important consideration for metal packaging manufacturers serving the European market. Heavy metal limits, PFAS restrictions, coating requirements, and material traceability all require greater attention throughout the production and procurement process.
      By strengthening supplier communication, improving material verification, and adopting safer packaging technologies, manufacturers can reduce compliance risks and build stronger relationships with international customers. Proactive chemical management is not simply a regulatory obligation; it is also an opportunity to improve product reliability, sustainability, and long-term competitiveness.
      http://www.jiangyinforward.com
      Jiangyin Forward Supply Chain Management Co.,Ltd.
