Professional Stage Lighting Optics: China’s Precision Supplier
  • #18681
      Addressing the Core Challenge in Color-Mixing Optics
      Professional stage, film, and photography lighting designers face a persistent engineering challenge: how to mix colored light from multiple LEDs into a single, uniform beam without visible color fringing, hotspots, or uncontrolled spread. Traditional transmissive color-mixing methods often produce exactly these problems—color fringing at beam edges, uneven color output across the field, and beam angles that are difficult to control. For manufacturers sourcing optical components for film spotlights, photography lighting, long-distance floodlights, zoom wash lights, and projection imaging lights, solving this challenge requires more than generic diffusers; it demands purpose-engineered optical systems.
      TOPLITE, a brand specializing in optical components for professional lighting equipment, has built its technical platform specifically around this problem, offering a structured product matrix of 82 distinct optical components and modules designed for film and television lighting, photography lighting, and broader professional lighting equipment applications.
      Mirror-Reflection Color-Mixing: The MRDB Series
      At the center of TOPLITE’s technical capability is a mirror-reflection color-mixing optic barrel platform, embodied in the MRDB Series. Unlike transmissive approaches, this technology platform uses mirror-reflection color-mixing optic barrels combined with optical glass light guides and combination lenses, and is compatible with Fresnel and imaging lenses for downstream system integration.
      The MRDB Series achieves a visible-light reflection rate of up to 99%, paired with a micron-level double-layer diffuser and a high-precision coated glass lens. This combination is engineered to improve color uniformity, narrow the beam angle, and increase brightness without introducing color fringing—directly addressing the pain points inherent to conventional color-mixing designs.
      The series spans a wide operational range: it supports COB LED light sources from 8 mm to 30 mm LES (light emitting surface), with MRDB power ratings from 60 W to 1,200 W. Within this range, TOPLITE offers 17 distinct MRDB models (including MRDB35-130AEC, MRDB40-183A, MRDB60-183BEC, MRDB45-240BEC, and MRDB50-300BEC, among others), each specified with precise beam angle data at both 10% and 50% intensity, along with detailed mechanical dimensions. This level of specification allows lighting engineers to select components based on exact optical and mechanical requirements rather than approximate ratings.
      STONEHENGE: Patented Optical Integral Matrix Technology
      TOPLITE’s STONEHENGE series represents its proprietary R&D output: a patented optical integral matrix design that uses light guides arrayed with color LEDs to achieve high-power color mixing. This series is organized into four distinct families, each targeting a specific power and application profile:
      STONEHENGE RGBW Optical Modules (120RGBW, 240RGBW, 480RGBW) use 5060 RGBW 4-in-one LEDs, with module power ranging from 120 W to 480 W and beam angles narrowing from 51 degrees down to 39 degrees at 50% intensity as LED count and power increase.
      STONEHENGE AL Optical Modules (400AL, 600AL, 1000AL) are engineered for high-power LED arrays using 5050 RGBW 4-in-one packaging, with LED counts from 32 to 88 and module power reaching up to 1,760 W when LED power is 30 W. These modules maintain a consistent 40-degree beam angle at 50% intensity across all three variants, enabling flat light source output with high brightness and color-mixing uniformity—critical for applications requiring predictable beam control at scale.
      STONEHENGE OS Optical Modules (OS300, OS600) support both 6070 RGBW 4-in-one and 7070 RGBACL 6-in-one LED packages, offering narrower beam angles (as tight as 26.5 degrees at 50% intensity for OS600) suited to applications demanding flexible color support with high brightness.
      Across the STONEHENGE line, the differentiated value proposition is consistent: compared with discrete color-mixing approaches, these integral matrix modules deliver higher brightness, better color-mixing uniformity, narrower beam angles, and are easier to configure, maintain, and upgrade.
      If you want to learn more about related optical knowledge, visit the following URL: https://youtu.be/LzsoTXuiwnE to get more related information.
      Light Guides and Combination Lenses: Component-Level Flexibility
      Beyond its flagship series, TOPLITE maintains an extensive catalog of bare and assembled light guides engineered from optical glass for high surface finish and light transmittance:
      • Bare Light Guide Series for LED ≤60W: 36 models covering LED specifications from 2020 to 7070 packages, with emitting surface shapes including square, hexagon, octagon, and circle, in lengths from 20 mm to 120 mm.
      • Assembled Light Guide Series for LED ≤40W: 13 models assembled in heat-resistant plastic brackets with a glass diffuser on the head, designed for RGBW or RGBL 4-in-one LEDs up to 5060 packaging.
      • Assembled Light Guide Series for LED ≤60W: 6 models supporting 6070 or 7070 packages in 4-in-one or 6-in-one configurations.
      This granularity means that whether a customer is designing around a compact 2020 LED package or a larger 7070 array, there is a matched light guide with defined light emitting size, length, and emitting surface shape—eliminating guesswork in the design phase.
      Complementing the light guides, TOPLITE’s Combination Lens Models (PST5320 and PPT6219) are PMMA lenses designed to pair with light guides for wide zoom ranges. The PST5320 offers a zoom range from 5 to 60 degrees (varying slightly by light guide model), while the PPT6219 offers 4 to 60 degrees, both compatible with LED power options of 40 W, 40-50 W, and 60 W across 18 different light guide models.
      If you want to learn more about related optical knowledge, visit the following URL: https://youtu.be/TBiRqzCR4ZQ to get more related information.
      Paired Optical Series for Complete Light Engines
      For customers building complete color-mixing spotlights or imaging lights around the MRDB Series, TOPLITE offers two paired optical series: TOP-GF Series Glass Fresnel Lenses, spanning diameters from 50 mm to 350 mm and beam angles from 2 to 80 degrees for smooth, uniform light spots; and IMM Series Lens Assemblies/Lenses, spanning diameters from 44 mm to 140 mm, engineered for sharp imaging and uniform light spots in high-precision optical imaging applications.
      Service Model Built for Custom LED Matrix Development
      TOPLITE’s service capability extends beyond component supply. The company provides custom installation structures, custom power configurations, custom sizes, and technical drawings to support customers building their own LED matrix light sources. In terms of delivery, bulk STONEHENGE orders are supplied as optical parts only, while sample orders may include assembled modules for evaluation purposes—final production form and performance remain subject to subsequent batch conditions.
      This structure reflects a deliberate business model: TOPLITE positions itself as a platform-level optical component supplier whose outputs are open and non-standard sizes and powers can be customized, with drawings and technical support provided to customers undertaking LED matrix production themselves.
      Platform Compatibility Across LED Configurations
      TOPLITE’s platform supports a wide range of color configurations, including white, cold-warm white, RGBW, and RGBALC, and is compatible with COB-type LED light sources as well as LED packages including 2020, 5050/5060, 6070, and 7070. This breadth of compatibility, combined with the ability to pair with TOP-GF Series Glass Fresnel Lenses or IMM Series Lens Assemblies, allows lighting equipment manufacturers to standardize on a single optical supplier across multiple product lines rather than sourcing different components for each LED configuration.
      For engineering teams and manufacturers in film and television lighting, photography lighting, and professional lighting equipment sectors evaluating optical component suppliers in China, the core considerations typically include technical depth, specification transparency, and customization capability. TOPLITE’s documented technical metrics—99% reflection rates, micron-level diffusers, defined beam angle data across its full MRDB and STONEHENGE catalogs, and a service model built around technical drawings and custom support—provide a factual basis for evaluating fit against specific project requirements in professional stage and studio lighting applications.
      TOPLITE will be attending the 2026 LDI Show in the United States. We will be waiting for you at Booth #1509 and look forward to meeting you in Las Vegas from December 6–8, 2026! To see more of our Show videos, please visit the following link for more information:https://youtu.be/-I5p4XAL77g
      https://en.led3d.com/
      TOPLITE
