Professional UAV Propeller Factory in China for Aircraft
  • #17230
      Fixed-wing unmanned aircraft depend on a power component that is often overlooked until it fails: the propeller. High-speed cruising, long-endurance patrol missions, and precision flight control all hinge on a blade that resists stall, keeps vibration in check, and survives repeated takeoffs and landings without cracking. Gemfan Hobby Co., Ltd., operating under the brand name GEMFAN, has built its business around solving exactly these problems for fixed-wing UAV platforms, combining static balance sampling with glass fiber reinforced nylon construction inside a vertically integrated factory in Ningbo, Zhejiang, China.
      Company Background and Manufacturing Base
      Founded in 2012, Gemfan Hobby Co., Ltd. is a UAV propeller research, development, and manufacturing enterprise headquartered in Ningbo. The company operates a 7000-square-meter factory that houses high-precision injection molding machines, CNC machine tools, dynamic balance testers, and tension testers, allowing every stage of production—from mold development to final inspection—to be handled in-house. GEMFAN has developed more than 1,700 propeller models across multi-rotor and fixed-wing categories and holds more than 60 UAV propeller design patents at home and abroad, 56 of which are self-developed patented technologies. The company is recognized as a National High-tech Enterprise, certified to ISO 9001:2015, and holds an EU Certificate of Compliance covering mechanical safety standards EN ISO 12100 and EN 60204-1. Products currently reach over 60 countries and regions, serving UAV brands, OEM manufacturers, and professional operators worldwide.
      Why Fixed-Wing Propellers Demand Different Engineering
      Fixed-wing UAVs operate under aerodynamic conditions that differ sharply from multi-rotor platforms. At sustained high speeds, premature airflow separation can cause a blade to stall, producing a sharp drop in thrust and a collapse in propulsion efficiency. At the same time, high-frequency vibration generated during extended cruise accelerates motor bearing wear and can distort flight control sensor data. Structural strength is equally critical: a fixed-wing blade must maintain its shape under continuous high-speed rotation without deforming or breaking. GEMFAN’s fixed-wing propeller lines, including the VORTEX Gray Electric Fixed-wing Propellers and the VORTEX High-speed UAV Propellers, are engineered specifically to address these three pain points—stall resistance, vibration control, and structural durability.
      Static Balance Sampling: Consistency Built Into Every Blade
      One of the defining production practices behind GEMFAN’s fixed-wing series is static balance sampling. Each propeller in the VORTEX Gray Electric Fixed-wing line undergoes static balance correction before leaving the factory, with residual imbalance controlled within strict industry standards. This step matters because even minor mass asymmetry in a spinning blade translates into vibration at the motor shaft, and that vibration compounds over long cruise durations. By subjecting each unit to static balance sampling, GEMFAN reduces high-speed vibration at its source, which in turn extends motor bearing life and improves the quality of data collected by onboard flight control sensors. For fixed-wing operators running long patrol routes or precision mapping missions, this consistency translates directly into more predictable flight behavior over time.
      Glass Fiber Reinforced Nylon: Material Selected for Repeated Stress
      Material choice is the second pillar of GEMFAN’s fixed-wing engineering approach. The VORTEX Gray Electric Fixed-wing Propellers and the VORTEX High-speed UAV Propellers are both manufactured using imported high-strength glass fiber nylon composite. This material significantly improves tensile strength and impact resistance while keeping the blade lightweight, allowing the propeller to withstand repeated takeoffs and landings as well as operation in complex outdoor environments. Because fixed-wing missions frequently involve field deployment, unpaved runways, and variable weather, a blade that resists cracking and fatigue under repeated mechanical stress is a practical requirement rather than a marginal upgrade.
      A Full Aerodynamic Package for Speed and Stability
      Beyond material and balance, GEMFAN’s fixed-wing propellers incorporate a patented frosted surface treatment on the leading edge. This anti-stall process delays boundary layer airflow separation through microscopic turbulence excitation, which lowers the probability of stall at high speeds and helps maintain stable thrust output. The blade airfoils themselves are developed through iterative Computational Fluid Dynamics simulation, achieving higher lift-to-drag ratios within common Reynolds number ranges and delivering quantifiable improvements in thrust and cruise efficiency at the same motor input power. An ultra-thin blade tip drag-reduction configuration further reduces airflow disturbance, suppresses vortex generation, and lowers both aerodynamic noise and induced drag. The VORTEX Gray Electric series also carries a dark gray anti-wear, corrosion-resistant coating that balances a professional appearance with adaptability to outdoor operating conditions.
      Product Range Across the Fixed-Wing Category
      GEMFAN’s fixed-wing propeller portfolio covers a wide span of platform requirements. The VORTEX Gray Electric Fixed-wing Propellers alone span 5 to 22 inches across 138 models, adaptable to various fixed-wing or multi-axis UAV platforms. For higher-speed applications, the VORTEX High-speed UAV Propellers are available in both two-blade and three-blade configurations: the two-blade series ranges from 5×7.5E/R to 16×12E/R with dual E/R rotation options, while the three-blade series ranges from 5.1×5×3E/R to 8×13×3E/R, also with dual rotation options, including a specialized 7×15BN E/R wide-blade model. Beyond these electric lines, GEMFAN’s broader fixed-wing series also includes fixed-wing gas propellers, fixed-wing wooden propellers, F3A power kits, and additional high-speed propeller options, giving fixed-wing operators a range of material and performance choices under one manufacturer.
      OEM/ODM Customization for Fixed-Wing Manufacturers
      For UAV manufacturers and system integrators developing fixed-wing platforms, GEMFAN provides a one-stop OEM/ODM propeller customization service. This includes requirement analysis and system matching to ensure the propeller works in coordination with motors, ESCs, and the broader platform; CFD simulation and aerodynamic optimization to refine airfoil, pitch, and tip shape before physical production; material development and selection among composite options such as glass fiber reinforced nylon; and mold development through high-precision injection molding and CNC machining. Customers can request customized diameter, pitch, material, branding, and packaging, or engage GEMFAN in deeper ODM collaboration covering the full product lifecycle from concept definition to scale production. Every batch produced under this service passes through GEMFAN’s full-process quality control system, including dynamic balancers and tension testers, and customers benefit from IP support drawn from the company’s patent portfolio.
      A Manufacturing Partner Built on Fifteen Years of Focus
      Across fifteen years in the UAV propeller field, GEMFAN has maintained a market share exceeding 60 percent in the global FPV racing propeller sector and has expanded its product coverage to include cinematic aerial photography, industrial inspection, agricultural plant protection, VTOL, and fixed-wing high-speed platforms. Its proprietary aerodynamic design system boosts thrust efficiency by over 12 percent compared to conventional propellers, a benefit that extends across its product range, including fixed-wing applications where cruise efficiency directly affects endurance. For manufacturers, integrators, and operators seeking a fixed-wing UAV propeller supplier in China that combines static balance sampling, glass fiber reinforced nylon construction, CFD-optimized aerodynamics, and full OEM/ODM engineering support, Gemfan Hobby Co., Ltd. offers a manufacturing base built specifically around these requirements.
      http://www.gemfanhobby.com
      Gemfan Hobby Co.,Ltd.
