2026-11-27 at 5:38 pm #18682
What Rebar Processing Machine Models Are Available Today
Anyone researching rebar processing equipment quickly discovers that the market spans a wide range of machine types, from basic manual-assist cutters to fully automated CNC welding workstations. Chengdu Gute Machinery Works Co., Ltd., operating under its brand name Gooden, maintains a product matrix that covers this entire spectrum, serving global markets including China and various international regions. Below is an organized overview of the rebar processing machine models currently offered, grouped by their functional category.
Manual & Small-Scale Mechanical Equipment
For construction sites and municipal projects dealing with sporadic material processing and small-batch components, two standardized models are available.
The GQ42D Steel Bar Cutter is positioned as a fundamental standard rebar processing solution. It addresses the common pain point where manual saws are inefficient and produce rough cuts, while large CNC lines are too expensive and space-consuming for sporadic needs. Its procurement and operating costs are significantly lower than CNC lines while delivering 10x the efficiency of manual cutting. The machine is lightweight with lifting points, allowing easy relocation in confined areas by a single operator. Core features include an electric mechanical mechanism with high-strength tools for reciprocating slicing that ensures flat cuts without burrs, adjustable limit plates for precision length control that reduce reinforcement waste and rework, a thickened steel body with wear-resistant alloy toolholders supporting continuous batch operations in dusty environments, and safety protection through overload shutdown upon material jamming.
The GW42D-4 Reinforcement Bar Bending Machine serves as versatile on-site equipment for manufacturing stirrups and main bars. It solves the problem of manual bending being labor-intensive and lacking angle consistency, while large equipment cannot fit in small residential or municipal sites. The machine delivers consistent bending angles—L, U, and horseback shapes—that manual tools cannot achieve, and its enclosed turbine-shaft gearbox provides water and dust resistance. A high-strength solid spindle provides stable bending of Φ6–Φ42mm bars with low rebound, interchangeable molds allow rapid production of diverse structural components, and bidirectional bending increases on-site processing capability.
Specialized CNC Steel Cage Fabrication Systems
For large-scale infrastructure foundations, two automated welding systems address cast-in-place pile construction and complex cage fabrication.
The SGH-22-12 / SGH25-12 CNC Reinforcement Bar Cage Roll Welding Machine reduces personnel requirements from 6 workers to 2-3 while increasing production speed. An industry-exclusive adjustment feature—weld-along slot fixing blocks—allows full-range diameter adjustment without custom rings. The dual-turntable coaxial structure ensures high roundness and resistance to distortion, rack-and-pinion transmission delivers higher accuracy and lower noise compared to sprocket systems, automated CO2 welding applies continuous pressure at intersections to eliminate incomplete or missed welds, and heavy-duty hydraulic brackets prevent cage bending under its own weight during fabrication.
The GHZ25-12 Fully Automatic Reinforcement Cage Welding Workstation is a proprietary fully automated system built for bridge, metro, and airport construction. It addresses the high cost of certified welders and low efficiency of manual positioning. Six welding heads work simultaneously, completing a 12-meter cage framework in 20 minutes with zero manual intervention, and the system automatically alerts operators if material lengths deviate from preset requirements. Automatic main bar feeding maximizes worker safety, one-touch operation retrieves preset specs from a database for fully automated cycles, and a cord-wrapping system ensures uniform winding pitch.
CNC Cutting & Sawing Production Lines
These models integrate cutting, sorting, and end-processing for industrial-scale material preparation.
The SGS100 / SGS150 CNC Reinforcement Bar Cutting Production Line reduces the high labor intensity of lifting heavy bars and slow manual sorting. The SGS150 model can process up to 60 tons per shift with only one operator and can be modularly connected to bending centers or threading lines. An enlarged hydraulic shear head allows batch cutting of multiple bars, 24 full-steel precision fixed-length plates with servo positioning ensure rapid, high-accuracy length control, and multi-level storage bins automatically sort cut bars into different compartments.
The SJT50 CNC Sawing and Threading Production Line is an intelligent assembly line for cutting, upsetting, threading, and grinding rebar ends, replacing the traditional requirement for multiple machines and operators. One operator can replace an entire manual assembly line, processing 1,200–1,500 thread ends per shift. Hydraulic dual chucks secure bars during sawing to extend blade life, a patented automated transfer rack eliminates secondary handling between sawing and threading stations, and digital thread dressing through PLC-controlled rolling and grinding delivers superior thread accuracy compared to manual methods.
CNC Bending Centers & Stirrup Machines
This category covers high-precision shaping equipment for complex infrastructure and structural components.
The LSW32B Vertical CNC Rebar Bending Center serves high-speed rail, bridge, and subway projects using 10–32mm bars, featuring an innovative horseshoe-shaped fixture for one-step molding of complex stirrups. Dual bending heads operate simultaneously under full servo control, and an integrated PLC-controlled material rack facilitates direct transfer from shearing lines.
The SGW12D-1 / SGW12D-4 / SGW16D Fully Automatic CNC Stirrup Bending Machines address slow manual stirrup fabrication, which produces only 400 units per hour with inaccurate angles. These machines produce 1,400 stirrups per hour, 3.5 times higher than manual production, using dual-line processing for synchronous straightening and bending of two bars and alloy die steel wheels for long operational life.
The SGWZ16D-3D-4 3D Reinforcement Bar Bending Machine is specialized equipment for 3D patterns, adopted by international clients. A rotation mechanism with a rotating gear plate bends bars at specified angles to create 3D shapes, while magnetic feeding captures straight bars automatically.
The WS42 Horizontal CNC Rebar Bending Center specializes in infrastructure bending for box girders and cap beams. Crank-link lifting simultaneously delivers bars above the bending head to reduce operator lifting effort, and a splined high-quality alloy spindle provides high strength and wear resistance for large-diameter bars.
Market Validation Across Project Types
These models have been applied across infrastructure, building construction, municipal engineering, and power generation projects. In a bridge and infrastructure case, the GHZ25-12 Welding Workstation completed 12-meter reinforcement cage frameworks in 20 minutes, reducing manual labor requirements by 80% with zero-defect weld quality. A high-speed rail project used LSW32B Vertical CNC Bending Centers to process complex bridge abutment frames, achieving ±2mm processing accuracy. A building construction rebar team implemented SGW12D machines, achieving 1,400 units per hour for standard 200x200mm stirrups. A power facility dam construction project used SJT50 lines where one operator processed 20 tons of steel bars (1,500 thread ends) per shift.
Summary
Chengdu Gute Machinery Works Co., Ltd., through its Gooden brand, offers a structured product matrix spanning manual-assist cutters and benders, CNC steel cage fabrication systems, cutting and sawing production lines, and CNC bending centers. This range allows construction enterprises, steel processing centers, and small and medium-sized construction teams to select equipment matched to their specific scale, project type, and site conditions, with standardized pricing and after-sales support built around durable, reliable components.
https://www.gutemachinery.com/
CHENGDU GUTE MACHINERY WORKS CO.,LTD -
