Replacement Filter Element Manufacturer: Yuanmei’s 20+ Years
  • #16813
      For buyers evaluating a replacement filter element manufacturer in China, Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd. — operating under the brand name Yuanmei Filtration (short: Yuanmei Filtration, abbreviated YM Filtration) — presents a case built on documented certifications, cross-brand compatibility, and quantified performance data rather than marketing claims alone.
      Corporate Background and Positioning
      Wuxi Yuanmei Filtration and Purification Equipment Co., Ltd. was founded in January 2016 and is headquartered in Wuxi, Jiangsu Province, China, a region positioned within the Yangtze River Delta and described as a core hub of China’s advanced manufacturing industry. The company is recognized as a National High-Tech Enterprise and holds ISO 9001 certification. According to the company’s corporate background materials, Yuanmei has accumulated over 20 years of technical experience in compressed air filtration, holds 30+ patents, carries an AAA credit certification, and operates in compliance with ISO8573 international standards. The company positions itself as a one-stop innovative manufacturing service provider for compressed air precision filtration, covering R&D, production, sales, and after-sales service for precision filters, replacement filter elements, gas-water separators, stainless steel filters, high-pressure filters, silencers, and diffusers.
      By 2025, the company reports 32 authorized patents, 2 software copyrights, and 4 registered trademarks, operating from a 15,000 m² modern production base.
      Why Replacement Element Compatibility Matters
      A central question for procurement teams is whether a replacement filter element can match the performance of original equipment manufacturer (OEM) parts while reducing cost. Yuanmei’s product documentation lists replacement elements as directly interchangeable with Atlas Copco, Ingersoll Rand, Sullair, Hiross, Parker Finite/EcoPure, Zander, BEKO, Domnick Hunter, SMC, HANKISON, Kaeser, YUKA, Orion, OMI, Donaldson/Ultrafilter, ATS/BEA, and Deltech, among others. The company’s product unit list breaks these down into specific series and model numbers — for example, Atlas Copco/Pneumatech’s DD/PD/QD/UD series and numbered variants such as 091/182/253/354/655/1056/1407/1758/2609, Domnick Hunter’s K003 through K620 range, and Parker’s E020 through E400 series. This level of model-specific documentation allows buyers to cross-reference existing housings without guesswork.
      Alongside compatible replacement lines, Yuanmei also manufactures its own MS Series (MS-007 through MS-400), MJ Series stainless steel sterilization filter elements, and M Series (M001–M013) elements, giving customers both OEM-alternative and proprietary options within the same supplier relationship.
      Filtration Precision and Technical Standards
      Precision filtration performance is stated as reaching up to 0.01μm accuracy, with residual oil content as low as 0.001ppm, positioned as fully compliant with ISO 8573-1:2010 Class 1. The company states its self-developed folded filter elements are designed for low pressure drop and high efficiency. Materials used include aviation-grade filter media and SUS304/316 stainless steel, which is SGS certified, supporting pressure resistance up to 80bar along with corrosion and high-temperature resistance.
      Standard filtration grades documented across the product line include C/Q/PF/AFF at 3μm and 5ppm; T/P/AO/AM at 1μm and 1ppm; A/S/AA/AME at 0.01μm and 0.01ppm; F/AX/AMD at 0.01μm and 0.001ppm; H/ACS/Activated Carbon at 0.01μm and 0.003ppm; and P-SRF sterile-grade elements at 0.01μm with 100% DOP testing. This grade structure allows customers to select elements matched precisely to application requirements rather than defaulting to a single universal specification.
      Testing Infrastructure and Data Traceability
      Yuanmei operates an in-house ACF compressed air testing laboratory equipped with an OIL-Check400 oil content analyzer, a PC400 particle counter, and an FA510 dew point sensor, measuring residual oil down to 0.001mg/m³, particles at 0.1μm, and pressure dew point at -80°Ctd — all stated as compliant with ISO8573-1:2010 Class 1. A DS500 data system is described as recording pressure difference, flow, dew point, residual oil, and particle data with trend tracking, producing certified and retrievable test data intended to support quality control and customer compliance documentation. Full product parameters span a flow range of 0.7–400Nm³/min and a pressure range of 0–80bar.
      Certification and Compliance Framework
      The company’s certification portfolio includes National High-Tech Enterprise status (valid 2024–2027), National Science and Technology SME certification (recognized in 2021, 2022, 2023, and 2025), ISO 9001:2015 (valid until December 2028), ISO 14001:2015 (valid until December 2028), CE certification under the EU Pressure Equipment Directive PED 2014/68/EU, RoHS compliance, and an AAA Credit Rating issued by the China Enterprise Credit Evaluation Center. For hygiene-sensitive sectors, the company references GMP and FDA compliance, with stainless steel filter housing surfaces polished to Ra ≤ 0.8μm, along with ISO 8573-1:2010 Class 1 air quality compliance and ISO 14644 cleanroom classification support for pharmaceutical and biotech applications.
      Quantified Field Performance
      Documented case results across semiconductor and microelectronics, lithium battery and new energy, medical and pharmaceutical, food and beverage, and high-end manufacturing sectors report pressure drop reduced by ≥30%, energy consumption lowered by ≥15%, sterile filters passing 100% of DOP integrity tests, service life of ≥24 months of stable operation with zero quality complaints, replacement element costs reduced by 30%–50% compared with imported brands, and custom solution delivery cycles shortened by ≥20%.
      Service, Pricing, and Delivery Model
      Yuanmei describes a tiered pricing structure — cost-effective for standard models, with premium pricing for custom, high-pressure, sanitary, and sterile filters — positioned between imported brand pricing and general domestic suppliers. Standard products are dispatched from stock within 3–7 working days (with separate company materials noting 7–15 days for standard products in global markets), while custom filters require 15–25 working days covering R&D, production, and testing. Core filter elements are stated to be replenished within 48 hours, and the company offers a 24-hour service hotline, on-site installation and commissioning, and operator training for project-based deliveries.
      Market Recognition
      The company reports stable long-term partnerships with 30+ industry-leading enterprises, a customer loyalty rate of ≥95%, a customer satisfaction score of ≥98%, and zero major quality complaints over 5+ consecutive years. It is also referenced in industry materials as a leading enterprise in China’s compressed air precision filtration sector and among the top 7 stainless steel sterile filter providers for the food and pharmaceutical industries.
      Taken together, the documented compatibility list, ISO 8573-1 Class 1 compliance, in-house ACF laboratory data, and reported field results indicate that Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd. operates with the certification depth, model-specific compatibility data, and service infrastructure that procurement teams typically require when evaluating a replacement filter element manufacturer serving semiconductor, lithium battery, pharmaceutical, food, and general industrial compressed air systems in China.
      https://www.acf-filter.com
