2025-11-06 at 2:10 pm #14156
https://www.sowaysensing.com/blogs/RF-Admittance-Level-Sensor-Calibration-Guidelines.html
In the realm of industrial automation and process control, the accuracy and reliability of level sensors are crucial for optimizing operations and ensuring safety. Shenzhen Soway Tech Limited. (Soway) has developed the RF Admittance Level Sensor, which offers a robust solution for liquid level measurement across various industrial applications. To ensure the long-term stability and accuracy of the sensor, Soway provides comprehensive calibration guidelines.
Calibration Guidelines
Regular Calibration
Importance: Regular calibration ensures the sensor's measurement accuracy and prevents deviations that may occur over time due to prolonged use.
Procedure: The Soway RF Admittance Level Sensor features an on-site calibration function, allowing users to adjust the range, zero point, and full-scale settings via buttons on the sensor. Follow these steps for calibration:
Install the sensor in an environment with a known liquid level.
Press the calibration button to enter calibration mode.
Adjust the zero point and full-scale settings to match the actual liquid level.
Save the calibration settings and exit calibration mode.
Frequency: It is recommended to calibrate the sensor every six months. The specific frequency may vary depending on the sensor's usage and environmental conditions.
Calibration with Standard Liquid Levels
Importance: Calibrating with standard liquid levels ensures that the sensor's measurements are accurate and consistent with real liquid levels.
Procedure: Prepare a container with a known liquid level and install the sensor on it. Follow the calibration steps mentioned above to ensure that the sensor's readings match the standard liquid level.
Frequency: It is advisable to perform a calibration with standard liquid levels once a year to maintain the sensor's long-term accuracy.
Record Calibration Data
Importance: Recording calibration data helps users track changes in the sensor's performance and identify potential issues early.
Procedure: After each calibration, document the calibration date, zero point, full-scale settings, and any other relevant data. Maintain a calibration log for easy reference and analysis.
Frequency: Record calibration data after each calibration session.
Technical Support and Services
Soway offers comprehensive technical support and services to ensure users can effectively utilize and maintain the RF Admittance Level Sensor.
By following Soway's calibration guidelines, users can ensure the long-term stability and accuracy of the RF Admittance Level Sensor, thereby enhancing operational efficiency and reducing maintenance costs. Soway is committed to delivering high-quality products and excellent services to help users achieve their goals in industrial automation and process control.
Label: RF Admittance Level Sensorhttps://www.sowaysensing.com/blogs/RF-Admittance-Level-Sensor-Calibration-Guidelines.html
Shenzhen Soway Tech Limited. (Soway) -
