RF Admittance Level Sensor – High-Pressure & High-Temperature Performance
  • #14709
      https://www.sowaysensing.com/blogs/RF-Admittance-Level-Sensor-High-Pressure.html
      The SFC5 Series RF Admittance Level Sensor from Shenzhen Soway Tech Limited is engineered to deliver reliable liquid level measurement in high-pressure and high-temperature environments. Designed for industrial applications, these sensors provide stable performance under the specified operating conditions.
      Depending on the probe configuration, the SFC5 Series can handle a wide range of temperatures:
      Integrated probe: suitable for temperatures from -40 ℃ to 85 ℃
      Split probe: suitable for temperatures from -55 ℃ to 200 ℃
      In addition to high-temperature resistance, the sensors are built to withstand a rated working pressure of up to 2.5 MPa, making them suitable for viscous liquids, oils, water, and chemical solutions.
      The SFC5 Series RF Admittance Level Sensor is constructed with no movable or elastic parts, ensuring excellent durability, impact resistance, and long-term reliability. This robust design allows the sensors to maintain accurate level detection under the stated temperature and pressure conditions.
      Whether for continuous liquid level measurement or alarm point control, these sensors provide a dependable solution for applications requiring precision under high-temperature and high-pressure conditions. With the SFC5 Series, Shenzhen Soway Tech Limited brings advanced RF admittance technology to these demanding environments, combining accuracy, durability, and adaptability in one reliable sensor.
      Shenzhen Soway Tech Limited. (Soway)
