Right-Side Sink Mounted Eyewash: Key Installation Considerations
  • #17353
      When installing an emergency eyewash fixture, the mounting position can affect accessibility, available workspace, and how easily the fixture can be used in an emergency. A right-side sink mounted eyewash is designed to be installed on the right side of a sink, providing an integrated solution for facilities where an emergency eye/face wash needs to be installed around an existing sink.
      The Model 7612 sink mounted eyewash fixture is designed for right-side sink mounting and incorporates a swing-away configuration. Understanding the key installation considerations can help ensure that the fixture is positioned appropriately for practical use.
      Right-Side Mounting Configuration
      Unlike freestanding emergency eyewash stations, a sink mounted eyewash uses the sink area as the installation location. For the Model 7612, the fixture is configured for right-side mounting, so the sink layout should be checked before installation.
      The available mounting space should provide enough room for the fixture to be securely installed without interfering with other sink components or nearby objects.
      Before installation, it is useful to confirm:
      • The sink has a suitable mounting location on the right side
      • The mounting surface can accommodate the fixture
      • Nearby components will not interfere with the eyewash assembly
      • There is sufficient space for the eye/face wash head to move into its operating position
      • The water connection can be arranged appropriately
      Considering these factors in advance can help avoid positioning problems after installation.
      Consider the Swing-Away Design
      One of the important features of the Model 7612 is its swing-away design. The eye/face wash assembly can be moved into position when the eyewash is needed and moved away when the sink is being used for other purposes.
      Therefore, installation should consider not only the mounting point but also the surrounding clearance. The selected location should provide enough space for the fixture to move without unnecessary interference.
      A suitable installation location should allow the eyewash head to:
      1. Move smoothly from its stored position.
      2. Reach the intended operating position.
      3. Remain accessible during emergency use.
      4. Return to its stored position without contacting surrounding objects.
      This makes clearance an important consideration when selecting the right-side mounting location.
      Check the Sink and Surrounding Space
      The sink should be evaluated as part of the complete installation environment rather than as an isolated mounting surface.
      Cabinet walls, backsplashes, faucets, shelves, laboratory equipment, and other fixtures may affect the available space. Even when the mounting surface itself is suitable, nearby objects could interfere with the operation of a swing-away eyewash.
      For this reason, installers should review the sink configuration and surrounding area before installing the fixture.
      Maintain Easy Access to the Eye/Face Wash
      An emergency eyewash needs to be accessible when required. The mounting position should therefore support convenient access to the eye/face wash assembly without unnecessary obstruction.
      A right-side sink mount can be useful when the sink layout provides appropriate space on the right side. However, the exact position should be determined according to the facility's layout and applicable emergency eyewash installation requirements.
      The goal is to create an installation in which the user can move the eyewash into its operating position and use it without unnecessary interference from surrounding equipment.
      Consider the Water Supply Connection
      Water supply routing is another part of installation planning. The selected mounting location should allow the fixture to be connected to the appropriate water supply without creating unnecessary interference beneath or around the sink.
      Before installation, the installer can review:
      • Available water supply connections
      • Connection location beneath the sink
      • Routing space for supply piping
      • Potential interference with plumbing
      • Accessibility for future inspection and maintenance
      Planning these details in advance can make installation more straightforward and help keep the plumbing arrangement organized.
      Check the Eyewash Operating Area
      The area around the eye/face wash head should remain clear enough for emergency use. This is especially important for a sink mounted design because the fixture is positioned around an existing work area.
      The eyewash should be able to provide its intended flushing function without surrounding objects obstructing the user or interfering with the operating area.
      For the Model 7612, the eye/face wash assembly incorporates an inverted directional laminar flow design. Consequently, the operating position and surrounding clearance should also be considered when planning the installation.
      Why Mounting Position Matters
      Choosing the correct mounting position is not simply a matter of deciding whether the fixture fits on the sink. The position can affect several aspects of installation and subsequent use.
      A properly planned right-side mounting location can help provide:
      • Convenient access to the emergency eye/face wash
      • Sufficient swing-away clearance
      • Appropriate use of available sink space
      • Suitable water connection routing
      • Easier inspection and maintenance
      • Less interference with normal sink operations
      For facilities that already have a suitable sink area, a sink mounted configuration can provide a way to incorporate an emergency eye/face wash into the existing workspace.
      Installation Planning for Model 7612
      When planning a Model 7612 sink mounted eyewash fixture, the right-side mounting configuration should be considered together with the sink dimensions, surrounding clearance, plumbing arrangement, and applicable safety requirements.
      Rather than focusing only on the mounting point or connection location, it is better to evaluate the complete operating area. The fixture needs to be securely mounted while also allowing the swing-away eye/face wash assembly to move into position and remain accessible during emergency use.
      Proper planning at the beginning of the installation can help ensure that the sink mounted eyewash integrates effectively into the existing workspace while supporting its intended emergency eye and face washing function.
      https://www.howshowerpro.com/right-side-sink-mount-eyewash-installation-considerations.html
      Haws Safety Technology (Wuxi) Co.,Ltd
