Stainless Steel Flanges: GB vs ANSI Standards for Industrial Piping
  • #17270
      Selecting the right flange for an industrial piping project involves much more than choosing a stainless steel grade or matching a nominal pipe diameter. The flange must fit the connected pipe or equipment, match the bolt arrangement, satisfy pressure requirements, and follow the standard specified by the engineering system.
      The Stainless Steel Flanges supplied by Wuxi Huazheng Stainless Steel Co., Ltd. are intended for industrial piping and equipment connections where reliable assembly, maintenance access, and material performance are important. For international buyers, understanding the differences between GB and ANSI flange specifications is especially useful when sourcing components from different markets.
      Why Stainless Steel Flange Standards Are Important
      A flange connection normally consists of several coordinated parts, including the flange, pipe, gasket, bolts, valve, pump, pressure vessel, or other mating equipment. These components must work together as one connection.
      The applicable flange standard determines important dimensional and connection characteristics. Depending on the specification, this can include outside diameter, flange thickness, bolt-hole quantity, bolt-hole diameter, bolt-circle dimensions, nominal size, pressure class, and other details.
      This means a description such as "304 stainless steel flange for DN100 pipe" may not provide enough information for accurate purchasing. The material and nominal size identify only part of the product. The applicable standard and connection configuration are also essential.
      For projects involving components from different manufacturers or countries, confirming the standard before production can significantly reduce the possibility of mismatched connections and installation problems.
      GB and ANSI Flanges Are Not Automatically Interchangeable
      GB and ANSI represent different standard systems used for flange design and piping applications.
      GB standards are Chinese national standards commonly used in domestic Chinese engineering and manufacturing projects. ANSI-related specifications are frequently encountered in projects designed around American standards and in equipment supplied for U.S.-based industrial systems.
      Although flanges from these systems may serve similar purposes, their dimensions and connection details can differ. A flange with the same nominal pipe size may not necessarily connect directly to a mating flange manufactured according to another standard.
      For international procurement, the correct question is therefore not simply whether a flange is "GB" or "ANSI." Buyers should determine which standard governs the complete piping system and then ensure that the flange, gasket, bolts, and mating components are compatible.
      Main Factors to Compare When Selecting GB or ANSI Flanges
      1. Flange Dimensions
      Dimensional compatibility is one of the first things engineers and buyers should verify.
      Important measurements can include:
      • Outside diameter
      • Overall thickness
      • Bolt-circle diameter
      • Bolt-hole diameter
      • Number of bolt holes
      • Bolt-hole arrangement
      • Pipe connection dimensions
      • Facing dimensions
      Even when two products have similar nominal sizes, differences in these measurements may prevent direct installation.
      This is particularly relevant when an industrial project combines imported valves, pumps, or other equipment with locally manufactured piping. Engineers should verify the complete connection rather than assuming that nominal size alone guarantees a match.
      2. Pressure Rating
      Pressure requirements are another major consideration.
      Industrial piping can operate under very different pressure and temperature conditions. Chemical plants, petroleum facilities, power equipment, pressure vessels, and process systems may require higher-rated components than standard utility piping.
      Flange selection should therefore consider pressure rating together with temperature, material grade, pipe size, medium, and applicable design standard.
      The flange also works as part of a complete bolted joint. Gaskets, bolts, pipe walls, and mating equipment must be suitable for the same service conditions.
      3. Nominal Size Does Not Tell the Whole Story
      Nominal pipe size provides a useful starting point, but it does not completely define a flange.
      For example, two flanges intended for the same nominal pipe size can have different outside diameters, thicknesses, bolt patterns, or pressure classifications because they follow different standards.
      A complete purchasing description should therefore include the applicable standard rather than only stating the pipe size and material.
      4. Mating Equipment
      A flange must be compatible with the component to which it will be connected.
      Common applications include:
      • Pipe-to-pipe connections
      • Pipe-to-valve connections
      • Pipe-to-pump connections
      • Pipe-to-pressure-vessel connections
      • Pipe-to-equipment connections
      • Maintenance and replacement connections
      For replacement projects, it is especially important to inspect the existing connection. Older systems may have incomplete documentation, making it necessary to confirm dimensions and identify the original standard before ordering replacement components.
      Stainless Steel Grade Selection
      The standard is only one part of flange selection. The stainless steel grade should also correspond to the service environment.
      Common grades used for industrial stainless steel components include 201, 304, 316L, 2205, and 310S. Different grades offer different combinations of corrosion resistance, mechanical properties, temperature performance, and cost.
      For general industrial environments, 304 stainless steel is widely used. Where greater corrosion resistance is required, 316L may be considered. Duplex 2205 can be selected for applications requiring a different combination of strength and corrosion resistance, while high-temperature applications may require specialized grades such as 310S.
      The appropriate material depends on the actual operating medium, temperature, pressure, corrosion conditions, and engineering specification.
      Forged or Cast Stainless Steel Flanges
      Manufacturing method can also affect flange characteristics.
      Forged flanges are manufactured through a forging process that shapes the metal under controlled pressure and temperature. They are commonly considered for demanding applications where mechanical strength and structural reliability are important.
      Cast flanges are produced by pouring molten metal into a mold and can be advantageous for certain designs and production requirements.
      The appropriate process depends on the flange design, quantity, application, required mechanical properties, and applicable specification. Buyers should confirm the manufacturing method as part of the technical purchasing specification when it is important to the project.
      Surface Treatment and Finish
      Surface condition can also influence the suitability of a stainless steel flange.
      Depending on the application, products may be supplied with different surface treatments or finishes, including polished or pickled surfaces. The selected finish should correspond to the requirements of the installation environment and the customer's technical specification.
      For applications involving corrosive media, hygiene requirements, high temperatures, or demanding industrial conditions, material grade and surface treatment should be evaluated together.
      When Should You Use GB Flanges?
      GB-based flange specifications are generally appropriate when the surrounding piping system, engineering drawings, equipment, and project documentation are based on Chinese standards.
      Using components under the same standard can simplify procurement and improve dimensional coordination across the project.
      For Chinese industrial installations or projects designed around GB requirements, selecting a flange according to the specified GB standard can make it easier to coordinate pipes, valves, fittings, and other equipment.
      However, the exact GB standard should still be identified. Simply stating "GB flange" may not provide enough technical information for manufacturing.
      When Should You Use ANSI Flanges?
      ANSI-related flange requirements are often encountered in systems designed according to American engineering specifications or projects using equipment manufactured for U.S. markets.
      For international projects, ANSI-based specifications may also appear when imported pumps, valves, pressure vessels, or other equipment are designed around American standards.
      The same principle applies: buyers should identify the exact applicable specification and pressure class rather than selecting an ANSI flange based only on nominal size.
      If a project combines components manufactured under different systems, compatibility should be verified before production. In some cases, a transition solution or specially specified connection may be necessary.
      How to Specify Stainless Steel Flanges for Purchasing
      A detailed inquiry can help manufacturers understand the exact requirements and reduce unnecessary clarification during production.
      When requesting a quotation, buyers should provide as much of the following information as possible:
      • Stainless steel grade
      • Applicable standard
      • Nominal pipe size
      • Pressure rating or class
      • Flange type
      • Facing requirements
      • Bolt-hole specifications
      • Mating component information
      • Operating temperature
      • Service medium
      • Surface treatment
      • Required dimensions
      • Quantity
      • Inspection or documentation requirements
      For customized projects, drawings or dimensional specifications can further reduce the possibility of errors.
      Before bulk production, sample or dimensional confirmation can also be useful, especially when the flange will connect to existing equipment.
      Industrial Applications
      Stainless steel flanges are used across many industries because they provide detachable connections that simplify equipment installation, inspection, maintenance, and replacement.
      Typical applications include:
      • Chemical processing
      • Petroleum and petrochemical systems
      • Pharmaceutical equipment
      • Food processing
      • Environmental protection equipment
      • Pressure vessels
      • Industrial machinery
      • Energy projects
      • Shipbuilding
      • Engineering installation
      • Water and fluid handling systems
      The exact flange material, standard, pressure rating, and manufacturing method should always be selected according to the specific operating environment.
      Sourcing Stainless Steel Flanges from China
      For international buyers, sourcing flanges involves more than comparing unit prices. Supplier capability, material availability, processing resources, dimensional control, surface treatment, and export experience can all affect the final procurement result.
      Wuxi Huazheng Stainless Steel Co., Ltd. was established in 2009 in Wuxi, China. The company operates as an integrated stainless steel supply chain enterprise covering stainless steel product distribution, manufacturing, processing, and international trade.
      Its product portfolio includes stainless steel plates, pipes, profiles, flanges, elbows, and other related components. Available material grades include 201, 304, 316L, 2205, and 310S.
      The company also operates processing resources including a sheet metal workshop, a surface treatment facility covering more than 3,000 square meters, and a warehouse of more than 6,000 square meters. These facilities support both standard product supply and customized processing requirements.
      Since obtaining import and export rights in 2023, the company has further developed its international business and serves customers involved in chemical equipment, pharmaceutical production, environmental protection, food processing, pressure vessels, machinery, and engineering projects.
      What International Buyers Should Confirm
      When purchasing from an overseas supplier, technical communication should be completed before production begins.
      Buyers should confirm the exact flange standard, material grade, dimensions, pressure rating, surface finish, manufacturing process, inspection requirements, packaging, and delivery terms.
      It is also useful to provide the specifications of the mating pipe or equipment. This allows the supplier to evaluate the connection rather than treating the flange as an independent component.
      For projects involving both GB and ANSI components, engineers should verify compatibility carefully. A flange should not be considered interchangeable merely because its nominal diameter appears similar.
      Final Thoughts
      The selection of Stainless Steel Flanges for an industrial piping system should be based on the complete connection rather than one specification alone. Standard, material, pressure rating, dimensions, manufacturing method, surface treatment, and mating components all contribute to the suitability of the final connection.
      GB and ANSI specifications can both serve important roles in industrial piping, but they represent different dimensional and engineering systems. The correct choice depends on the standard governing the project and the equipment with which the flange must connect.
      For buyers sourcing stainless steel piping components internationally, Wuxi Huazheng Stainless Steel Co., Ltd. provides stainless steel products and processing services for a range of industrial applications. By confirming the required standard and technical details before ordering, buyers can reduce compatibility risks and obtain Stainless Steel Flanges better suited to their piping, equipment, and engineering requirements.
      http://www.hzstainlesssteel.com
