Steam Heated Spray Hank Dyeing Machine for Uniform Skein Yarn Dyeing
  • #15569
      Steam heated spray hank dyeing machine for skein yarn dyeing
      If you are looking for a practical hank dyeing machine for skein yarn processing, this steam heated spray hank dyeing machine is designed to help improve dyeing uniformity, reduce color variation and support stable daily production. It is suitable for dyeing houses that need reliable color consistency, efficient heating performance and flexible processing for different yarn materials.
      Manufactured by Wuxi Shin Tong Yunn Machinery Technology Co., Ltd., this machine is built for real dyeing production requirements. With over 25 years of dyeing machine manufacturing experience and CE-certified equipment, we provide factory-direct solutions for customers who value stable quality, practical configuration and long-term service support.
      It can be used for cotton, wool, acrylic, polyester, viscose, nylon, cashmere, silk and blended yarn in hank form, making it is practical choice for both sample development and bulk production.
      Why Buyers Choose Shin Tong Yunn’s Hank Dyeing Machine
      • Uniform dye liquor circulation for better shade consistency
      • Efficient steam heating with upgraded heat exchanger quality
      • Suitable for different yarn counts, materials and batch sizes
      • Factory-direct supply for clearer communication and better project matching
      • Practical structure for easier maintenance and reliable operation
      What This Machine Helps You Improve
      1. More Uniform Dyeing Results
      For hank yarn dyeing, uneven liquor flow and unstable temperature often lead to color differences between batches or within the same batch. This machine is designed to improve circulation stability and heat control, helping dye liquor distribute more evenly through the yarn and supporting more reproducible dyeing results.
      2. Efficient Steam Heating with 316L Stainless Steel Heat Exchanger
      It is equipped with 316L stainless steel shell-and-tube heat exchanger to support efficient and stable steam heating during the dyeing process. This design helps improve heating performance while also upgrading the quality and service life of the heat exchange section.
      Compared with less robust heat exchange structures, this design offers better corrosion resistance, more reliable heat transfer performance and stronger long-term operating stability. For dyeing factories, it means more consistent process heating, lower maintenance risk and better production continuity in daily operation.
      3. Better Adaptability to Different Yarn Types
      Different yarn material require different circulation strength and process settings. With suitable pump control and practical machine design, this hank dyeing machine can be discussed and configured according to actual yarn type, count and production target.
      4. Lower Risk of Production Waste
      Stable dyeing performance helps reduce re-dyeing, color correction and utility waste caused by process instability. For dyeing houses, that means better production continuity and more controllable operating cost.
      Main Features of the Steam Heated Spray Hank Dyeing Machine
      Feature Description Practical Benefit
      316L stainless steel shell-and-tube heat exchanger Efficient steam heating with stable heat transfer and stronger corrosion resistance Improves heating efficiency, enhances heat exchanger durability and supports reliable long-term operation
      Spray circulation structure Dye liquor is distributed through spray circulation during processing Helps improve liquor penetration and reduce shade variation
      Frequency-controlled pump Pump performance can be adjusted according to yarn and process requirement Supports more flexible processing and protects yarn quality
      Silicone-sealed machine door cover The machine door cover uses silicone sealing to help prevent dye liquor leakage and maintain stable internal temperature during operation Improves operation reliability, helps keep the dyeing process stable, and reduces unnecessary heat loss
      Practical maintenance structure Machine layout supports easier inspection and routine servicing Reduces downtime and improves maintenance convenience
      Suitable Applications
      The dyeing machine is suitable for yarn dyeing factories and textile processors handling hank yarn in different materials and order types. It is commonly considered for:
      • Cotton hank yarn dyeing
      • Wool and cashmere hank dyeing
      • Acrylic and blended yarn dyeing
      • Polyester or synthetic yarn dyeing with suitable process setting
      • Small batch color development and regular production orders
      Why Factory-Direct Supply Matters
      When purchasing hank dyeing machines, buyers are not only comparing price. They are also evaluating communication efficiency, technical clarity, machine suitability, delivery control, spare parts availability and after-sales coordination. Factory-direct supply helps reduce unnecessary communication layers and makes it easier to confirm the right solution for the project.
      At Wuxi Shin Tong Yunn, we have our own dedicated export team, which helps ensure smooth communication between overseas customers and our factory on production details, technical requirements and after-sales issues. This direct coordination improves response efficiency and helps customers receive clearer and more reliable support throughout the project.
      It is especially important for customers processing different yarn types, discussing machine configuration or planning new dyeing capacity, where accurate technical communication and timely service support matter throughout the whole cooperation process.
      Who This Machine Is Suitable For
      • Dyeing houses looking for stable hank yarn dyeing quality
      • Factories needing practical steam-heated dyeing equipment
      • Buyers comparing factory-direct hank dyeing machine suppliers in China
      • Projects requiring discussion on yarn type, batch size and machine configuration
      • Customers who value long-term technical support and spare parts service
      Related Products and Guides
      To compare similar equipment or learn more about yarn dyeing machine selection, you may also review the following pages:
      Need a Suitable Configuration for Your Yarn Dyeing Project?
      If you are planning a hank yarn dyeing project, we can discuss machine selection based on your yarn material, batch capacity, heating method and production target.
      You can send us your yarn type, expected capacity and utility condition for a more suitable recommendation and quotation.
      FAQ
      What yarn materials can be processed in this hank dyeing machine?
      It can be used for cotton, wool, acrylic, polyester, viscose, nylon, silk, cashmere and various blended yarn in hank form, depending on the process requirement.
      Is steam heating better for hank yarn dyeing production?
      Steam heating is widely used in dyeing houses because it supports efficient temperature rise and stable heating control. The actual suitability depends on your plant utility condition and production requirement.
      Can the machine be discussed for different capacities?
      Yes. Machine configuration can be discussed according to yarn type, daily output target, batch size, and factory condition.
      What do buyers usually compare before ordering a hank dyeing machine?
      Buyers usually compare dyeing quality stability, machine structure, heating method, utility consumption, factory experience, spare parts support and after-sales service.
      Why choose factory-direct supplier in China?
      Factory-direct sourcing usually helps buyers communicate more clearly on machine details, reduce unnecessary intermediary cost and improve coordination on production, delivery and service support.
      https://www.yarnfabricdyemachine.com
