2025-07-01 at 3:23 pm #13015
https://www.jj-machinery.com/The-Workflow-of-a-Mortar-Fully-Automatic-Packaging.html
In the era of smart manufacturing and industrial automation, the construction materials sector is rapidly evolving to embrace intelligent, efficient, and precise production systems. One prime example of this shift is the mortar fully automatic packaging line, a comprehensive solution designed to optimize the packaging of dry-mix mortars and other powdered construction materials. Wuxi Jiangjia Construction Machinery Co., Ltd., a leading name in the industry, offers advanced automatic packaging lines tailored for high-performance, accuracy, and operational reliability.
This article delves into the core workflow of Wuxi Jiangjia’s mortar fully automatic packaging line, highlighting each key phase that transforms raw mortar material into neatly packed, palletized, and warehoused products — ready for market distribution.
1. Material Dosing and Conveying
The process begins with precise material dosing and conveying, where raw dry mortar components are measured and transferred through screw conveyors or bucket elevators. This phase is crucial for maintaining product consistency. The system can handle various additives and materials, ensuring uniformity in the final blend.
Advanced sensors and programmable logic controllers (PLCs) manage the proportioning of materials with high accuracy. This phase ensures the right amount of raw material is delivered to the packaging unit, setting the stage for downstream efficiency.
2. Automatic Weighing
After the materials are conveyed to the filling station, automatic weighing mechanisms come into play. Using high-sensitivity load cells and intelligent weighing systems, the packaging line accurately measures the desired weight per bag, whether it's 25kg, 40kg, or 50kg.
The weight data is fed in real-time to the control unit, which adjusts the feed rate to eliminate overfilling or underfilling. This level of precision not only enhances product quality but also reduces material wastage.
3. Bagging and Packaging
Once the correct weight is achieved, the bagging machine takes over. Depending on the configuration, the system supports a variety of bag types including valve bags, open-mouth bags, or FIBC (jumbo) bags.
High-speed filling nozzles ensure fast and dust-free bagging. Bags are automatically positioned, filled, and prepared for sealing without the need for manual intervention. This step is crucial for maintaining hygiene and reducing dust pollution within the facility.
4. Sealing
After filling, the bags move to the sealing station, where they are either heat-sealed, stitched, or ultrasonically bonded, depending on the bag material. A well-sealed bag is essential for preserving the mortar's shelf life, protecting it from moisture and contamination.
The sealing equipment in Wuxi Jiangjia’s system is built for speed and reliability, ensuring consistent sealing quality even in high-throughput environments.
5. Conveying
With the bags now sealed, they are transferred via a conveyor system to the next stage. These conveyors are typically modular and can be customized to fit various plant layouts. The smooth movement of bags helps prevent damage, misalignment, or blockages, keeping the production line flowing efficiently.
6. Palletizing
Next comes the palletizing phase, where automated robotic arms or gantry palletizers stack the bags onto pallets with optimal space utilization. These systems follow pre-programmed stacking patterns that ensure stability and load-bearing balance.
Automation at this stage significantly reduces labor intensity and ensures a uniform, professional appearance — ideal for logistics and retail presentation.
7. Wrapping
To protect the stacked mortar bags from environmental elements during storage and transport, the pallets are wrapped using an automatic stretch wrapping machine. The plastic film is applied tightly around the pallet, securing the load and minimizing shifting during transit.
Wuxi Jiangjia’s wrapping systems are designed to work in sync with the palletizer, providing seamless transition and high-speed output.
8. Warehousing
The final stage is automated warehousing, where the wrapped pallets are either moved to a storage zone or directly loaded onto trucks for distribution. Integration with warehouse management systems (WMS) allows for smart inventory tracking and real-time logistics coordination.
This end-to-end automation — from raw material to warehouse — results in a packaging line that is not only fast and precise but also scalable and future-ready.
Wuxi Jiangjia Construction Machinery Co., Ltd. -
