2026-08-21 at 4:36 pm #17283
Understanding the SUP37S Five-in-One Biaxial Swing Welding Head
The SUP37S Five-in-One Biaxial Swing welding head, developed by Wuxi Super Laser Technology Co., Ltd. under its Suplaser brand, represents a focused engineering response to a persistent challenge in industrial welding: the need to combine process flexibility with signal stability and manageable weight. Positioned within Suplaser’s Handheld Laser Welding & Multi-Function Series, the SUP37S is built around a 3000W power class and is designed for manufacturers seeking a single tool capable of covering multiple welding and cleaning tasks without switching equipment.
Core Technology Behind the 30 Percent Oscillation Frequency Increase
Digital Drive Solution 2.0
At the center of the SUP37S is Suplaser’s version 2.0 digital drive solution. By adopting this new generation digital drive scheme, the oscillation frequency has increased by 30 percent, and the motor positioning accuracy is correspondingly high. This digital approach to drive control addresses a known limitation of traditional analog systems: instability under electrical interference. For welding operations where consistent seam quality depends on precise, repeatable oscillation, this improvement in frequency and positioning accuracy translates directly into more predictable results across a welding run.
Five-in-One Functionality for Diverse Welding Scenarios
The defining feature of the SUP37S is its innovative “five-in-one” mode, which integrates the functions of platform welding, energy storage welding, handheld welding, cleaning, and weld path cleaning into a single head. These five processes can be switched with just one click, eliminating the need to swap tools or reconfigure equipment when a workflow shifts from, for example, handheld welding to weld seam cleaning. This level of process integration is particularly relevant for metal fabrication workshops and production environments where multiple process types are required in sequence, since it reduces downtime associated with equipment changes.
In addition to the five-in-one mode, the gun body is equipped with an independent switch button for independent process selection, allowing convenient switching among three preset processes. An operating status indicator light is also built in, providing real-time feedback on the system’s operating status so operators can confirm the active mode without interrupting their workflow.
Ergonomic Design and Operational Comfort
The SUP37S appearance has been completely upgraded compared to earlier iterations, with an ergonomic support structure design intended to ensure a more comfortable grip with both hands. According to the product specifications, this design allows the welding process to be effortless and stress-free, which is a meaningful consideration for operators working extended shifts. This ergonomic focus is consistent with Suplaser’s broader corporate positioning, which identifies operator fatigue from heavy equipment and high manual labor intensity as core pain points in industrial manufacturing that its optical and mechanical innovations aim to address.
Enhanced Signal Stability with Shielded Twisted Pair Wiring
Signal instability in welding controls is another pain point that Suplaser’s engineering directly targets. The SUP37S multi-functional cable has been upgraded to a shielded twisted pair configuration, which has stronger anti-interference performance. Combined with the digital drive architecture, this wiring upgrade supports more reliable communication between the control system and the welding head, reducing the likelihood of signal disruption during operation in electrically noisy industrial settings.
Technical Specifications Overview
For engineering and procurement teams evaluating the SUP37S, the documented specifications are as follows:
- Scope of application: up to 3000W
- Collimating Lens: D16 F60mm
- Protective Lens: D18*2mm
- Focusing Lens: D20 F200mm
- Applicable wavelength: 1080±20nm
- Vertical Focusing Range: ±10mm
- Recommended air flow rate: 10-15L/min
- Type of cooling: Water cooling
- Weight: approximately 0.97kg
These specifications position the SUP37S as a water-cooled, mid-power handheld solution suited to applications requiring both welding versatility and dependable optical performance within the specified wavelength and focusing parameters.
Suplaser’s Position in the Laser Equipment Industry
Wuxi Super Laser Technology Co., Ltd., operating under the Suplaser brand, was founded in 2016 and is headquartered in Wuxi, Jiangsu Province, China. The company has built its strategic positioning around a clear insight: industrial manufacturing continues to face high manual labor intensity, operator fatigue from heavy equipment, signal instability in welding controls, and complex maintenance requirements for optical components. Suplaser describes itself as a high-tech enterprise dedicated to the research, development, and production of laser equipment supporting products, with the stated goal of making industrial manufacturing simple and efficient through optical innovation.
This positioning is supported by a substantial intellectual property base. Suplaser holds 86 total patents, comprising 29 invention patents, 36 utility model patents, and 21 design patents, covering optical design and mechanical structures. The company maintains a dedicated Research & Development center in Wuhan to leverage regional optoelectronic expertise, alongside its headquarters and manufacturing base in Wuxi and regional service and technical support offices in Shenzhen and Jinan. Internationally, Suplaser has established market presence in Russia and Vietnam.
Suplaser has also received recognition for its technology and growth trajectory, including the “Best Laser Device Technology Innovation Award” at the 2025 China Laser Star Awards, High-tech Enterprise (HNTE) status, and designation as a “Specialized, Refined, Unique and Innovative SME” by the Jiangsu Provincial Government, in addition to being recognized as a “Gazelle Enterprise” and a “Young Eagle Enterprise.”
Why Consider the SUP37S for Multi-Process Welding Needs
For manufacturing operations that regularly shift between platform welding, energy storage welding, handheld welding, cleaning, and weld path cleaning, the SUP37S offers a way to consolidate these functions into one tool rather than operating separate machines for each task. Its version 2.0 digital drive solution, with a 30 percent increase in oscillation frequency and improved motor positioning accuracy, directly supports welding precision, while the shielded twisted pair wiring addresses signal reliability concerns common in industrial electrical environments. The ergonomic support structure further reduces physical strain during extended handheld use.
As part of Suplaser’s broader Handheld Laser Welding & Multi-Function Series, the SUP37S reflects the company’s stated approach of pairing process integration with attention to operator comfort and system stability. Organizations evaluating laser welding equipment with multi-process requirements may find the documented feature set and specifications of the SUP37S relevant to their technical requirements, and can refer to Suplaser’s published product parameters when comparing performance criteria such as power class, focusing range, and cooling type against their operational needs.
https://www.suplaserweld.com/
WUXI SUPER LASER TECHNOLOGY CO.,LTD -
