SUP37S Wins 2026 OFweek Vico Cup for Welding Innovation
  • #17364
      Introducing the SUP37S: A Five-in-One Breakthrough in Handheld Laser Welding
      The laser processing industry has taken notice of a new benchmark in multi-process welding technology: the Five in One Biaxial Swing Welding Head SUP37S, developed by Wuxi Super Laser Technology Co., Ltd. under its Suplaser brand. This product has recently been recognized with the 2026 OFweek Vico Cup Award for Technological Innovation in Laser Processing Heads, a distinction awarded to WUXI SUPER LASER TECHNOLOGY CO.,LTD for its hardcore technology in this category. For manufacturers evaluating handheld laser welding solutions, the SUP37S offers a detailed case study in how integrated process design, digital drive systems, and ergonomic engineering can be combined into a single tool.
      Why the SUP37S Stands Out: The Five-in-One Innovation
      At the core of the SUP37S’s recognition is its innovative “five-in-one” mode, which integrates five distinct functions into one welding head: platform welding, energy storage welding, handheld welding, cleaning, and weld path cleaning. Operators can switch between these five processes with just one click, eliminating the need to change tools or equipment when a job requires multiple operations. This is a meaningful upgrade over typical single- or dual-function heads, since it directly addresses a common pain point in industrial manufacturing: the inefficiency and downtime caused by constant tool switching during complex fabrication tasks.
      Digital Drive and Precision Control
      The SUP37S is built on version 2.0 Digital Drive Solution, a new generation of digital drive technology. According to the product specifications, this system increases oscillation frequency by 30% compared to previous generations, while also delivering higher motor positioning accuracy. For welding operations that depend on consistent bead quality and swing precision, this digital drive architecture provides a stability advantage over traditional analog control systems, which are more susceptible to signal interference in industrial environments.
      Ergonomic Design for Reduced Operator Fatigue
      Beyond its functional integration, the SUP37S has been engineered with operator comfort in mind. The exterior design has been comprehensively upgraded, featuring an ergonomic support structure that allows for a more comfortable two-handed grip. Suplaser describes the welding process with this head as “effortless and stress-free,” a direct response to the industry-wide challenge of operator fatigue caused by heavy or awkwardly balanced welding equipment during extended shifts.
      The gun body also includes an independent process switching button, allowing users to move between three preset processes without interrupting their workflow. An operating status indicator light is built into the unit, providing real-time feedback on the system’s operating status so operators can monitor performance at a glance.
      Reinforced Cabling for Signal Stability
      To further support reliable operation in demanding industrial settings, the SUP37S incorporates an upgraded shielded twisted pair wire for its multi-functional cable. This upgrade delivers stronger anti-interference performance, addressing another common pain point identified across the industry: signal instability in welding controls that can compromise process consistency.
      Technical Specifications
      The SUP37S is rated for a power class of 3000W, with a stated scope of application up to ≤3000W. Its optical configuration includes a Collimating Lens of D16 F60mm, a Protective Lens of D18*2mm, and a Focusing Lens of D20 F200mm. The head is designed for an applicable wavelength of 1080±20nm and offers a vertical focusing range of ±10mm. It operates with a recommended air flow rate of 10-15L/min and uses water cooling for thermal management. Despite its expanded five-in-one functionality, the unit maintains a manageable weight of approximately 0.97kg.
      A Product Backed by Company-Wide Technical Depth
      The SUP37S does not exist in isolation—it is part of a broader Handheld Laser Welding & Multi-Function Series developed by Wuxi Super Laser Technology Co., Ltd., a company founded in 2016 and headquartered in Wuxi, Jiangsu Province, China. The company has built its strategic positioning around a clear insight: industrial manufacturing faces high manual labor intensity, operator fatigue from heavy equipment, signal instability in welding controls, and complex maintenance requirements for optical components. Suplaser’s mission is to make industrial manufacturing “simple and efficient through optical innovation,” and the SUP37S is a direct expression of that mission, combining lightweight construction, digital signal stability, and multi-process integration in one unit.
      This product-level innovation is supported by substantial intellectual property depth. The company holds 86 total patents, including 29 invention patents, 36 utility model patents, and 21 design patents, covering optical design and mechanical structures. This patent portfolio underpins the proprietary technologies found in the SUP37S, including its biaxial swing technology for automated welding precision and its digital driver systems.
      Recognition Beyond the SUP37S
      The 2026 OFweek Vico Cup Award adds to a growing list of recognitions for the company. In 2025, the company was awarded the “Best Laser Device Technology Innovation Award” at the China Laser Star Awards. It has also been recognized with the Laser Industry Influential Enterprise Award at the 9th Secret Light Awards (SLA) 2026, and holds status as a “Specialized, Refined, Unique and Innovative SME” in Jiangsu Province, a “Gazelle Enterprise,” a “Young Eagle Enterprise,” and a certified High-tech Enterprise (HNTE). These recognitions collectively reflect a sustained pattern of technical innovation across the company’s product lines, of which the SUP37S is a current flagship example.
      Service and Support Infrastructure
      Suplaser’s service capabilities extend across its manufacturing base in Wuxi, with a dedicated Research & Development center in Wuhan, and regional service and technical support offices in Shenzhen and Jinan. This infrastructure supports nationwide technical support in China, along with international technical consultation for global distributors, ensuring that customers adopting products like the SUP37S have access to maintenance and support resources across the company’s operational footprint.
      The SUP37S Five in One Biaxial Swing Welding Head represents a focused response to real operational challenges in industrial welding: the need to reduce tool-switching downtime, minimize operator fatigue, and maintain signal stability during complex multi-process jobs. Its recognition with the 2026 OFweek Vico Cup Award for Technological Innovation in Laser Processing Heads reflects the technical substance behind its five-in-one integration, digital drive architecture, and ergonomic design. For manufacturers and integrators evaluating handheld laser welding equipment, the SUP37S offers a documented example of how Wuxi Super Laser Technology Co., Ltd. translates its stated mission—making industrial manufacturing simple and efficient through optical innovation—into a specific, verifiable product.
      https://www.suplaserweld.com/
