2026-01-13 at 2:26 pm #14965
Brief of TEBOLAM Non-Intumescent Fire-Resistant Coatings
For industrial and construction projects, passive fire protection is a non-negotiable safety requirement—but traditional fire-resistant coatings often fall short, failing to balance durability, heat resistance, and eco-friendliness. TEBOLAM’s Non-Intumescent Fire-Resistant Coatings fill this gap: with superior performance that meets international safety standards, it has become a top choice for global engineers and contractors, effectively addressing the pain points of traditional products.
1. Exceptional high-temperature resistance for reliable heat insulation
This coating excels in withstanding extreme heat, with a high-temperature resistance of up to 1200°C for extended periods. Unlike subpar alternatives, it forms a dense, stable heat-insulating barrier when exposed to flames, directly retarding heat transfer and flame spread. This feature ensures effective protection for key substrates such as steel, concrete, and wood—critical for maintaining structural integrity in high-risk scenarios like industrial warehouses or power plants.
2. Strong adhesion and durability for comprehensive protection
Its strong adhesion capability allows it to bond firmly to various surfaces without cracking or peeling, even in harsh industrial environments. Moreover, it integrates seamlessly with complementary TEBOLAM products, including steel structure fireproof paint, industrial fire protection coatings, and heat-resistant coatings. This compatibility enables the creation of a holistic passive fire protection system, enhancing overall safety performance and extending the service life of protected structures.
3. Eco-friendly low-VOC formula for compliance and safety
The coating adopts a low-VOC (Volatile Organic Compounds) formula, free from harmful emissions and pungent odors. It fully complies with strict international standards such as EU REACH and US EPA, making it safe for both indoor and outdoor applications. This eco-friendly attribute not only reduces environmental impact but also meets the green building requirements of modern projects—avoiding the health and regulatory risks of solvent-based traditional coatings.
4. Versatile compatibility and easy application for efficiency
It boasts wide compatibility with multiple substrates (steel beams, concrete walls, wooden structures), adapting to diverse project needs from industrial facilities to commercial high-rises. In terms of construction, it supports flexible single-coat or multi-coat application (based on fire rating requirements), eliminating complex procedures. Compared to traditional fire protection systems, this simplifies construction, reduces labor costs by optimizing workflows, and shortens project timelines—even beginners can operate it smoothly.
In summary, TEBOLAM’s Non-Intumescent Fire-Resistant Coatings are a versatile and reliable solution for passive fire protection. Suitable for industrial warehouses, commercial buildings, and power plants, they combine high-temperature resistance, durability, eco-friendliness, and easy application—delivering long-lasting, compliant fire safety while cutting maintenance and construction costs. For projects prioritizing safety, efficiency, and environmental responsibility, choosing TEBOLAM means investing in an innovative, industry-leading fire protection solution.
http://www.tebolam.com
Huizhou Wanhong Chemical Co., Ltd. -
