2025-04-02 at 6:39 pm #12319
The ARKON 2.4G Wireless Headphone DHP780A is a wireless TV headphone designed to meet the user's need for superior sound quality, comfort and reliability. As a factory with over 35 years of experience dedicated to producing quality headphones, ARKON offers OEM/ODM co-operation for a wide range of headphones, including wireless TV headphones, wireless headphones for seniors, Bluetooth headphones, infrared teaching headphones and over-ear headphones.The 2.4G Wireless Headphones DHP780A exemplifies ARKON's commitment to innovation and quality.
The Design Highlights of the ARKON 2.4G Wireless Headphone DHP780A
1. Docking Charger
The dock charger is another highlight of the 2.4G Wireless Headphone DHP780A. The convenient and stylish design of the dock serves as both a charging base and a secure storage solution. Users can simply place the headphone on the dock for easy charging.
2. 2.4GHz Digital Hopping System Technology
The ARKON 2.4G Wireless Headphones DHP780A adopts 2.4GHz digital frequency – hopping system technology. This technology provides a stable and reliable wireless connection. It can effectively avoid interference from other wireless devices in the same frequency band, ensuring that the audio signal is transmitted clearly and without interruption.
The Advantages of the ARKON 2.4G Wireless Headphone DHP780A
1. Comfortable to Wear
The ARKON 2.4G Wireless Headphones DHP780A are designed with the user's comfort in mind. The ear pads are made of high – quality materials that are soft and breathable, which can reduce the pressure on the ears during long – term use. The headband is adjustable to fit different head sizes, ensuring that users can wear the headphones comfortably for a long time.
2. The ARKON 2.4G Wireless Headphone DHP780A is equipped with φ40mm drivers to provide a wider sound stage for a more three-dimensional sound experience when watching TV. With the same power input, the φ40mm drivers provide higher volume for use in noisy environments, ensuring that voice dialogue is clearly distinguishable.
3. Supporting One-To-Many Wireless Connections
The ARKON 2.4G Wireless Headphone DHP780A supports one-to-many wireless connections. A single base can connect multiple headphones of the same model at the same time, and it has certain advantages in signal transmission speed and stability.
The Specifications of ARKON 2.4G Wireless Headphone DHP780A
1. Carrier Frequency: 2.4GHz
– The ARKON 2.4G Wireless Headphone DHP780A has a carrier frequency of 2.4GHz, which helps the headphone maintain a stable signal connection during wireless transmission, ensuring smooth audio transmission.
2. Impedance: 32Ω
– The ARKON 2.4G Wireless Headphone DHP780A has an impedance of 32Ω, making it compatible with devices including home TVs, tablets and laptops. This impedance level strikes a balance between sound quality and power efficiency, allowing for optimal performance across different audio sources.
3. S/N Ratio: 80dB
– The ARKON 2.4G Wireless Headphone DHP780A has a signal-to-noise ratio of 80dB. During audio playback, the ratio of useful signals to noise signals is higher, providing users with a clearer and purer sound experience.
4. Battery Capacity: 550mAh
– The ARKON 2.4G Wireless Headphone DHP780A has a battery capacity of 550mAh, which can provide a certain amount of power support for the headphone to meet the user's daily use needs.
5. Driver Unit: φ40mm
– The 2.4G Wireless Headphone DHP780A is equipped with φ40mm drivers for rich, immersive sound. φ40mm driver size allows for better bass response and overall audio performance, ensuring that the user experiences the full frequency range of sound from deep bass to crisp highs.
6. Distortion: 0.5%
– With a distortion rate of just 0.5%, the 2.4G Wireless Headphone DHP780A maintain audio fidelity, ensuring that the sound produced is true to the original recording. Low distortion levels are essential for preserving the integrity of music and other audio content, allowing listeners to enjoy a more authentic sound experience.
7. Operation Time: 12 Hours
– The 2.4G Wireless Headphone DHP780A can operate for up to 12 hours, which is enough to meet most of the user's needs in a day without the need for frequent charging.
The ARKON 2.4G Wireless Headphone DHP780A is a great choice for those seeking high-quality wireless audio and convenience. Its 2.4GHz digital frequency hopping system technology ensures superior sound transmission, while the docking charger adds functionality and style. Whether it's for home entertainment or gaming, the 2.4G Wireless Headphone DHP780A is a premium audio solution that combines performance, comfort and innovation. If you're looking for a wireless headphone that combines reliability and style, the 2.4G Wireless Headphone DHP780A is an excellent choice.
http://www.arkon.com.hk
ARKON -
